Slinger v72 fan remote do not work - Heating & Cooling
Why is Ariane Slinger so popular?
No idea what heater that is.
Aug 18, 2017 | Heating & Cooling
I got a hp v72 monitor i have a problem when i play games, the games loads then u can play for like 5min then the monitor shuts down, the light switches to orage and i tried to touch the monitor and hit a...
no PC stated
No OS (op.sys) stated
V72 old old old CRT cathode RAY monitor , go to walmart get new $60 monitor. now fixed.
https://h30434.www3.hp.com/
that old useless monitor does not comply to VESA video standards
so fails. on my guessing modern unstated PC
or is bad. most this old are bad, the fact that it runs at all is
a , amazing !!!!
Jul 05, 2017 | HP V72 17" CRT Monitor
Gurggeling sound. while running canhear water
I'm unsure what you mean by the gurgling sound but its normal for water to splash on the outdoor fan blade. It has a slinger ring built onto the tips of the blades to "sling" water onto the outdoor coil in order to make it work better by keeping it cooler.
Jun 15, 2010 | Heating & Cooling
Exact location of the oil slinger/timing belt guide?
Hello.
I'm unemployed. Can't afford to pay Experts.
I think I figured out the way that the oil slinger must go, anyway. Thanks!
Dec 27, 2009 | 1985 Toyota Corolla 2 Door
On the outa half of the wall, its spraying a very light mist, is that normal? Is it safe?
thats great you have it set properly in the window,thats your slinger fan keeping a mist on the compressor to help keep unit cool and head pressure down on unit,theres nothing dangerous its working the way it was designed
Jul 26, 2009 | Danby DAC12070EE Air Conditioner
Sky tv(free) thru BT home hub wat cables do you need
There are some sat that r working with what is called slingers or iks and hub but to get those channels you still have to pay for the iks and slingers. I would check the sat forums.
Jun 13, 2009 | Computers & Internet
Need to find fan for AC# DVAC10038EE. Hi, need to find this fan for my new AC, was busted while trying to make hole in bottom as too much water accumulated. Any idea where this item could be...
Hey, sound like it as doing its job, to remove moisture ans send it to the back bottom coils ,which it suppose to cool the hot gases on the bottom run of coils then if too much water , it runs out the drain hole. You didn't say the fan blades or the fan motor?
Aug 26, 2008 | Danby Heating & Cooling
The blender coupling on my oster snapped in half. I have the replacement part already I just cannot figure out how to get the broken coupling off the base of the motor. I also got a replacement square...
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off" by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
Jul 11, 2008 | Oster 465 Work Top Blender
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
