Question about The Office Equipment & Supplies
Can you replace the glass on a pls 180 laser - The Office Equipment & Supplies
Error code a 4200
c-4200? a c-4200 is a laser unit error. replace lsu.
Jun 12, 2013 | Kyocera TASKalfa 180 Copier
Sir Iam Using HP 1007p Printer, One time i get the print in my printer, but my computer monitor "Engine scaning Error" window will be dipalyed, Pls sloved this problem in online
Laser scanner assm faulty, replace it..
If you are teck guy, open laser scanning unit check the engine motor rotation is it free or hard, lubricate it & clean the reflected glass.. fix it back and try..
Sep 20, 2011 | HP LASERJET P1005 Printer
My copies comes out faintly. pls wat is/ are the cause(s) ?
the light copies on these machine can be result of dirty optics. On digital machine when the optics are dirty the copy is light.
You should remove copy glass and clean the lenses and mirrors and glass with glass cleaner and polish it verry well.
Also the problem can be dirty laser unit.Worn developer, worn drum, charge roller,...
Hope that helps!
Aug 24, 2010 | Ricoh Aficio 1035 Copier
How do i calibrate a PLS 180 laser
the pls is a pendelum system you need to open it from the rear and shift the weight it is usually a set screw that you turn in or out to change the resting pointof the pendulem
Feb 26, 2010 | Pacific International Pacific Laser...
I just replaced my ps3 laser it worked for about 10 min now same thing, only the disc wont spin. DID I DO SOMTHING WRONG pls HELP
Sadly there currently is no fix for this problem. I've also had this same problem and contacted Sony about it.
You need to send it in to them to get it serviced. You can do this at:
www.us.playstation.com/Support/PS3
or
uk.playstation.com/help-support/ps3
If your warrenty has expired it will cost around $180.
Although, if you had anyone other than a Sony representative replace your disc, they may refuse to service your console.
Jun 23, 2009 | Sony Playstation 3 (PS3) Console
Replace glasses "broken"
I assume that you are talking about the laser enhancing glasses if so the part number is 603367-00 and they list for 14.52 if not let me know and I will dig deeper.
May 23, 2009 | Dewalt DW077KD 18 Volt Self Leveling...
I have a Canon LiDE 60 need to open scanner. How do I open it?
I just fixed my lide50. The data cable on the left was getting stuck when the scanner was halfway the page. I put some tape around the cable to make it more stiff, now it´s o.k.
To open it you have the remove the long strips on the left and right hand side of the glass panel. they´re glued to the glass but can be removed using a small screw driver. After that carefully move the glass to the backside, now you can lift it. Be careful when moving the scanner around, the ´scanhead´ can get detached, it´s a pain in the *** to get it back together again.
May 04, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Pionner CDJ700S Lens, DWY1069 replace the DWY1067?
Hi Marcelo. I´m from Brazil, same CDJ-700s, same problem as yours. From what I´ve researched until now, DWY 1067 an DWY1069 ARE NOT FULLY INTERCHANGABLE on CDJ-700s and maybe 500s. I think some newer 700s already came out with 1069 from factory, so this is why all this misunterstanding. On older 700s that came out with 1067, some SMD components must be changed in the mainboard in order to 1069 work properly. Mine came ou with 1067, I´ve replaced it with a 1069, didn´t worked well (sound skipped, or didn´t play at all).
In 2001 Pioneer released a replacement kit for this situation. The kit is named GXX1200, and includes the optical unit (DWY1069) which is included in the whole mechanical unit (DXXsomething, depends on model), and SMD resistors and capacitors for replacement. Dirty job, I know...
Since I already bought the replacement 1069´s, I´ll buy the SMD components too. I´ll let you know if will this work. Not an easy task, but I´ll try.
Here you can check the whole kit:
http://www.chsinteractive.co.uk/electrical-components/general-components/lasers-optical-heads-ribbons-and-motors/laser-optical-heads-assemblys-original/pioneer/dxm1239a-gxx1200-laser-optical-head-assembly-replacement-kit-pioneer.htm
And here the documentation for the replacement:
http://www.chsinteractive.co.uk/pdf_data/24001LM.pdf
Regards
Fernando Seiji Imay
Apr 16, 2009 | Pioneer CDJ-700S Turntable
Da price of pulsar 220 headlight
220 mask price is 2000
headlight- 4000
jal- 700
handle ,tee-1300
and easily fit in pulsar150
Apr 06, 2009 | 2007 Bajaj Pulsar 150
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
