Question about GE Profile JTP56 Electric Double Oven
I am getting a F7 error code and it will not stop beeping
Http://www.fixya.com/howto/h155060-dreaded_f7_error
Posted on Jul 26, 2009
    Scholar:
  • 30 Answers
I like ovens, they make cookies. Fix the probelm, don't replace it with another of the same problem. Try this, it's gonna work! First of all, turn off the circuit breaker. Don't replace anything. The insulation in the ribbon cable is poor. The conductors in the cable are crossed. The ribbon cable is actually two ribbons pressed together, and the conductors between the two cables are shorting or becomming crossed. Lift the two cables apart, place a piece of paper between them, fold the edges of the paper over the cable so that it does not slip out, and make sure to shove it all the way down to where it will meet the plastic display panel housing. Turn the breaker back on. There, problem solved.
Posted on Nov 24, 2009
    Guru:
  • 310 Answers
Either a stuck key on the keypad or problem with the controller.
If you can remove power, unplug keypad, then power on ... if error comes back after a few minutes it is the control board, otherwise a stuck key and you need to replace the keypad.
Regards,
www.fixyourboard.com
Posted on Jul 25, 2009
The General Electric under the counter oven is beeping and only stops when I push the Clear/Off button. Then it resumes beeping 1-2 minutes later. Also "F7" appears to the left of the time...
The F7 error code means that a key on the touchpad has shorted and the touchpad needs to be replaced... sometimes it's a electronic anaomily, since you have pushed Clear/off and the F7 returns it surly means that touchpad is bad.
GENE
Sep 09, 2011 | General Electric Ovens
GE Oven Model # JRS04B0W3BB is showing an F7 code, how do I fix it? I can stop the beeping noise by pushing the stop button, but the beeping returns after about 30 minutes. I have pulled the breaker for...
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE 24" Built-In Single Electric Wall Oven
Our JTP15 beeps and displays F7 is there a reset for it?
Yes, you will need to press the stop/cancel button, this will clear the error code and the display.
Nov 14, 2009 | GE JTP15 Electric Single Oven
F7 beeping an cannot stop it... any solutions?
HI, if this error code cannot be canceled, this will confirm a touch pad issue. the membrane is damaged and, this will require you to replace the ERC.
Replacing the Electronic oven control will fix this issue.
Mar 29, 2009 | GE JKS05 Electric Single Oven
F7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Nov 17, 2008 | GE JKP45 Electric Double Oven
DCS over F7 error beeping
KEYPAD BUTTONS ARE REMAINING CLOSED FOR MORE THAN 32 SECONDS. REPLACE KEY PAD,DUE TO STERCHED PANEL MEMBRANE
Jul 25, 2008 | DCS WO-130 Stainless Steel Electric Single...
F1 Error Code
According to the GE website, F1 usually means a problem with the keypad. You might try my solution for the F7 problem which is similar in nature. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my solution with more than 1900 folks and most report success.
Please let me know if it works for you at:
hutchipop@yahoo.com
Good Luck,
Powerman
Jul 16, 2008 | Ovens
F7 error code
f-7 means either the touch pad is stuck or a relay on the control board is stuck. if the code came up while the oven was not being used then the touch pad is shorted. if it came up while in use then the controlboard is bad
Nov 22, 2007 | GE JGRP17 Gas Single Oven
GE Profile JTP56 Electric Double Oven Logo
664 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
