Question about Refrigerators
Discovery poptop can I use the fridge on gas or 240v with the top down when parked
3 Suggested Answers
  • 8 Answers
SOURCE: I have a Thetford N112 which will not cool the
un plug the heating element from the circuit board and ohm it out. also check fuse on board. but sounds like the heating element has gone out. if when you ohm it its on 0 its bad
Posted on Aug 27, 2009
  • 1056 Answers
SOURCE: Hi I have a jayco jayfinch poptop help how do I
A poptop? And your picture looks like an older regridigrator control panel. Please explain your question with a little more detail.
Posted on Apr 13, 2014
How to convert 110v to 240v dometic 2652 fridge ?
Simple solution would be to step down the 240V to 110 V with a transformer .
Jul 01, 2014 | Dometic RM2652 Refrigerator
Hi I have a jayco jayfinch poptop help how do I turn the fridge on by electricity??
Apr 13, 2014 | Refrigerators
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
Fridge does not cool down
dear sir,
if your freezer,s compressor is running the i think its low gas problem please contect to your service technician for refilling refrigarant .
hope answer the question
thank you
please vote!
Jul 01, 2010 | Engel MT45FU1 Chest Freezer
My 3-way Dometic fridge works on gas but stopped working on 240V! ....Why?
With the 240V element diconnected, test it with an ohm meter to find it was open circuit. No heat! The 12v element still had resistance.
At the moment gas is still keeping my cool while I wait for a new element to arrive. ..... cheers
Sep 01, 2009 | Dometic RM2652 Refrigerator
Fridge wont get cold with gas
This is worth a try. Disconect the gas and power make sure the pilot light is out. Turn the fidge unside down overnight then unright again. Try it on gas agian. This worth a couple of goes before giving up.
Aug 30, 2009 | Thetford Norcold N323 1.7-cu ft 3-way...
Aug 27, 2009 | Refrigerators
Chescold caravan fridge 3 way fridge, (out on the bench not in a van) works well on 240V but not on gas. Pilot looks good, fridge is level, I have tried inverting the fridge as suggested. No luck. I can't...
Yep same prob as my Chescold model RC1180. I pulled the entire gas circuit apart as the fridge works well on 240v haven`t yet sussed the 12v.
I suspected the thermostat ( on the gas side ) there is a tiny jet on the side of the aluminium block at the base of the electric thermostat, also another springloaded 'valve' at the bottom of the aluminium block.The ' valve' is actuated by the thermostat Dial, as it screws a pin down onto a plate which departs from an O' Ring seal letting gas into the chamber where the tiny Jet is seated.This tiny Jet meters the gas to the Pilot burner.
Anyway ' That' wasn`t the problem! lol
The Problem was a 'Clogged Pilot flame Jet'
Fix..... I stripped as piece of fine electrical wire 12v and cleaned the jet out. It is a # 26.
The Jet itself looks like it has been 'Stamped' out rather than Drilled, this may account for some fridges working better on gas than others as there seem s to be some distortion on the Jet Orifice. I will buy a new Jet and a #26 drill and replace the original one.
I am just testing the fridge on Gas now...going like a Trojan... bonus is ive got a little 3 sausage hot plate over the Gas exhaust and am cooking dinner while the beer is getting colder !
K
Dec 06, 2008 | Refrigerators
Our caravan fridge electrolux rm4206 gets cold on both gas and 240v mains but does not seem cold enough ie freezer compartment is not quite frozen and fridge compartment is not cold enough. Any...
remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
Aug 27, 2008 | Electrolux Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
