I need reparation simple tech 320 - Computers & Internet
3 Suggested Answers
  • 8 Answers
SOURCE: simple tech mini 320 gb external hard drive
You might need to initialize the drive.
Right click on “My Computer” or “Computer” on Vista.
Select “Manage”
On the next screen select “Disk Management”
In the lower middle section you should be able to find your drive.
It will show up as Disk 1 or Disk 2….depending on how many drives you have in your computer.
If you click on the area that says Disk # you should get and option to “initialize drive”.
Also to the right it should show the allocation information for the drive. If it says “unallocated” then the drive needs to be partitioned.
Right click on the white box next to the drive listing.
Select the option “New Partition”
This will bring up the partition wizard and you will need to step through this process.
Select a primary partition.
On the next screen accept the maximum size it will provide.
On the next screen you assign a drive letter.
On the next screen you will do the format and accept the default settings.
The formatting will start and will be busy until it is complete.
You can monitor this from the disk management window.
Posted on Jun 05, 2008
  • 224 Answers
SOURCE: simple tech 320 gb not spinning
Try a new usb cable or a different usb enclosure.
Also try and remove the drive from it's enclosure and connect direct to a sata port on a desktop pc.
Posted on Aug 23, 2012
How do I fix a broken port on my LaCie 320 gb hard drive that won't connect to the info?
It's really quite a simple fix... Simply disassemble the drive casing, and remove the hard drive itself, it's actually quite simple. Then install the hard drive into another, replacement external case - they are available at electronics retailers, computer stores, The best deals are found online at locations such as Amazon, eBay, or
Jun 01, 2014 | LaCie (301151U) 320 GB USB Hard Drive
Simple tech 320 gb not spinning
Aug 23, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
My Simple Tech 320 GB Hard Drive fell off my chair, it makes a "searching noise" but doesn't show up in My Computer....are these repairable
Well the drive is finished, but you can still take it to a computer shop who can open the casing and pop in a new 2.5inch drive, it will cost you less than buying a new one.
Jun 03, 2011 | SimpleTech Computers & Internet
I have a 320 Simple Tech 320GB with nothing on it and am trying to do a back-up 87 GB in size and it keeps telling me I do not have enough room?
Hello, thanks for using FIXYA,
have you had try to format the external drive, do that then try to copy again.
Let me know if that works
Rate this solution please
May 27, 2011 | SimpleTech Signature Mini 320GB External...
SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue: HELP. I have simlple tech 320 external hardirve. M...
Were you using this on a PC? it may be using Fat or NTFS. If it's seeing the drive and you can't use it, it may be the filing system, I believe macs use a different one than PC's. I would copy the files "if possible" to another flash drive or computer and just re format the 320 gig drive, the mac will install the right filing system for the drive and it should be good to go.
May 16, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Brake lights are stuck on all the time. 320 2002 Mercedes
You have a simple plunger switch on the brake pedal. This can be lubricated or replaced. Simple job.
Nov 30, 2009 | 2007 Mercedes-Benz ML320 CDI
Simple tech drive
Using this program
Its worked perfectly on my 300GB usb drive, my PS3 can see it just fine
Oh and it works on vista as thats what i did it on..
Aug 01, 2009 | SimpleTech 320GB SimpleDrive External by...
Codes for Dish network
Jan 20, 2009 | Initial DTV-321 32 in. LCD Television
Simple tech mini 320 gb external hard drive
It mostly comes with 3 years of warranty but you cant utilise warranty just for being "not recognized".
Try to trouble shoot the problem by using the technical suppport offered for the item
Apr 12, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
