Question about Dishwashers
Hi red tap light keeps coming on When filling drains ok at the start, side panel removed and can see it's only using pipe 4 to fill and pipe 5 stays full of water dishwasher is new
SOURCE: dishwasher won't drain
Can you kindly help me?
Posted on May 17, 2008
SOURCE: Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Posted on Jun 05, 2008
  • 409 Answers
SOURCE: bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Posted on Sep 25, 2008
fphandyworks
  • 56 Answers
SOURCE: BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Posted on Jan 05, 2009
  • 234 Answers
SOURCE: Dishwasher does not fill with water when started. Problem began slowly with dishes not rinsing completely. Overfill float appears to work properly. Water fills pipe leading to fill solenoid but does n
I am almost certain that your problem is the fill solenoid.
If it does not work, there will be no water entering your machine.
I would either remove it and test it or just replace it at this point.
Tim
Posted on Apr 16, 2009
MieleG870sc I can hear the motor, but water does not seem to be coming in and after cycle ended, soap tablet was unused?
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Mar 01, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
My g595sc miele dishwasher after about 2-3 minutes of working come to stop with the "WATER INLET" light on. Please help.
Jan 22, 2010 | Dishwashers
Hi, i have a mieled/w g1. it give a code of f13 which is inlet but i dnt think the waters getting thro the electonic non r/ valve
Jan 14, 2010 | Miele G880 Dishwasher
Our MIELE TURBOTHERMIC shows a red indicator light on the topic of: drain/watersupply.when switched off and restarted, it evacuates the water succesfully and commences the cycle but then after two minutes,...
Dec 26, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
E1 error code on my kenwood dishwasher [kwd243a
Hi
The E1error code indicates a water inlet error.
To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
If inlet valve has tested OK ie machine filled with water in test mode then:
Disconnect from power.
Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
- Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
- If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
- If you still have problem, then control board is faulty, it is much more likely to be flow meter .
Thanks for contacting fixya.com
Sep 10, 2009 | Dishwashers
I have a hot point aquarius wf321 and it wont come out of the last spin cycle it just keeps filling up with water and keeps going been doing this for the last 8 hours
it may be sucked out by siphoning through your sewer pipe .Probably a siphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from coming out the drain pipe , go to home depot or an appliance parts house , and get a siphon break . When a washer fills , but water level doesn't rise in the machine , it must be going down the drain
Aug 25, 2009 | Washing Machines
Machine fills and keeps filling and never goes to agitate. just fills. If you skip it ahead it will only go to rinse and spin.
Probably a siphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from coming out the drain pipe , go to home depot or an appliance parts house , and get a siphon break . When a washer fills , but water level doesn't rise in the machine , it's being sucked out by siphoning through your sewer pipe .
Aug 15, 2009 | Washing Machines
E1 error code
Fault is 1E- this indicates a water inlet error.
- If you still have problem, then control board is faulty, but in my experience it is much more likely to be flow meter
Aug 05, 2009 | LG Dishwashers
Whirlpool washer awm 6163
ckd for drain hose to low ..top needs to be 30-38 ins from floor also needs to be loose fitting in drain pipe to prevent siphoning ..if neither is the case ckd fill hoses for obstruction in screens last ch flow meter ..remove top round object left side with small hose from fill valve 1 side other side to detergent dispenser may try tapping it while it fills if works ok replace flowmeter
Sep 09, 2008 | Whirlpool Washing Machines
Dishwashers Logo
22 people viewed this question
Top Dishwashers Experts
Owen Barnes
