Question about Hardware & Accessories
I have a model 8100-9045-01 45 watt power pack. I can not get the timer to work. It was go on and off but can not set it to come on at 7pm and go off at 11:00pm. It did work but just stopped
SOURCE: My Malibu 200 Watt Power
There is no fuse and no repair parts
I've been all over the Malibulights.com website looking for anything that might help the large number of people with Malibu questions. The website has very little information and no parts and the site offers no help except the following:
1) Malibu gets the customer money, and other people troubleshoot for their customers
2) When buying a power pack, the total bulb wattage on the line has to match the power pack wattage
10 - 20 watt bulbs = 200 Watt power pack
15 -20 watt bulbs = 300 Watt power pack
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack.aspx
If your power pack is oversized, it will burn out the bulbs and burn out the power pack
3) A power pack makes a humming noise when it has power >>> check your power source if power pack won't work >>> no other troubleshooting is offered
4) Replace burned out bulbs ASAP or the power pack burns out the other bulbs
5) Unplug power pack when working on bulbs [otherwise, the power pack burns out which is why people write fixya asking why their power pack won't work after replacing all their bulbs]
6) Nowhere on the Malibu site does it offer-or-explain burned out power packs or power packs that don't work, but they show plenty of new products for you to buy.
Posted on Oct 19, 2010
SOURCE: how to troulbe shoot my 300-Watt Power Pack/Timer.
'Harry' wrote to me yesterday with handy malibu information.
1) Power packs come with 5 year limited warranty.
He is contacting Malibulights.com for a refund of some type.
Hope he writes back and says how that comes out.
2) He was having problem and plugged power pack into wall timer, then set timer.
Heh heh, pretty clever: Malibu transformer works, but timer doesn't, so plug power pack into a wall timer!!
That being said, I had same problem with my power pack.
I used blower to remove dirt and sprayed wd-40 and tried to take it apart.
My power pack was getting electricity.
Connections were good where lights tie into wire.
My lights never turned off.
Power pack doesn't come apart.
I turned it upside down thinking water got into timer.
I took it inside and let it warm up.
It still wouldn't work so bought another one.
Then I searched Intermatic and Malibulights.com for answer, but they have no troubleshooting or repair other than check electricity and check bulbs.
Conclusion: when power pack doesn't work, it is broken.
Unless you buy a separate timer and plug power pack into that timer as Harry suggests.
After researching power packs at Intermatic, Malubulights.com, ebay etc, the best I found were tips for next power pack that might save money:
The reason I add these tips now, before your power pack needs replacement is some fella wrote-in.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
Posted on Dec 04, 2010
SOURCE: How do I set my
Resourceful do-it-yourselfer will find following information helpful for solving problem.
Max Load 1000Watts incandescent
http://waterheatertimer.org/How-to-program-Hagar-timer.html#700-series
Manual uses several languages including English
http://waterheatertimer.org/pdf/Hager-EH711-Timer.pdf
Hagar 700 series analog timer has mechanical dial that rotates as time passes.
Segments located on outer edge of dial are moved down-and-out, or up-and-inward to set on-off times.
As dial rotates, segments move lever that turns Load on-off.
With segment timers, all consecutive segments between on and off times have to be pushed in place.
Since EH700 series timer has NO NC terminals, segment position is determined by how timer was wired.
This is because segments-in and segments-out turn different terminals ON.
As a result, the best way to set this timer is to push 10 consecutive segments down-and-out.
Leave rest of segments up-and-inward.
Then manually rotate timer dial to watch when Load turns on-off.
Hagar analog timers also have a switch located in bottom right.
This is the manual override switch.
Set switch in position "I" and then rotate timer dial to watch when Load turns of-off.
Set switch in position "O" and then rotate timer dial again to watch when Load turns of-off.
Manually rotating dial and experimenting with segments and switch will tell resourceful do-it-yourselfer exactly how to set timer.
Once segments and switch are set, then rotate timer hands until current time shows on analog dial face.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 18, 2011
SOURCE: How to set Hager timer
Hagar EH711 is surface-mount analog timer with segments located around timer dial.
Timer has 2-position slide switch with I and O.
Timer has NO and NC wiring terminals, and I O switch reverses terminals.
Timer dial can be rotated by moving minute hand clockwise with finger
Open following link for instructions that illustrate how to set analog timers by experimenting with features.
http://waterheatertimer.org/How-to-set-timers.html
Open following link to see Hagar analog and digital timers with illustrations and manuals:
http://waterheatertimer.org/Hagar-timers-and-manuals.html#700-series
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
Posted on Sep 07, 2011
SOURCE: Describe your Inc. ML121RT Malibu
If clock has slowed down or is running reversed or gets stuck on the tripper, then clock motor has gone bad.
There are no replacement clock modules for this product, but product comes with warranty.
Work-around: Buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer:
Resources: including warranty links, tips, trippers, etc:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Posted on Sep 11, 2011
I purchase a Malibu ML600TW. My quest is. In this unit are there 2 separate 300 watt transformer. or when you contact the line in you are wiring to 600 watts.
With the 600 watt ML series, there are two sets of a-b-c terminals. C terminals are used with photo eye.
Connect 300 watts of bulbs to one set a-b terminals, connect 300 watts to other set of a-b terminals.
I'm not sure what is inside the power pack. However if you run less than or more than 600 watts or let your bulbs burn out for any length of time, the power pack can burn out. Save your receipt for limited 5-year warranty.
For your benefit, open following link for more information on ML power packs, plus troubleshoot, plus tips to keep power pack from burning out, and links to trippers:
Upvote the help.
May 24, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
Timer clock not working. can it be replaced?
You posted under malibu power pack.
Power packs do not have repair parts.
Occasionally folks write fixya saying they took power pack apart, but nobody reports repairing transformer or timer.
'Harry' wrote fixya with helpful information.
His timer stopped working so he bought cheap plug-in timer, set power pack to override, and then plugged power pack into cheap timer.
Harry said his power pack has 5 year warranty and he was negotiating with Malibulights.com for replacement. No word how that came out.
Best I found are tips for next power pack that might save money:
The reason I add tips now, before power pack needs replacement is some fella wrote fixya.
a) Match wattage of bulbs with wattage of power pack
Lets say you have fifteen 20 watt bulbs = 300 watts, so install 300Watt power pack
b) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
c) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
d) When working on bulbs, unplug power pack or power pack may burn out.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 19, 2011 | Malibu ML200RT - Low Voltage Power Pack...
I have a Malibu 200 watt transformer with timer and I'm not sure why the timer is not working. Is there an instruction manual on line that I can read to see what I should do?
Malibulights.com has manuals.
http://malibulights.com/customer_service/owners_manuals.aspx
People post malibu questions on Fixya each day.
Some people report being able to take apart power pack and timers, but nobody reports being able to fix power pack once it stops functioning.
If you can get manual override to turn lights on, 'Harry' wrote to fixya with some help.
Harry also said his power pack has 5 year warranty and he was negotiating with Malibulights.com for replacement. No word how that came out.
There are no parts for power packs.
The reason I add tips now, before your power pack needs replacement is some fella wrote fixya.
Feb 17, 2011 | Malibu ML200RTW - Low Voltage Power Pack...
I have model ml600twsn 600 watt intermatic timer for my outdoor lights.Recently I have been unable to set them to turn off an on automatically. I can manually. what should I do?
You have malibu-type low-voltage transformer.
There are no repair parts for this type of timer, and nobody reports being able to fix timer once it goes bad.
1) "Harry" wrote to fixya with a work-around: He bought cheap plug-in timer, set malibu timer on override, and plugged malibu into wall timer.
2) Harry also said that his timer has 5 year warranty, and he was negotiating for replacement.
Contact Intermatic:
http://www.intermatic.com/customer%20service.aspx
3) Buy another timer:
http://www.amazon.com/Malibu-Intermatic-600watt-Professional-Transformer/dp/B000PGPO50
4) I found tips for next power pack that might save money:
d) When working on bulbs, unplug power pack or it may burn out.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 27, 2011 | Garden
After a power outage how to reset timer correctly
You posted under Intermatic or Malibu power packs:
Different brands and models re-set differently.
For full information on Intermatic/Malibu power packs showing links to Malibu and Intermatic manuals, plus troubleshooting, and trippers and tips:
Oct 23, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Apparently the motor is working but the timer is not running
These dang power packs don't have replacement parts. You can see if the manual override turns lights on and off. The power pack makes a humming noise. If the timer is not rotating, then try setting the current time.
Malibu manuals are located on this page
Normal 0 false false false MicrosoftInternetExplorer4 http://www.malibulights.com/customer_service/owners_manuals.aspx
If you buy another one, be sure to match up total wattage of bulbs to the power pack wattage.
For example 10 - 20 watt bulbs = 200 Watts >> you should buy 200 Watt power pack
15 - 20 watt bulbs = 300 Watt power pack
Oversized power pack will burn out the bulbs
Also if you let bulbs burn out, it will shorten life of power pack
Unplug the power pack when working on the bulbs
Oct 17, 2010 | Malibu ML200RT - Low Voltage Power Pack...
THE TIMER DOES NOT WORK , NEED TO REPLACE IT WHERE IS THE PART LIST FOR ML600TW MALIBU ANTS GOT INTO THE DIAL TRY TO CLEAN IT OUT APPENRENTLY BURN UP THE MOTOR IN THE TIMER LIGHTS OR ON ALL THE TIME.WORKS...
I've done a lot of reading and research on Malibu
No replacement parts for Power pack, or schematic >> Malibulights.com shows replacement lights and replacement power packs
Manual for Malibu 600 Watt power pack
SAVE the pins off old power pack and see if they match pins on new power pack ... because you can't find pins on the internet
When the power pack goes bad or you lose the pins, then you buy another power pack
Things to remember:
Match number of lights to power pack wattage
30 - 20 Watt bulbs => 30 x 20 = 600 Watt power pack
Replace bulbs as soon as they burn out, or other bulbs will burn out quickly, and I think it causes power pack to burn out sooner too.
Up-vote if this helped. Thanks for the feedback.
Oct 13, 2010 | Malibu Intermatic Inc. ML121RT Low...
I need instructions for setting the timer
Malibu product manuals
Manual for 300 Watt power pack
http://malibulights.com/docs/pdf/8100-9300-01.pdf
Read cautions
Tips
300 Watt power pack requires sum of bulbs to equal 300 Watts
If you use 10 - 20 watt bulbs that is only 200 Watts so you need 200 Watt power pack
Replace burnt out bulbs immediately or other bulbs will burn out and shorten life of power pack
When working on bulbs, unplug power pack so it does not shorten life of power pack
Set Malibu Timer:
Red trippers are ON
Black trippers are OFF
Place trippers on dial at ON OFF times/ AM and PM
Set current time of day:
Plug in power pack
Trippers are installed
Rotate dial counter-clockwise to current time, say 9 am
Rotate dial 2 more revolutions and then return to current time
That's it
Oct 12, 2010 | Intermatic Malibu 300W Power Pack...
Just as someone else wrote, I too have the Malibu light timer and have the blue & red pegs set to turn on (red peg) at 7pm and off (black peg) at 11pm. The lights will not automatically turn on...I...
The clock motor has gotten weak and is now overheating, and will soon stop turning. There are no replacement clock motors for ML series power packs.
Open following for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
Nov 09, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
