Question about Building Materials
When I try and open with the remote or the wall consol the light just flashes and the door does not open?
SOURCE: flashing green light on Sears garage door wall opener HBW0777 1/2
Same problem - The flashing wall button indicates the remotes are locked out. I fixed mine by pushing the green button on the back of the opener. I did nothing else , just left the LED time out.
Posted on Dec 13, 2008
  • 247 Answers
SOURCE: OLDER SEARS GARAGE DOOR OPENER WONT OPEN GREEN LIGHT FLASHING
do you have the sensors at the bottom of the door? if so they might be out of alignment. all you have to do line them up by getting the green light solid. let me know if this helps you.
Posted on Dec 18, 2008
  • 905 Answers
SOURCE: Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Posted on Dec 29, 2008
ktkodama
  • 37 Answers
SOURCE: Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Posted on Dec 30, 2008
  • 3197 Answers
SOURCE: Garage door opener remote won't work
meerkat1 your receiver has quit working which is part of the logic board. The logic board runs around $80.00 for the part alone. Might be time to get a new opener.
Posted on May 12, 2009
The wall control unit is flashing but it will close and open the garage door, but when I press the remote from the car the light flashes twice and it will not shut the door.
You may have 2 problems here. First press and hold the lock button on the wall control for 3 seconds. This should stop that flashing and your remotes should work. If the main light is flashing when you try to close the door you need to check that your door sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little.
Mar 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Lift Master remote does not work. The wall mounted unit will open and close the door, but the remote control does not. I've changed the battery with a 1a battery from Radio Shack- but it still won't...
Check the wall console. If it has a lock button and the LED is flashing, the GDO is locked. None of the remotes will work, only the wall button. If it is locked, press the lock button and hold for a couple seconds and release. The LED should stop flashing, and the remotes should start to work.
If the door will open but not close, and the lights flash 5 times, check the door sensors. Make sure the sensors are aligned with each other, and the LEDs are both on.
Jan 11, 2011 | liftmaster 373lm Liftmaster Craftsman...
I have a door with two buttons and remote but only
On the wall control with the flashing light press and hold the button with the lock icon for 3 seconds and release.
Jan 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO - Remotes not working
I think this is an easier way to program. Press and hold the button on the remote and then press and immediately release the smart/learn button on the rear of the motor unit. Do this for each remote you have.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Apr 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage opener not responding with remotes, keyless pad, or wall console. Can hear it click but nothing happens. Green light in opener blinks 5 times. When i reset the green light stays on until i try to...
UNPLUG UNIT TO RESET.
IF IT STILL FLASHES 5 TIMES AND MOVES 6-8 INCHES REPLACE RPM SENSOR.
IF IT STILL FLASHES 5 TIMES AND DOESN'T MOVE REPLACE LOGIC BOARD.
Garage door opener will not work up or down,light is on.
take off console )disconnect wires). if remote works, get new console.
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
139 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
