Question about Orion Car Audio & Video
I have a orion hcca 5000d amp and the lights flash giving the code that it's being over current. How can I fix this?
  • Shane Clark
    Shane Clark Jun 13, 2017
    Do you have the Bitwriter? If not you can order it off Amazon for around $70. Plug the ESP cable and press the zap button, which will reset it.
  • 300 Answers
SOURCE: orion hcca
The owner's manual states the ported box should be:
  • 4.00 cu ft.
  • Port diameter = 4"
  • Port length = 14"
It doesn't mention round vs. rectangular port. For more details, you may want to contact Orion.
Posted on Mar 20, 2008
SOURCE: old schoool orion amp 250-hcca
Wiring Codes for SX and HCCA
Orange = Right Positive
Black/Orange = Right Negative
Yellow = Left Positive
Black/Yellow = Left Negative
Blue = Remote Turn On
You can remove the bottom of the amp and the colors can be deciphered as to which goes to which pin in the plug. Go to this link on AmpGuts for a reference.
And here is a link where you can buy a new plug on ebay for $25.
Posted on Dec 08, 2008
  • 17 Answers
SOURCE: orion hcca 2100 old school
Try this page:
Posted on Dec 09, 2008
  • 13 Answers
SOURCE: orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Posted on Jul 18, 2009
  • 7 Answers
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Posted on Sep 18, 2009
Schematic for orion HCCA-D2400
The schematic or service manual doesn't appear to be available online. You may have to contact Orion. Verify the REM input to the amp. It should be 12V when the car is on and 0V when the car is off.
Jan 15, 2014 | Orion HCCA-D2400 Car Audio Amplifier
Orion hcca-25001 amp blue and yellow light stays on and still plays
i have a hcca25001 amp need to know if the blue light and the yellow light suposed to stay on when amp on
Jul 04, 2012 | Orion HCCA-25001 - Mono Amplifier
For da orion 2500d, what would be the difference between 10'', 12'', & 15'' orion hcaa subs besides a matter of price and inches? I have two of the orion 2500d amps and am ready for the subs. I would...
I honestly would go with 2 12 inch dual 2 ohm subs and wire them one per amp. That will give you a 1 ohm load to each amp and will give the HCCA's 2500 rms per sub... It will be stupid loud... 10s hit tighter than 12's usually and 12's tighter than 15's but u will get more air movement out of a 15 than the 12's and 10s... but... 2 10's require say a 4 cubic foot box to perform well... 2 12's require a 5 cubic foot box to perform well and 2 15's require about 7 to 10 cubic foot to perform to their fullest... no matter what if you put a sub in a box that's too small it will not perform or sound like what you want it to... go 2 12's and like a 5.50 cubic foot box or a 6 cubic foot box and you will love it...
Dec 01, 2009 | Orion HCCA-D5000 Car Audio Amplifier
I have a d5000 amp and its wired up to a 15.2 hcca orion sub when i turn it up high volume,it cuts out anyone know why
make sure you have the frequency cuts right. if ur giving the sub anything lower then 30hz (assuming ur using 15's) the amp will cut out to protect the woofers from overload
Nov 18, 2009 | Orion HCCA-D5000 Car Audio Amplifier
I have a 12 inch ORION HCCA dvc, 4ohm sub. My
Halving the impedance will draw twice the current. You could technically get a 3 Db more power since the peak voltage will remain the same. BUT if the magnet structure is not intended to use that cone design, the magnet difference MAY not give you 2 ohms.
In fact, if the designed magnetic flux were smaller, you could wind up with a 1 ohm speaker.
trying to get that much power is really kind of silly as even 50 watts with efficient speakers will exceed safe levels of sound that will not cause damage to your ears.
As you push an amp up in power, usually distortion will increase as well.
Oct 26, 2009 | Orion HCCA 12D Car Speaker
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
if its hot its drawing to much current sound as if you have something improperly hooked up..if i could see your wiring i could help u out better steve
Feb 27, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Car Audio & Video Logo
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
