Question about Cell Phones
Replace VX8350 front lcd screen
I have a VX8350 with a cracked LCD screen. I want to replace it with one from another phone that has a broken hinge. Are there any instructions on replacing an LCD?
Broken screen on sidekick 3
To replace the cracked screen follow the guide below. It is fairly easy to do and runs about 30 dollars from ebay.
Here is a guide for it
Sidekick 3 LCD Screen Replacement
New Sidekick 3 LCD Screens for Sale
Sep 09, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Right Hinge Broken
Here is the response that I got from Verizon customer service today via e-mail. I, too, have the broken hinge on a new LG VX8350:
"According to our records a limited number of LG VX8350 devices may exhibit a cracked hinge or stress cracks on the front housing from normal operation. LG determined hinge / stress cracking is due to a production issue with the hinge. LG has implemented corrective action to resolve issue in future production and devices repaired by LG."
They are replacing the phone with a certified LG. All in all, I am very pleased with their commitment to customer service. I would suggest contacting Verizon directly and letting them know that you are aware of the hinge problems.
Hope this helps.
Aug 03, 2009 | LG VX8350 Cellular Phone
Cracked screen LG vx8350
you will be able to just replace the lcd
thanks
erik
Feb 26, 2009 | LG VX8350 Cellular Phone
How to repair broken hinge of my Verizon LG Vx8350
I was able to take apart a VX8350 I have with a broken screen. I don't see any way to replace just the hinges with replacing the whole top part of the phone including the screen. The ribbon cable from the screen runs through the hinge part into the main assembly of the phone. It appears the cable can't be removed without cutting it.
Jan 11, 2009 | LG VX8350 Cellular Phone
Nokia 6288 Broken front screen and LCD
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Dec 18, 2008 | Nokia 6288 Cellular Phone
LG shine broken lcd screen
klsie66
I have seen lots of LCD Screens cracked or broken on an LG Shine. A replacement screen can be bought for around $20 from Ebay. And the process of replacing it yourself if rather simple. All you need are a small philips screwdriver and a plastic tab (guitar pick) or a fingernail.
Here are two links that will help you out. The first is a guide that will show you step by step how it's done. And the second is a good link for buying replacement LCD Screens to replace your broken one.
Replacement Guide for Cracked LG Shine LCD Screen
Replacement LCD Screens for the LG Shine on Ebay
Sep 28, 2008 | LG Shine KE970 Cellular Phone
How to replace a broken lcd screen
man this is the best i fixed my lcd in les than 2mins ..fantastic
Aug 21, 2008 | Nokia e65 Cellular Phone
REPLACE BROKEN SCREEN
yes it can be fix but you need to replace the LCD... Before you put the new LCD clean up the wire connected from LCD going to your board most of the time that was full of dirt
Apr 07, 2008 | Motorola Mobility RAZR V3
Cracked front cover at hinges
What does work is this-
Superglue the cracked lid as you WILL have one of these if you are reading this post- dont rush, I did about 10 glue applications over a few days to let it set correctly.
Next remove the offending hinges. You will see to spring/pressed steel curves in the body of the hinge, Next hack saw one (the outer is easier to get to) of these off, this frees the hinge up very well. Worked for me so give it a try
Feb 18, 2008 | Acer Aspire 3610 Notebook
Nokia 6133 LCD Replacement Trouble
my guess is that you messed with something while you were prying it open.
I have the nokia 6126 (very similar) with a broken screen but i get it open, could you help me with that
Feb 14, 2008 | Nokia 6133 Cellular Phone
Cell Phones Logo
119 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
