Question about McCulloch Garden
I have a McCulloch M40-450c mower The engine starts but will not run I can make it run for a short time by pressing the bulb can you sugest a remady.
    Top Expert:
  • McCulloch Master
  • 12,744 Answers
Check filter and or need to rebuild or replace carburetor
Posted on Apr 16, 2017
Engine starts after primer bulb is pressed 5 or 6 times, but dies after running a few seconds.
Main jet in carb is clogged. Also check the fuel lines to carb and make sure that they are intact and have no leaks.
Jul 29, 2016 | Toro Recycler 22" 149cc Personal Pace Lawn...
Primer bulb collapsed
Slightly unscrew the gas cap and see it the problem goes away.
Many times the Gas tank Vent clogs and this will cause the engine to create a vacuum in the gas tank until the engine can't draw in the gas .
Jul 15, 2013 | Garden
I have a 4 month old mcculloch with a briggs and stratton 450c engine , it starts no probs but then starts to blow out black smoke
Hi, check your air filter, also check your oil level is not over full as it may have become diluted with fuel. Let me know. Regards Phil.
Aug 30, 2012 | Briggs & Stratton Briggs Stratton...
Engine runs fine than after about 10 min it starts to surge and than quits will start up after a short cool down but does the same in a short time Frank
This seems to work a lot.
As the engine starts to surge, loosen the fuel cap.
If the engine runs smoothly again, clean the vent holes on the cap.
Good Luck.
Gary
May 02, 2011 | Parks Optical 13.5hp Briggs And Stratton...
Can anyone help with fuel mix and starting instructions for McCulloch 2214av chainsaw please
Ok, always use good quaility teo stroke oil, from a manufacturer who actually produces a chainsaw, ie Husqvarna/Stihl/Jonsered etc, all of these oils should be run at 50-1, avoid oil makes you have never heard of.
Starting instructions are as follows, switch the red ignition switch too on ( up ) depress the primmer bulb as many times as it takes to 3/4 fill the bulb ( you cannot flood the engine if you over prime, it is better to over prime ) pull the blue choke fully out, crank the engine until it fires once ( it will only fire once, do not continue to crank the engine after it first fires with the choke still out ) now push the choke fully back in, crank the engine until it fires up and runs on fast idle,now blip the throttle trigger to diss engage the fast idle position, the saw should now drop down to idle.
Regards
Jan 31, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Briggs & stratton 35 classic mower.(mcculloch m3540p) starts rarely and only 4 a short time. Shows spark at plug fuel getting through air filter ceaned.(tried without air filter to no avail.checked...
With the air cleaner removed, see if the engine will run for even a short time when you give a couple of quick squirts of starter fluid into the carb.
If it runs with that, the orifices inside the carb are dirty and need the gunk cleaned out.
Before extended storage, always drain/use up all the gas in the tank and run the engine til the carb runs out of gas.
Sep 21, 2017 | Garden
I have a McCulloch 3516 chainsaw and need advice on how to adjust the carburator. It starts but runs for a short time and dies.
You say runs a short time, seconds or minutes ? Seconds could be carb setting, minutes could be fuel mix ratio. let me know.
Oct 17, 2009 | McCulloch Garden
Craftsman 7.0 HP Briggs & Stratton mower stalling
Check the muffler, if the muffler is clogged it could cause overheating of the engine, and could keep the engine from getting the necessary fuel-gas mixture.
Aug 09, 2009 | Garden
McCulloch Chain Saw Manual
Found all the mcculloch manuals you could ever want on mcculloch product information site. Its run by mcculloch an you put the product weather chainsaw or strimmer whatever an the type in the next collum an press download then print it off all very easy. My manual was in german so made up i found stumbled on this.
Jan 14, 2008 | McCulloch MC1275 Steam Vacuum
Garden Logo
37 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
