Question about NAD L40 CD Player
One audio channel is not working
Left channel is not working.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
1.check whether the audio.rca jack cable is good
2.check Rca jack connector
3.there might be a problem in your stereo audio processing circuits
4.Contact service centre for further rectification
Posted on Dec 22, 2007
Creative SBS 370 2.1 - left audio channel is not working
This is coz of one carbon track of dual potmeter gone bad due to prolonged use.
Jan 28, 2013 | Creative Labs SBS 370 Computer Speakers
L/ front audio out not working fully. pre amp channell working & headphone L/front working. Can you advise
The left channel output in the amplifier stage is going out - could be a cold solder connection due to overheating. Check the left channel output of the power transistors solder trace - you can compare them to the right channel stage because they're almost identical circuits.
Nov 04, 2010 | Harman Kardon AVR 7000
Audio volume is weak from left channel but good from right. Problem appears to be after the amp stage as the problem still exists if i swap the audio in L to R. Also tried swappping the speakers and...
More likley that there is a fault in either the pre-amp or power amp of the left channel. To be honest with you it's one of the most diffcult problems you can have, unless you can see a burnt or damaged part. All you can do is compare the parts in the right channel with those in the left.
Touching the parts in either channel with a screwdriver (don't short any) will cause a buzz! This can be used to test the channels. Work backwards from the power amp section. Remember a buzz in the right should give you one in the same place on the left!
PS KEEP AWAY FROM THE POWER SUPPLY.
If you are not good with electronics consult someone who is.
Jan 02, 2010 | Aiwa NSX-DS55 CD Shelf System
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
Bridging a f15d mono block from solid audio witch outputs do i use
Normally right positive and left neg. Your amp should have indicators on the terminals. Of the four you should have a separate + and - for each channel. This tells you which channel is for pos, and which is for neg. If no markings switch for each one left pos/right neg or right pos/left neg. It will only work on one way.
Sep 13, 2009 | Solid Audio F15D 1-Channel Amplifier Car...
No left channel audio on eMachines T6212
Download and install proper driver from;
http://downloads.emachines.com/drivers/audio/D00334-001-002.exe
and check again.
Hope this will work.
Regards;
Hassan
Jul 31, 2009 | Computers & Internet
AUDIO AMPLIFIER'S ONE CHANNEL DEAD
Hi there.
Check for shorted speaker wires on left channel. If not, disconnect speaker wires and check to see if headphone jack works. If left works, you may have a blown speaker. If left still doesn't work, left power amp blown.
Thanks
Paul
Jul 06, 2009 | Sony Audio Players & Recorders
No left channel sound
check wiring. if ok, swap speaker channels if ok, swap rca plugs, if ok. Bad channel on amp.
Jun 29, 2009 | Technics SA-DA10N 5.1 Channels Receiver
Onkyo TX-28 Receiver Output Problem
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Sep 02, 2007 | Kenwood VR-305
NAD L40 CD Player Logo
260 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
