Primare SPA 21 wont power on. I flip the switch on the bottom of it and it makes a click sounds inside but then nothing comes on the screen. I tried another power cable and its exactly the same.
    Top Expert:
  • Televison & ... Master
  • 74,999 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Apr 16, 2017
Testimonial: "I unplugged the power cable and turned the power switch off and on several times then plugged the power back in and it turned on. This happened before, i switched it off and back on and it came on. Any chance its something like the switch contacts are dirty or something rather than the board being screwed?"
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 28, 2014 | Philips 42PFL3704D LCD TV
Wire t104r
look at inside cover for wiring line is voltage coming in and load goes to pump
Aug 06, 2013 | Intermatic T101P3 Pool Timer IndoorOutdoor...
Unable to turn on
First, make sure the circuit breaker is on and there is power to the motor.
If you have power to the motor it may be that the air switch on the motor is not working and needs to be changed.
The air switch is around $21 to replace.
Rod @ US Parts Center
May 06, 2013 | AO Smith Pool & Spa
if the clicking sound comes from the solenoid when you try to start the engine the solenoid may need replacing, the solenoid is like a big switch that takes the power from the battery to the starter motor,inside it there contacts that come together to make contact & that is where the problem is.....hope this helps.....cheers
Jul 18, 2010 | 1996 BMW 318
Pool motor makes a buzzing sound but doesn't work
sounds like it has a bad capictor .. look fr a otor shop in your area that tsts them , should be free test
May 30, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Nothing happens when we flip the switch, though the pilot light is on.
is the gas valve turned to ON position?try to jump the top and bottom screws on the gas valve, there are 3 in a row there inside the bottom door on valve. use a small wire to jump it no risk of shock its milivolts and you wont even feel it. if unit lights you have a swich problem or wire problem
Oct 01, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Lens wont open cannot take photos
You have the camera in REVIEW mode... your model either has a a switch on the rear panel to select taking photos OR reviewing. Or it may have a button, but it sounds like yours has the swith type...just flip the switch to the opposite direction and try it... the lens should act normally and allow photos to be taken...LET me know what you find out..
Apr 20, 2009 | Canon PowerShot A520 Digital Camera
Primare A30.2 power amp has suddenly stopped working. Was playing OK, then after about half hour of non use (still powered up) it clicked and the green light went off. Both fuses (mains plug and in the...
Check for the fuses inside the machine, replace only with same ratings! Make sure there's no shortcircuit at the speaker output terminals. Have it checked out by your local dealer if you are in doubt.
Oct 08, 2008 | Audio Players & Recorders
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
