Question about Food Processors
My thermomix TM31 blades seem to be spinning on shaft and therefore not processing food as it should
3 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: Food processor blade stuck on motor shaft
my friend if you had not removed that blade for a while it will certainly stuck due to the moisture that forms on the shaft of the blade holder causing it to have corosion you will have to carry that item to be removed by a qualified tech by you doing it your self could cause damage,which could cost you more.good luck
Posted on Jun 19, 2007
SOURCE: replace processing glass jar for bravetti quad blade food process
go to ninja kitchen.com
Posted on Aug 04, 2011
My food processor blade keeps popping up (loose) when I put food into it.
You will probably need to replace the sleeve on the motor shaft and the blade. If overloaded the shaft can spin inside the blade which wrecks the connection between them. Replacing both together is the correct solution.
May 16, 2014 | KitchenAid Chefs Chopper KFC3100 3 Cups...
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
I have the 14-Cup Cuisinart Elite Collection Food Processor. Up until recently it was working fine. Recently when using the shredder blade, when I insert food into the feeding tube the blade stops...
If the unit works OK with other attachments and the problem is only with the one cup; then the blade may be loose and spins on the shaft, the connection gear under the bottom is worn or binding up. Debris is stuck around the blade shaft or from heating up the metal parts expanded and bind when turning.
Mar 10, 2014 | Cuisinart Food Processors
Spindle / shaft or mixer bowl?
if you say the motor is running but no blades moves in the cup.it means the shaft which is connected to the blades and the motors break down.
so i refer u to open it and check which shaft part is broken,or take it to the mechanic.
Jan 05, 2014 | KitchenAid KFP740 Food Processor
The motor post on my food processor has deteriorated to the point my blades will no longer turn (just sit there)Can I replace that part ?Or is it too hard for an amature fix it upper?Is that post even...
If the motor is running, the problem can be that the motor shaft is spinning inside the drive sleeve. Replace the sleeve. That is more common than a motor failure.
Nov 30, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Motor works but blade does not spin. When I press down the glass while motor is running, it will spin a tiny bit but then stops.
check the interlocking part on the bottom of the blade piece. This part can wear down and then not interlock properly therefore it does not spin anymore. You can buy a new one from the website but it costs $30 and it comes with a bunch of other stuff. It's called the deluxe upgrade kit.
http://www.buythebullet.com/
May 11, 2010 | As Seen On TV Magic Bullet Food Processor
Jun 16, 2007 | Cuisinart DLC-5 Food Processor
Food Processors Logo
103 people viewed this question
Top Food Processors Experts
eyecam
Are you a Food Processor Expert? Answer questions, earn points and help others
