Question about Refrigerators
Hisense fridge hr6bmff520 error code ef - Refrigerators
Hello Philippa here, I have resolved my problem. Thank you
Hello and thank you. My Hisense fridge HR6BMFF520 alarm sounds when I open door. Display shows -88. It is not very cold inside. Regards, Philippa.
So how did you fix it? Thanks for letting us know. All posts about the same post are better done by COMMENT under the posters name :>)
Nov 15, 2016 | Refrigerators
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
WHATS CODE ERROR EF RF
Clean the condenser at back of the fridge , it could be cloged with dart or something is blocking it eg paper or its too close to the wall such that cooling in condeser is not effective
Aug 09, 2015 | Refrigerators
My refrigerator is not keeping temp and there is a code on the water/ice machine reads S(or 5)y EF. What does this code indicate?
If I'm not mistaken EF error code stands for Evaporator Fan which is the fan motor in the back of the freezer section. That would explain the noise you heard. The fan could possibly be frozen or stuck or the motor actually went bad and needs replaced. Without that fan running you will get very little cooling.
Apr 15, 2015 | Refrigerators
What does a Ef code on a Electrolux fridge mean? We have replaced the control board and the evaporator fan motor.
Hi Valmon Va, I appreciate your post!
I see that your Electrolux refrigerator is displaying the error code "EF" and you have replaced multiple parts. "EF" stands for evaporator fan circuit failure this could be a possible problem with the control board, evaporator fan, or wiring between each component. I would suggest consulting with a professional technician for a diagnosis because they have available tools to review each component and assure proper voltage to each piece. I hope this is helpful. -Matt
Dec 04, 2014 | Electrolux Refrigerators
What does the error code 5y EF mean on my Frigidaire refrigerator
Good Morning Friend,
I understand you are receiving an "SY EF" code on your Frigidaire refrigerator, model# FRS3R5EMB. The "SY EF" code stands for system error with the evaporator fan. This possibly means that there is something going on with your evaporator fan or it could possibly be a false error code. . I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FRS3R5EMB Side by Side...
I have an error code "EF" for my Electrolux
Generally, EF error is showed with an additional number on your display... EF 1, EF 2, EF 3, EF 5, EF8, or EBF.
Each error code will depict a different cause and solution. Out of these solutions, the most common is the control board and possibly the UIB (User Interface Board), or too higher mains voltage coming into the house, causing damage in this UIB device.
Test and check voltage, if this isnt solve it, relace UIB device.
Hope this helps.
Mar 05, 2012 | Electrolux EW1200i Front Load Washer /...
Recently bought a samsung rl38sbsw fridge freezer it worked or 24hour Then side got really warm is this normal?
new new code...
5a 01..
3F 32 37 03 D0 73 84 84...
C6 64 1D EF 47 5A 0E EF.......18.55PM
Nov 18, 2008 | Refrigerators
Refrigerators Logo
211 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
