Question about Grilling
SmokeshacK smoker will not heat and I don't believe it is the element
    Top Expert:
  • 12,128 Answers
Need tom test for power and the on switch and elements with a multi meter
Posted on Apr 16, 2017
Electric smoker won't heat up
yeah you could retro fit it and hope for the best..just dont leave it unattended in use..
Jan 11, 2014 | Bruce Foods Cajun Injector Creole Garlic...
I need a new electric heating element for my Little Chief smoker
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dsporting&field-keywords=Little+chief+replacement+element&rh=n%3A3375251%2Ck%3ALittle+chief+replacement+element Here is one source....
Jan 15, 2013 | Grilling
Masterbuilt eletric smoker: the control panel shows that it is working but the heating element inside the smoker is still cold, it will not heat up?
I have one that is 3 yrs old and just had the same problem. After reading other posts this is what I did. I removed the wood chip holder. This is accomplished by removing two phillips head screws from the holder on the right where it attaches to the inside wall. Then the are to small bolts that have to be removed where it attaches to the frame in the center. Now you should all of the heating element. Remove the two outer screws where it attaches to the back wall. Don't take out the center one, it attaches the ground wire on the other side. Tip the heating element up and gently pull it out, it won't come far and you should be able to see if one of the wires has burned through. The wire had burned off the right hand portion of the element in mine. To repair it you need to access it from the back. Take out the screws that hold the time/temp control on top. Drill out all the rivets from the back outside panel, remove the bottom screws from the drip pan holder, and pull the panel off. Towards the bottom you will see the back side of a small metal box that covers the heating element connections. Pull that box out. Get some blue or red rtv sealant from your local auto parts store Clean the area around where the element mounts on the inside, put some sealant on the mounting plate and remount it. This serves to make it water tight to help prevent corrosion inthe future. I chose the leave the connection cover off the backside. If you do that as well you might need to use small bolts to remount the element since the screws screw into that box. In order to remoun the element wire you will need a yellow male spade clip available at the auto parts store, home depot, etc. Strip about 3/8 in of the insulation of the burned wire, place it in the center of the spade clip and crimp the yellow part. Slide the clip onto the element end. Reattach the time/temp control, plug in the smoker and turn it on to see if it heats. You can lightly and quickly touch the element inside the smoker to check for heat, carefully of course so you don't get burned. Assuming it works, unplug everything, return to the back and use rtv sealant to completely cover the connections to the element. Wait for it to set up and recoat a 2nd time. Plug everything back in and do a 2 or 3 hour test run. If that goes well, apply rtv sealant to the back of the smoker and use #10 1/2in sheet metal screws to reattach the back. Good luck!
Sep 30, 2011 | Masterbuilt ESQ30B Smoker
Need a heating Element for a Master Build Digital Smokehouse Model# 20070106 Serial# GA040923
Since the - - -holes @ Masterbuilt told me they don't sell them, and after extensive seraches on the net, I found a company that is making me one for $37.50 plus shipping. (As of August 31, 2011)
Contact: david@hhelectricmfg.com and tell him you want to order a heating element identical to one he is making for Lelys. (The mountting plate may be a little different, but all you'll have to do is drill new holes in the new mounting plate.
Aug 29, 2011 | Masterbuilt 20070106 Electric Smoker
While using my Masterbuilt smoker (Model 20070106) the temperature began to gradually decrease and now it will not heat at all. I'm sure the heating element needs to be replaced but I am having...
SgtDave - Don't feel like the Lone Ranger. There have been a bunch of people seeking either the burner element and/or the electronic controls. The burner element is available form Appliance Factory Parts, but only with the smoker box. At one time is was sold separately, but now, the element by itself is no longer available. Even Masterbuilt no longer sells just the heating element. In part, if you check your Owner's Manual or the Manufacturer's Data Plate on the smoker, take note of the Country of Origin, you'll understand why.
Wish I could have been of more help to you.
Jul 11, 2011 | Masterbuilt 20070106 Electric Smoker
I'm getting power to my smoker but the heating element is not getting hot. What can I do?
Get a voltmeter or multi-tester, test power to the element. If there is power, then heating element is bad. If not power to the element, then temp sensor or control board may be bad.
Sep 06, 2010 | Masterbuilt 20070106 Electric Smoker
My heating element is not working. How can I get a replacement.
I experienced the same problem. My heating element was not working. After a Continuity Test, the Heating Coil was dead and needs replacement. I asked Masterbuilt if any heating coil replacement parts were available. They said "no", but they could offer a discounted sale on a new Smoker for about $175.00. I am still looking. A local appliance dealer said the internet was the most likely place to find one. After looking on the internet, I can't seem to find one yet. If you know of any, please let me know. Call (616) 772-1332 and ask for Bob. Thanks
Jul 10, 2010 | Masterbuilt 20070106 Electric Smoker
Heating Element Failure
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Apr 03, 2010 | Masterbuilt 20070106 Electric Smoker
My Masterbuilt electric smoker stopped heating will cooking
Mike in Alaska
PSU313@yahoo.com
Jan 24, 2010 | Masterbuilt 20070206 Smoker
The heating element does not operate -doesn't heat
How true: I love this smoker but until the heating element doesn't work. I am on my 3rd one now. Each have had the heating element go out. Luckily the 1st 2 smokers I took back to where I purchased them and they "Cabalas" gave me a new one "NO questions asked". Now I have this 3rd smoker. Guess what! Not heating again. I decided to take this thing apart myself and investigate the problem. Since the unit is all sealed I need a Drill, dremal cutting tool to open up the backside to get at the heating element and wiring. What I found was that the CONNECTOR to the heating element was BURNED up. All wiring was fine! I believe MasterBuilt is not putting in a high enough temp connector and also the connector looks to me of dissimilar metal which will cause metal breakdown when heated. I then went to Ace Hardware and found some High temp connectors and replaced the originals. All working now!
My friend has the same smoker with the same problem ... He called Masterbuilt and got the song and dance and how much it would cost to fix - so went out and purchased a Different Brand. Knowing that I had fixed my smoker I ask him if I could take his apart .... Well and behold ..... It had the same CONNECTOR problem. I wish I had my 1st 2 smokers back to check those out also. But my theory is that they also had the same problem.
Here is 1 more problem I have seen with this Smoker ... I store my smoker on my deck all seasons (covered up when not in use). During the winter when it is cold out my smoker control panel will not come on. It always works when it was warm out. So what I have found is if I take the control panel off and bring it inside to warm up .... Then reinstall it all works fine! My theory is that the control panel has a liquid crystal that is freezing causing it not to work.
Sep 11, 2009 | Masterbuilt 20070106 Electric Smoker
Grilling Logo
83 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
