Question about Kenmore Dishwashers
Ice maker not working, kenmore model 56549400
Arms still in up position...water not coming in...replaced module part #626653...
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
maklean
  • 1665 Answers
SOURCE: no water to ice maker
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Posted on Jul 28, 2008
    duby1990
    • 370 Answers
    SOURCE: ICE MAKER NOT WORKING
    Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
    Posted on Nov 20, 2008
    I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
    Posted on Mar 31, 2009
    • 36 Answers
    SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
    check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
    Posted on Jul 24, 2009
    Ice maker not working. Refrigerator had been off for 1 week. Now not making ice. There is water coming into the water dispenser but does not seem to be getting to the ice maker,
    Hello there
    f your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: bullet.jpg If your ice maker has a small red plastic lever, lower it to lower the wire. bullet.jpg If there's no plastic lever, simply lower the wire. bullet.jpg In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
    Jul 26, 2010 | Kenmore 21.7 cu. ft. Top Mount...
    Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
    First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
    Mar 25, 2010 | Kenmore Freezers
    Icemaker not working on a Kenmore Bottom Freezer
    if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
    Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Kenmore Ice Maker
    Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
    Jun 27, 2008 | Freezers
    Kenmore side by side ice maker
    There are as you can imagine many possible causes for you no ice condition. I will give you the most common problem for the year model you have. I hope this helps you.
    You will need to remove the ice maker from the freezer compartment to check it. Once it is repaired if the following information does help, and you reinstall the ice maker, it should go through a cycle automatically within an hour of your reinstalling it in the freezer compartment.
    Once you have the ice maker out of the freezer compartment you will need to remove the white cover on the end of the ice maker and look at the center of the large white gear. If the part inside the hole in the center of the gear is broken or looks twisted, you will need to replaced the module. The module is the part that has the large white gear and is held in the ice maker by 3 phillips head screws. It only comes as an assembly. You can't get just the little broken piece.
    supertechks
    Please don't forget to rate me
    Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Your motor module is bad on the ice maker. It is located on the left side when mounted in the refrigerator. It is under the White Cover over the end. It is brown in color. To verify the correct problem, the ice stripper arm in the ice maker that turns and pushes the ice out of the mold, should be pointing up towards you when it is in the mounted in the refrigerator. I call it the 2 O'clock position. If the ice stripper arm is pointing another direction, it is broken. I sell the module on Ebay as username, themackshack. My parts are genuine factory parts. Good luck!, Mack
    Jan 08, 2008 | Kenmore 50522 / 50524 Side by Side...
    Ice Maker Not Working
    Vik, the ejector blades should be pointing toward you in the 2:00 position when the ice maker is home. This tends to make me believe that your module is bad. Pull the ice maker out again and check the center white gear. There should be 2 clips holding it on. If one of those clips broke, the gear will not rotate right. Another thing you mentioned is that you had water on the back side where the line goes into the fill tube. You may have a frozen inlet tube too. If the tube is frozen, the pressure will force it out the back by that connection. Pulling that tube out can be a pain, try using a hair dryer if the baster not working. On this model, you can't just jump T&H to start the cycle because of the immiters. Follow these instructions to start a cycle.
    To jump start the ice maker do the following: Unplug the refrigerator. With the ice maker out of it’s mount but connected to the harness use a insulated jumper wire stripped a quarter inch on each end and place the jumper in the holes marked T & H on the module. Place the ice maker with the jumper in, on the shelf with enough clearance to close the freezer door. Close the freezer door. Plug the refrigerator back in and wait 50 seconds. Now open the door and see if the module is rotating. If so remove the jumper, put the cover back on the module and place the ice maker back in its mount. The water fill should take place when the ejector blades are at the 12:00 position. Note that on some models, after you have done the aforementioned proceedure you have to press and release the light switch 3 times for the module to start.
    Dec 02, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
    Icemaker
    Look at the ice maker and see what position the ejector bar (white bar with fingers that turns and ejects the ice).  Looking at the ice maker from the front (front is white plastic cover) the ejector bar should be in the 2-3 o'clock position .  If it is not then the module is broken.  In this case the module and ice maker thermostat need to be replaced.  If not sure how to do this repair then just buy a new ice maker.  Let me know what you find and we can go further if necessary.  This is the first thing to check.
    Oct 20, 2007 | Kenmore 44109 / 44102 Side by Side...
    ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
    Most common problem is a broken ice maker module.  Should also replace ice maker thermostat when changing the module.  Make sure fill tube isn't frozen first. If you take the ice maker out pull off the plastic cover and in the center of the wheel that kind of looks like a gear there are two little plastic studs.  If one is broke or they are pressed together then the module is bad. Make sure to replace the thermostat along with some silicone grease because a bad thermostat is what causes the module to break.
    Oct 19, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Dishwashers Logo
    32 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    vince
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
