Question about Bosch Ovens
Have a Bosch built in Oven, cannot release glass cover to replace oven bulb
  • 100 Answers
Take a look at,uk where they have some videos explaining the different fittings....
On some the glass cover unscrews and on others there is a screw and cover plate that needs to be removed..
Posted on Apr 16, 2017
Any suggestions on how to remove covers on lights in Ilve oven so I can replace globes? Tried warming oven as suggested but they wont budge. Is the only solution to get an Ilve technician?
when you go to the service agent to get the correct bulbs ( (need to be pyrex glass ones as normal bulbs will not stand the oven heat) ,ask them how to remove
the fat from cooking gets in the glass threads and then goes to carbon , making it very hard to turn the covers
maybe a oven cleaner sprayed around the glass may help release the threads
Jan 14, 2018 | Ovens
How do I replace a blown buld in the main oven
In most ovens, move the metal bracket to one side. the glass dome cover should fall out. Unscrew the old bulb. Screw in the new bulb. Place the glass dome cover back over the bulb. Move the metal bracket to hold on the glass dome cover. Easy job to do.
Aug 23, 2015 | Stoves Premier 720EMa Electric Double Oven
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Apr 15, 2015 | AEG Ovens
How i can change the lamp in my Bosch oven?
Remove the glass cover and unscrew the bulb.
Dec 04, 2014 | Ovens
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
Replace bulb
oven bulbs are special bulbs only available from an oven service agent
although the ratings are the same , the glass used is actually pyrex glass as ordinary glass will not handle the oven temperatures
Dec 24, 2017 | Viking Professional VESO130 Dual Single...
I want to change the light bulb in the oven, can you help me.
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: . Click on the Get This Manual button.
I hope this helps.
Jul 24, 2011 | Zanussi ZDQ695 Electric Double Oven
The glas bulb cover at the top of the grill/top oven has broken leaving the glass edge stuck in the thread. I have a replacement but cannot get the old remnants out. Do I have to call an engineer to...
take a wooden stick about the same diameter as the broken bulb; place a washchoth over the end; push the stick into the bulb base in the oven and, turn the stick counter clockwise until it comes out. the stick is an insulator so you won't get shocked and, the cloth grips the bulb base.
Jul 31, 2010 | Bosch HBN 9061 / HBN 9021 Double Oven
Glass light cover removal
Try spraying WD40 onto the glass and bulb holder, try to screw the bulb cover back on first, and then try to unscrew i, it may help if you grasp it with a cloth or similar as you try to unscrew it
Plz rate my solution.
Jan 19, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Pry back the bulb glass cover wire spring and remove glass cover. Use heavy rubber gloves or a plastic bottle opener(piece of serrated soft plastic/rubber) and unscrew counterclockwise.
Mar 05, 2007 | Whirlpool GBS277PR Electric Single Oven
Ovens Logo
48 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
