HOW CAN I GET IT TO PRINT NORMALLUY PLEASE - Office Equipment & Supplies
Not printing
I need to know the model number please. Not printing? I also need to know is it connected with a usb cable or an ethernet cable or a parallel cable. Please state if after you send a print job, does it try to print or does your computer say it never did print? Otherwise your question is vague and quite broad in the fix it world, please elaborate.
Nov 29, 2011 | HP Office Equipment & Supplies
I have connected a SEH print server to a printer, but for some reason i am unable to print. I can connect to the Print server and able to ping it, but when i print a document ( test print) this is...
Hi
Please set up again the printer and set it as default printer.
To correct the installation or the printer driver is corrupted.
Please let me know if you need more help and please rate it if it helps you. regards
Feb 24, 2011 | SEH TECHNOLOGY InterCon® PS34a...
When i print test page the page don't print but i seen nombers& symbol
Actually your printer is printing in Machine language, Please make sure that you have installed the printer drivers into your system, if not please install the printer driver first and then try to print, it will definitely print the test page and other prints as well, please let me know it works or not OR What problem you have faced after that, so i can send you more details about that
Sep 28, 2010 | Zebra LP 2844 Thermal Printer
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
I AM USING KYOCERA 8030 IT NETWORK CONNECTED EVERY TIME I PRINT IT PRINTS TWO BLANK COPIES WHY?
are you facing same problem with other document like notepad ...... please check it please ..... open a notepad type some thing like test print and give print and check its comes blank pages or not .... if its not coming please check the document setting how many pages your document heaving you can give number pages you want to print ....... if you facing same problem with notepad please post you comment ........... and try to uninstall the printer driver and reinstall it ..............
Dec 29, 2009 | Kyocera Office Equipment & Supplies
Trouble with my epson stylus c45 printer. PLEASE HELP!?
this is usually caused by clogged print heads, unfortunately epson is still one of few brands that still manufactures most of their printers with the heads built into the machine and thus upon print head clogging the printer must be taken in to be serviced or buy a new printer that does not have the print heads built in but rather built into the ink cartridges. hope this helps.
Sep 30, 2009 | Office Equipment & Supplies
Please help abt VB6 code for SATO CX400 printer
just make prn file or by crystal report
call me on 9974985001
Feb 04, 2009 | SATO CX400 Thermal Label Printer
I just installed my new printer HP F4280, when gives print command in MS office it give error message MS office has stopped working
Hi Ahsan & Guest,
Thanks for sharing the problem with me.
Please first check printer installation:-
Start --> Printers and Faxes --> Right Click the printer --> Properties --> Print test page.
Problem might be Lose cartridge, Lose cable connections, Paper Jam, previous aoverloaded print que. Please Rectify all this.
There may be a hardware problem with printer itself please take help of printer technician in that case.
If this works, then start MS word, type something on page.
Click on print and select the right printer and print. It will work GoodLuck
Dear Guest, this problem might be in printing the web pages, please select all what you want to print or select nothing before printing.
Please see print preview to make sure that what you are going to print is rightly selected.
Thanks
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Jan 22, 2009 | HP DeskJet F4280 All In One Printer InkJet
Hp 1320 prints blank pages
My HP 1320 printer is printing blank pages and it will not even print test pages etc
Nov 03, 2008 | HP LaserJet 1320 Printer
Photosmart 8250 printing computer codes
my printer photosmart 8250 is printing does not print it says ink system failure when i try to replace it the yellow ink jet so please please help i'm in third world country my email address is abrbw@yahoo.com please help again
Jul 17, 2008 | HP Photosmart 8250 InkJet Printer
jasbo
jasbo
