Question about Coffee Makers & Espresso Machines
My coffee maker is only about a month old. When i make a full pot 12cups it only gives me 10 cups of coffee. It is now starting to leak water from someplace.the taste has changed
  • 2039 Answers
SOURCE: Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Posted on Feb 14, 2009
skrbin
  • 121 Answers
SOURCE: Sunbeam 10 cup coffee maker starts and stops brewing spuradically
check water heater
Posted on Feb 16, 2009
cactus bob
  • 267 Answers
SOURCE: Coffee pot
durabrand has no contacts outside china this is a unit made for and imported for walmart only walmart is the only contact ...... your problem is not anything you or walmart can do anything about the problem is the cheap plastic that is used , when it gets hot some people can taste and smell it and others cant . .. its getting more common in everthing that heats water .. personaly i would not drink anything from an appliance that puts a plastic taste in my water ..... if you move up in price the problem is reduced , better plastics are used , but your not going to get one for 10.00 ! "you get what you pay for " more now than ever .... good luck Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 05, 2009
joe7379
  • 93 Answers
SOURCE: Vanishing water
Is this problem happening by chance after you have used the maker? If so the heat from the previous use may be causing the water to steam from being so hot and thus causing the pot to be only half full. the hotter the maker the more water evaporates. You might need to let it cool down in between pots.
Joe
Posted on May 19, 2009
  • 128 Answers
SOURCE: brewing time is too long 20 min for 6cups
You have an obstruction in the feed line to the heating element. I found coffee grounds before the check valve. I had to take the bottom off it which I am sure the manufacture wouldn't approve of but I was at my wits end and ready to toss it. I just brewed a full pot 10 minutes!!!
Posted on Aug 22, 2009
I love my Cuisinart 10 cup coffee maker, but I hate my pot. Every time I pour a cup of coffee the pot leaks. I have tried removing the lid and the pot still leaks. Please help I am getting tired of...
Be careful! The top will soon disconnect from the bottom! I've had the same problem for the last few months. This morning (11/19/10) the top of the pot seperated when I poured a cup of coffee and half a pot of piping hot coffee spilled down my right leg. I'm on hold with their customer service department as I type this. Has anybody else had the same issue?
Regards,
Harry B.
Nov 11, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
I put in 12 cups of water and only 4 cups come out with coffee what is wrong with this. It is only one month old
This occurs occasionally if the unit needs cleaning or you are brewing a new pot of coffee immediately after emptying a hot pot of coffee.
Run a cup of vinegar through the coffee maker twice, run at least 2 pots of clean water through to rinse the vinegar out.
This should clear the problem until it needs cleaning. The suggested frequency of cleaning is every 30 pots, but this varies depending upon the type of water you use.
Nov 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Brewing time is too long 20 min for 6cups
Aug 18, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DDC-2200 coffee maker problem: Sometimes the unit brews less cups than cups of water put into it. Then, after while, you get a brew that give 2 or 3 cups more than what was put into it. The...
Clean the pot by brewing a full pot of undiluted vinegar, then rinsing it by brewing 2 full pots of water through it. Also, change the charcoal filter on a regular basis. We clean the pot this way every month and replace the filter every 2 months.
Jul 18, 2009 | Cuisinart DCC-1200 Coffee Maker
Vanishing water
Joe
May 19, 2009 | Bunn 10 Cup Home Coffee Brewer
Coffee doesn't brew full pot
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Leaks at bottom
look for leaks up at the top by the top hinge.
mine leaks there. apparently a gasket is missing or just not tight enough.
you should see bubbles come out and see water go into the filter cone but some of it leaks down the inside (near the pot inside) and out the bottom of the maker and appears to be leakng from the bottorm.
Mar 23, 2008 | Cuisinart DCC-1200 Coffee Maker
More Steam Less Coffee
I had same problem after 4 months. very slow brew time, 10 cups of water poured in made about 6 cups of coffee. I used a packaged coffee pot cleaner powder and this fixed the problem (for now).
Dec 26, 2007 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
