Question about Marantz Audio Players & Recorders
Can I hook an iPhone up to a Marantz AV560? - Marantz Audio Players & Recorders
How do I connect an iPhone or iPad to a marantz sr-68 receiver. The receiver is around 16 years old but produces great sound with the speakers hooked up to it
You need a cable that has a 2.5mm stereo connector on one end and two "RCA" connectors on the other end. Plug into the headphone connector on your device, and the other end to the back of your receiver's "aux" input.
Oct 22, 2016 | Marantz Audio Players & Recorders
How to hook a carver TFM 45 to a Marantz AV 8003 pre amp with Bose 901 speakers thank you very much
The output of the Marantz will go to the input of the Carver. The Bose EQ has to go into a Tape Monitor on the Marantz, or, you can connect the Marantz output to the Bose line in(not tape in). The line output of the Bose, to the Carver input.
Is there anything else I'm missing?
Jan 08, 2015 | Marantz Audio Players & Recorders
How to hook up a Marantz AV 8003 pre amp to a carver TFM 45 amplifier
Marantz preamp out, to Carver amp(or line in). Have you tried this and had problems?
How to hook up a Marantz AZ8003 pre amp to a carver TFM 35 a.m.
Please see my last few comments on the same issue. If you can't find it, please let me know. BTW, Marantz does not show the AZ8003 to be a valid model.
Dec 21, 2014 | Marantz Audio Players & Recorders
Can i hook up 4 8ohm speakers to my marantz 2252b
You can but you will have to put two speakers on the main L/R and two speakers on the remote L/R. DO NOT HOOK UP MORE THAN ONE SPEAKER TO A CHANNEL. Doing so can result in the amp running hot and damage will occur.
Oct 25, 2012 | Marantz Vintage 2252 B Stereo Receiver...
I need to connect to a Marantz SR-19 a record player How do i do it
On the back of the receiver there are connections, usually record player should be hooked up on Phono slot. If Phono is not available, trying using Aux or another slot that isn't being used. After hooking it up, remember the place you hooked it up, turn on the turntable, play a record, then hit the button on the receiver where the turntable is hooked up.
Sep 20, 2010 | Marantz SR-19 Receiver
Archos AV560 - Not charging
charger was failing - tried new charger & it worked
Jul 13, 2008 | Archos AV 500 400-Hours Video Recorder
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
