Question about Coffee Makers & Espresso Machines
Replace brewing unit message during calc'n'clean. System asks me to open drawer and then replace brewing unit. Is this a fault or does the unit need to be replaced periodically even if working fine?
During a Calc'n'clean the system asks me to open drawer and then replace brewing unit. Is this a fault or does the unit need to be replaced periodically even if working fine? Can ignore the calc'n'clean message and system still makes great coffee's.
SOURCE: CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Posted on Oct 29, 2007
SOURCE: How to use the calc-clean button
Calc-Clean function
The Calc-Clean function removes scale and impurities.
To do so, set the steam control to position '0', set the temperature dial to 'MAX', and fill water tank up to the 'MAX' level. Then heat up the iron until the pilot light on the handgrip goes out.
Remove the mains plug from the wall socket and hold the iron horizontally over the sink. Then press and hold down the 'CALC CLEAN' button.
Move the iron forwards and backwards while boiling water/steam squirt from the holes in the soleplate to wash away impurities/scales.
When the water tank is empty, heat up the iron to dry it.
Finally move the iron to and fro on a piece of cloth to dry the soleplate. Repeat the process if necessary
Posted on May 24, 2009
  • 85 Answers
SOURCE: How do you 'Calc Clean'?
Hello shid9
This is an easy fix. To decalcify your unit you need to make a water/vinegar solution. 2 parts water and 1 part vinegar. You might need to run two pots of the solution through if the first one is very cloudy. When done with that, rinse with 1 pot of fresh water. This should help remedy your calc problem. I hope this is helpful for you.
Happy brewing! NormanZ
Posted on Jul 16, 2009
SOURCE: On FME4 coffee maker the error message CALC
it means de"CALC"ify its detecting calcium build up the manual says to run white vinegar without the filter followed by two clean water cycles goto krups.com to download the manual
Posted on Dec 20, 2009
SOURCE: fault on water system
please, give some solution because i'm going crazy with this coffee maker - if you want to make a second coffee, probably 10 minutes after you made your first one - "fault on water system"!! and believe me - there is water ..
Posted on Jul 22, 2010
Keurig mini keeps asking to add water
Needs cleaning and reset the system with a full flush and Calc.
Feb 04, 2013 | Keurig B31 Mini Plus Brewing System
Hi the door keeps popping open on my perfecta coffee machine?
I have a DeLonghi Magnifica machine and had a similar problem where the door would pop open itself during the brew cycle. I figured out that there is a movable funnel on the inside of the door (part Z in my manual called a mobile drawer) that was sticking and needed to be cleaned. I had to remove two screws on the top of the door to remove this assembly, then soak it in water to loosen up the coffee deposits. After a thorough cleaning the mobile drawer no longer sticks and the door no longer opens by itself.
Be careful to make sure that you do not lose the little spring mechanism that keeps the mobile drawer in the correct place. I took pictures to make sure I knew how to put the unit back together again. Best of luck.
Apr 28, 2011 | DeLonghi ESAM6600 Espresso Machine
I have a cva coffee machine it seems like the brew unit is jamed it makes a buzzing noise like it is descaling itself , I have cleaned it and checked the shoot for alignment it makwes the noise and then...
F73 is a bad brew unit. The cva 4070,4075,4060, and 4066 are designed to use espresso beans.
If you use an oily bean such as Starbuck's french roast, it will clog the filter in the top of the brew unit. If you catch it in time, you can just replace the brew unit. If you run the machine with a clogged filter long enough, you have to replace the brew unit and gearbox together.
Sometimes if you work with the tech support department, they will send you a brew unit to install yourself. If you live in an area that has Miele factory support, you may just want to get a service call. It is very important to rinse the brew unit every 24 hours, and to use the cleaning tablets in the trap door( not the descaling tablets) if not, the coffee oils build up and turn into a tar that will clog the brew unit. They run about 300 dollars so they are worth doing the maintenence on.
Nov 21, 2010 | Miele Coffee System
I removed the black brewing system from inside the coffee machine, in order to clean it. Now I can't put it back in. The little wheel attached to the back wall of the coffee machine doesn't want to fit...
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now replace the tray and insert the brew group. If it still won't go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Oct 23, 2010 | Saeco Spidem Villa
Saeco Incanto Deluxe brewunit jammed
Remove the dredge drawer. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide that piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Mar 04, 2010 | Saeco INCANTO DELUXE Espresso Machine
Syncrony Compact Digital unit- Used well for 5 yrs without incident. Currently, after bean grinding and tamping stages, a strange, non metallic rumbling/grinding sound occurs just before the...
First clean the screen and tube on the brew unit, then lube the guides/gear grooves on the brew unit, also lube the o-ring(big red one). Then that should take care of it. You can also try backwashing/degreasing the brew unit if the machine has a preground chute.
Feb 07, 2010 | Gaggia Syncrony Compact Digital Espresso...
Brew draw blocked
Ok if brew unit is displayed,the cause is the brew unit needs to be to cleaned of all old grease and coffee grounds.
Once cleaned you will need to regrease the big oring at the top of the brew unit,pretty much anywhere that moves needs to be lubed and the two smaller ones near the back of the dreg drawer.
In some cases a tight or siezed brew unit can damage the main control board.
Feb 02, 2010 | Gaggia Titanium Espresso Machine
Bean and water fault(red) light blinking when i turn on solis master 5000 coffee machine. how to fix it. Regards vh
HI First make sure everything is in and locked (brew unit, drip tray, and dredge drawer). Open the knob on the right and flow water through the wand. Now turn the knob in the bean hopper to 16 and push the brew button. If that didn't work you might have a clog in the grinder, and will need to clean it.
Jan 26, 2010 | Solis Master 5000 Espresso Machine
Hello shid9
Jul 15, 2009 | Philips Senseo HD7832 Coffee Maker
Dreg drawer cannot be inserted back to its place...
Take the brew unit out, (press the leaver and swing it back together and put it back in the machine,
Apr 10, 2009 | Saeco Royal Professional Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
