Question about The Computers & Internet
My external hard disk was working well before but now when it is connected to the computer and you open disk management it shows that it is Unknown and not innitialized
    Top Expert:
  • The Master
  • 75,066 Answers
The hard drive has failed.
Posted on Apr 17, 2017
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: My external hard disk was
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Posted on May 27, 2011
Tip
Using Windows Disk Management Utility to Manage Internal and External Disks
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
The Disk Management utility can be accessed in two different ways.
#1- You can open the Control Panel,
Click on Administrative Tools,
Click on Computer Management and the Computer Management window will open.
#2- Right click on you “My Computer” Icon
A menu will open
Chose “Manage”
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a “Drive” and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show “healthy”)
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter “C”.) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters “F” or “G”. In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
on Jan 29, 2010 | Computers & Internet
External hard drive data shows not initialized
Download a free copy of either Hiren's BootCD or Kasperski Rescue Disk, using a different computer. Then boot to the OS on that home made disc. You should be able to browse to your files and save them to another drive, such as a flash drive or a USB connected hard drive.
Apr 25, 2017 | Western Digital My Passport Essential SE...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
My external hard disc moder no : TS80GSJ25S shows there is no disc in your drive
If you have used this drive before then the drive is malfunctioning and my need to be formatted. If not, then the disk could need initializing and then formatting. You can check the status of the disk using the windows disk management utility. The directions to use this utility are shown below, If the disk does not appear in the manage disks section, check the connection to the computer, and try to power cycle the drive by unplugging it, waiting for about 20 seconds and then plugging it back in. This may renew the connection and restart the drive.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments. Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
Jan 09, 2011 | Transcend StoreJet USB 2.0 External Drive...
I have an external hard drive made by Gigaware. When plugging it in, the computer recognizes it as mass storage device but will not show up in My Computer. The external drive is on and spinning. Any...
If you have not used the external hard drive before, you will have to go into your drive management and initialize your drive and possibly format it. The fact that your computer recognizes it is a good sign. It means that the external drive is working properly and the computer recognizes that the external drive is there. I have an short paper I have written describing how to use the drive management utility in windows. It is too long to post here. I can either post part of it or you can give me your email and I will send it as a MS word attachment so you can have the entire paper.
I hope you find this helpful Brian
Here is the part I can post here:
Using Disk Management Utility
A menu will open
Chose "Manage"
Dec 25, 2010 | Computers & Internet
My western digital dosent get detected, whenever i connect the device a new hardware found sound comes and nothing comes in my computer, i tried restarting nd olso tried to connect the device on other...
sometimes drives need to be initiallized when they are connected I will give you instructions to use the Manage Feature of windows to manage your drives. The instructions are as below:
If you cannot see the drive using the disk management utility, then you need to check to be sure the drive is not malfunctioning and also check your connection cable to be sure it is not the problem.
I hope this is helpful!!
Brian
#2- Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
Dec 23, 2010 | Western Digital 320GB MyBook External USB...
Maxtor external HDD not detected by Vista
try to format it.it might need a quick format for you to use it. if still doesnt work check for the sata,pata cable that connects your motherboard.
Apr 30, 2009 | Maxtor Hard Drive
I reformatted my C: drive and ever since Windows will not recognize my Seagate External Free Agent hard drive. It shows up under ?My Computer? as Removable Disk (I: )? It used to be listed as Seagate...
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Jan 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Dec 30, 2008 | Seagate FreeAgent Pro 1TB External USB...
Computers & Internet Logo
55 people viewed this question
Top The Computers & Internet Experts
tim brauer
tim brauer
Dilum Senarath
Dilum Senarath
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
