Question about Ovens
How can you remove burnt plastic from electric hob oven
  • Heather Petty
    Heather Petty Apr 16, 2017
    Hi gary oneill, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • 3,828 Answers
From the ceramic or glass cook top
will be a slow process cant scratch the top
hope its not tuppa ware
it will smoke
plastic scraper or solid plastic spatula
with hob off .. boiling water little at a time
may have to low heat the hob again
how can you remove burnt plastic from electric hob - index-y2awcuzjynizse3421uzf4yu-5-0.jpg
Posted on Apr 16, 2017
Hi ive purchased a zanussi gas hob & electric grill and oven my installer wanted to knw what amp and wire to use to connect the oven nothing is stated in the manual model no ZOF35511XK
The necessary data for your installer is on
the rating plate. The rating plate is on the back side on oven and on the bottom side on hob. Never remove
the rating plate from the appliance cavity.
Make sure that the electrical information on
the rating plate agrees with the power
supply. If not, contact an electrician
All electrical connections should be made by
a qualified electrician.
The appliance must be earthed.
Sep 10, 2014 | Zanussi Ovens
My glass cermamic cooktop is burned, i mean literally. Its milk stains or sauce stains all over it. And i cant remove it. There are dark brown stains on it. Please help me
try using a ceramic hob specific scraper to removed the burnt on bits then use a ceramic hob cleaner.
Can you let me know what country you are in and I can send you alternative links.
The following link are for the uk.
311299 is the most cost effective as it contains cleaner and scraper.
Aug 21, 2010 | Ovens
Is this oven suitable to have a Induction Hob
Provided there is a space between the top of the oven and the hob, it should present no problem.
You will of course need a seperate plug outlet for hob
May 21, 2010 | Neff B1421 Electric Single Oven
I have dropped a cup onto my ceramic Zanussi hob, is the slither of glass that came off able to be repaired ??
Just to clarify something, is your hob above a double oven D2100-4 because that is only telling me about your oven the hob will have its own Mod. no. But any crack to the glass on any Hob can weaken the glass and really should not be used due to the weight of Pots on glass if the glass did break it could be quite dangerous with all the electrics below.
Hope this gives you some help in the matter.
Good Luck.
May 06, 2010 | AEG D2100-4 Electric Double Oven
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
Complete power loss to Hotpoint electric oven
You need to ascertain that the oven is actually getting power.To do this, you are going to have to remove it from the housing and remove the terminal cover where the the cable comes in, and check for power there.
You may find that the terminal block has charred due to a bad connection and the wire has burnt away
If this o/k, and you are getting voltage there, then the problem is obviously within the oven itself, could be a timer fault.
If you have no voltage at terminal block, then the problem is between the terminal block and the main switch.
Hope this helps with your problem.
Dec 03, 2009 | Hotpoint Ovens
My Delongi dsf905 oven stopped working
Nov 29, 2009 | Ovens
I can't get a low flame on my lpg hob. The flame isn't outrageously huge so I think the hob is converted for lpg. But I can never get anything on a simmer, even with simmer mats over the flames. ...
If you remove control knobs you should find a hole where screwdriver can be inserted to adjust the flame failing this ensure correct injectors were installed when converted to lpg
Jul 13, 2009 | Ovens
Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Jun 01, 2009 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
