Question about Miele Freezers
What dies AU bean on Miele chest freezer display after defrosting
5 Suggested Answers
  • 150 Answers
SOURCE: Kelvinator novelties chest freezer
check the defrost timer, defrost limit, and defrost heater.
Posted on Apr 23, 2008
SOURCE: chest freezer
do you have voltage at the compressor? if not you have an open circuit or bad t-stat. if voltage is present and compressor is not running you have a bad start device or bad compessor. if voltage present and compressor runs you have a refrigeration issue get a new freezer.
Posted on Jul 18, 2008
  • 949 Answers
SOURCE: Can I disconnect the automatic defrost on my chest
Unfortunately they are designed different and the freezer would not function properly after just a few days due the configuration of the evaporator.
Posted on Apr 25, 2010
  • 4793 Answers
SOURCE: there is frost around the
if the frost is just around the top seal area then YES.but if the frost goes further down then the whole unit needs a full defrost (NO scrapers/hot water/steam/or any other "help")use car de icer...and dry thoroughly.also, if too full, it will frost up around the top.
Posted on Aug 22, 2010
Why is there a lot of frost in my woods v15nab freezer?
On a chest freezer, frost always accumulates around the top perimeter first because the warmer moist air comes in contact with that area first once the door is opened. More frequent defrosting may be the answer.
Jun 08, 2014 | GE Freezer  14.8 Cu. Ft. Manual...
Frost building up at the coil. i think the defroster does not work
Chest freezers are manual defrost. Which mean yall unplug it to defrost it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 12, 2011 | Woods Chest Freezer C1501W3
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, wgheaven@yahoo.com.au Russ
Mar 28, 2011 | Whirlpool Freezers
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER
spacer.gif 5.5 Cu. Ft. Chest Freezer bbd4a981-a436-4ad6-b98a-7249ef5d1d1a_300.jpg Click to Enlarge Lowest price:$179.00Description:
Food storage will be a snap with this roomy 5.5 cu. ft. chest freezer, featuring up-front temperature control, storage basket and defrost water drain.
Brand: Magic Chef
Category:
Appliances > Refrigerators & Freezers > Freezers > Chest
UPC: 665679002023
Model Number: MCCF5WBX
Dec 16, 2010 | Magic Chef Chest Freezer MCCF5WBX
My Freezer temp drops to 11c, I have to keep defrosting & then it`s fine for a couple of months
as its a chest freezer you have no auto defrost,so you must do it your self.make sure all food is wrapped/heat sealed bags.to stop moisture/frost from building up.use a freezer thermometer to set at
-18C and do not over fill,if you live in a high humidity area then every other month is about right.DO NOT DEFROST WITH STEAM OR HOT AIR.USE CAR DE ICER .then dry thoroughly.
Aug 21, 2010 | Miele 10.2 cu. ft. / 289 liter Chest...
I have a Kenmore chest type frost free freezer
I am not aware of a chest freezer that is auto defrost.Go ahead and defrost it like you would any chest freezer. Eric
Aug 10, 2009 | Freezers
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
General electric 5.0 chest freezer has water coming all over the floor.
The reason this happens is because the defrost timer is not turning back on when it needs to, causing the freezer to thou out and overfill the drip tray sitting on top of the compressor. A new defrost timer should be available from the local refrigeration wholesalers in your area.
May 11, 2009 | General Electric Chest Freezer FCM5SU
Apr 21, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezers Logo
81 people viewed this question
Top Miele Freezers Experts
John Tripp
John Tripp
Jay Finke
Jay Finke
ray gallant
Are you a Miele Freezer Expert? Answer questions, earn points and help others
