Question about LG Televison & Video
How do you finalise a disc? machine is LG HDD/DVD recorder RH7926w has no remote - so using other LG remotes -
Successfully used these remotes in past for finalizing but no button pressing can get anything on screen that deals with finalizing please help leanne
    Top Expert:
  • LG Master
  • 74,999 Answers
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. [open and clean] [open and clean]
Posted on Apr 26, 2017
How do i select finalise on sharp dv-rw 250h remote control
If you are using the original remote or one which matches all of the functions, make sure that no DVD or VHS tape is being played and that the recorder is on. Make sure that there is sufficient space left on the disc. (The space needed depends on chapter/disc titles.) Then press Setup on the remote; it should be below the arrow keys but the position may vary. Use the Up/Down arrows to select System Setup and press Enter. Select Disc Setup and press Enter. Select Finalise and press Enter. Select Start with the Right/Left arrows and press Enter. Wait for the procedure to finish.
Note: only discs recorded on this particular device can be finalized on the DV-RW250H. On some other Sharp DVD recorders, the Disc Menu is accessed directly from the Setup menu.
I hope this helps.
Sep 20, 2016 | Sharp Televison & Video
How can I show my DVD-R(Memorex) on my televison?
I assume you mean that your current DVD player won't play this DVD?
There are 3 reasons that it won't play. One that the disc is faulty and therefore won't play on any machine. Two that the disc has a scratch or has marks on it. You can look at ways to clean the disc on-line!
3 That it was not finalised on the machine that it was recorded on. If you current player is a + machine it won't play the disc if it is unfinalised. You will need to use the old machine to finalise the disc or another "-" disc recorder to do it - if it will accept the disc! Otherwise if the old DVD recorder is no longer with you, then your only hope to save the disc is to find another model of your old recorder to do it on. If it was a common model someone might let you finalise the disc!
Feb 21, 2013 | Panasonic Original Pansonic Tv Vcr Dvd...
How to enter disc menu for finalizing dvd-r on philips dvdr3330H
The Disc Settings menu is accessed from the Disc Index Picture screen (so it's not as easily accessed as on other brands of DVD recorders). When you first put a recorded disc in the device, you'll see this index screen. At this point you need to press the UP arrow on the remote repeatedly until the disc content menu appears. This is a screen with the disc name, amount of recording time used and the date of the first recording. Then press the Right arrow button to get to the Disc Settings menu. Use the Down Arrow to reach the line that reads Finalise Disc. Then press OK and then press OK a second time to confirm the action.
The documentation for the DVDR3330H is available from Philips here: . See page 52 for the screen captures. The Finalise steps are on page 53.
I hope this helps.
Aug 19, 2012 | Philips DVDR3330H DVD Player/HDD Recorder
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
I recorded video from my Sony Handycam to the RH387H HDD and then wrote the video onto a DVD-R disc using the XP setting (instead of SP, LP.....). The disc can only playback now on the LG387H, but cannot...
make sure the disk is finalised after recording, if this does not help then the bit-rate it uses for xp may not be compatable with other dvd players, in which case stick to sp,lp or dual-layer sp is best if ou can.
Jan 25, 2011 | LG RH1999H DVD Recorder/HDD Recorder
How Do You Finalize the DVD after Recording it?
On remote control press 'Setup' button;
'DVD Video Setup' tab will be highlighted;
Using arrow keys around the 'Enter' key, press right arrow once to move to adjacent tab called 'HDD/DVD Setup';
Press down arrow once to move to 'HDD Setup' tab;
Press right arrow to move to 'Disc setup' tab;
Press down arrow to highlight 'Finalise' button;
Press 'Enter' and follow on screen prompts.
Dec 21, 2009 | JVC DR-MX1 DVD Recorder/VCR
DVD - Video Finalization rejection
1. The message can appear if the disc has already been finalised.
2. The disc may be faulty.
3. Try copying again from HDD to another disc. Performing a copy and finalise together by using 'DVD Video Creation' from the Edit menu can be more successful than doing each step separately.
4. When you transferred from your video camera, did you use firewire? If so, did you record at the maximum (default) bitrate of 14+ ? If so, you must copy (rate conversion) to the DVD at a maximum bitrate of 9.2, which is the maximum for the DVD playback standard.
Jan 01, 2009 | Toshiba RD-XS34 DVD Player/HDD Recorder
Finalise disc
You need to put the disk back into the recorder, select the finalize function from the onscreen menu, and follow prompts. Do you have an owners manual for the unit?
Apr 22, 2008 | LG RH177 DVD Recorder/HDD Recorder
Hi there. You need to "finalise" the dvd before you can view it.
LG RH1999H DVD HDD Recorder
1. Turn machine on
2. Use remote to open disc tray
3. Use remote to go to setup area of menu (Home - Left) and scroll down to 'Lock' symbol
4. Press 0 seven times
Oct 29, 2007 | LG RH1999H DVD Recorder/HDD Recorder
Televison & Video Logo
32 people viewed this question
Computer Repairing
Computer Repairing
