What symbol denotes the headlamp is on. I or 0? My battery is flat and I need to check this first. Thanks JOHN
    New Friend:
  • 124 Answers
1 is on
0 is off.
Basic binary
Posted on Apr 17, 2017
Massey ferguson 3213H mower, what symbol denotes the headlight is on, I or O. ? My battery is flat and I need to eliminate this question first. JOHN
I is on,,,
When you put the battery on charge (if you leave the terminals connected) you will see the correct switch position (with ignition on)...
Apr 16, 2017 | John Toys
2001 CHRYSLER TOWN AND COUNTRY SYMBOLS
Hi Ken, The battery symbol is indicating that there is a problem with the charging system. Check and make sure the belt is okay and if it is check the 'Alt' fuse in the fuse box. If that one is good check the fusible link and then the alternator. Regards John
Jan 26, 2013 | 2007 Toyota RAV4
I have a servis 1200rpm washing machine in my just-moved-in flat. I don't know the exact model of the washer, but it does not start. There is light above the symbols when i press them, but it still...
Methinks you could do with a manual- for now and later!
TO OBTAIN ONE (FROM ANYWHERE) YOU WILL NEED TO KNOW/FIND THE MODEL NUMBER AS IT IS CRITICAL- IF NOT ON THE FRONT TRY THE MANUFACTURER'S PANEL WHICH IS PROBABLY AT THE BACK, SORRY!
Now- unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 20, 2011 | Washing Machines
3 or 4 mins into any cycle, machine stops, symbol on front flashes ( symbol looks like a tap on it)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
Thanks and good luck,
John C
Sep 01, 2011 | Washing Machines
How can i change the region on my Philips DVP630 Help please
Turn On Player
Open Disk Tray (From Front Panel)
Using Remote Control Press 7 8 9 OK 0 (Zero)
( Number Will Appear On Screen Denoting Region)
Close Disk Tray
Player is Now Region Free
hope this helps
John
Jan 22, 2011 | Philips DVP630 DVD Player
Ofter i format my samsung b5702 . to signs shows on the screen: 1. a blow "E" on the top next to the signals. 2. a red sign " look like a microphone or a battery " next to the voice sign what boes it...
Hi
E denotes the EDGE network status.
If the E is surronded by box then it show the EDGE connection is active and if the only E is there the service is inactive
4e1eae6.jpg:I think you are talking about this symbol.
This denotes you have a new voice mail message.
Please view your voice mail this symbol will go off.
Thanx
Jul 28, 2010 | Cell Phones
Need to know how to retrieve the diagnostic codes on a 1989 nissan stanza
I have the 87 model,but the procedure should be the same. Its under the passengers seat. Had to remove my seat to access it.Turn the ignition on,with a flat-headed screwdriver turn the screw fully clockwise,and wait until you see several blinks. Two or three.Now turn the screw fully counter-clockwise,and read the blinks.The Red light denotes "!0), the yellow light denotes (1), so if the Red light blinks once,and the green light blinks twice, the code will be 12
May 20, 2010 | 1989 Nissan Stanza
Globesymbol display on my phone
If the globe symbol is displayed it denoted that your phone is using the active data connection..
Check whether you have any software that uses the internet is running, also try switchin off the phone and switching on the phone..
Press and hold the RED button continoisly so that the phone DATA connection gets disconnected..
Pease leave me comment,if you need any further assistance
OR please rate this solution
Thanks
Dec 20, 2009 | Cell Phones
What symbol is used when the battery needs to be recharged? Is it ok to recharge the battery before the symbol appears?
battery's life is governed on the number of recharges. so it is always recommended to recharge a battery only when it has been discharged completely. generally a blinking battery symbol denotes that the battery needs recharging.
Aug 07, 2009 | Olympus Stylus 710 Digital Camera
Huge files are not being retrieved
I would make sure that all filenames do not exceed 116 characters in length, and they contain only standard characters (A-Z and 0-9, not symbols like !@#$%^*))/|).
Sep 18, 2008 | Electronics - Others
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
