Question about Solis Coffee Makers & Espresso Machines
Need a switch for Solis 114 to start grinder. Brand:Defond. type:CPU-1113
    Habit-Forming:
  • 100 Answers
I don't know where you are but...
http://www.partsguru.com/SolisEspresso.html
These people are good even if there website is rubbish...
Posted on Apr 16, 2017
Where can I buy a Defond CPU-2113 safety switch for a Toro Blower/Vacuum?
If you do not use the Blower / Vac for Vac you can cut out the the reset switch, it's only when you get foreign material in the impeller using the Vac stopping the motor, I cut out the switch. As you look at the Defond switch (side with writing you see a white wire and a black wire side by side. mark the black wire with a small piece of tape 1-1/2 inches from the connecting lug. Cut all wires off the switch. Strip wires back 3/8 to 1/2 inches. Use heat shrink tubing
and slide it back on the black wire with the tape, same thing thing with the black wires on opposite side of the switch. Use a end to end splice as opposed to a parallel splice because of wire routing space..Splice the white wire with the black with tape, Then the other two black wires. using heat shrink tubing to cover the splice. Good idea to take a picture (smart phone) so as to see wire routing after you separate blower halves, very little wire routing space. Make sure motor is seated in it's nest before joining halves together do not use Vac if you use this fix. Mine works just fine, save $60+ bucks.
Nov 01, 2014 | Toro Garden
Push-button microswitch Defond CPU-1113
https://www.repairclinic.com/PartDetail/Switch/811421/3315030
or here
http://www.ezvacuum.com/eureka-electrolux-power-switch-81142-1-for-air-speed-pronto-amplify-precision-and-more.html
Here. Amazingly, after 2hours of search I found out that it is the same thing (thanks to this guy on ifixit - Eureka Airspeed Exact Pet Bagless Upright Vacuum Power Switch Replacement )
Also, NOVA KAN l-5 is basically the same thing only it is impossible to get just one of them, only buy in bulk from alibaba
So, I hope this will show up in google next time someone searches for this damn part!
May 18, 2014 | Heating & Cooling
Looking for a source to purchase Defond CPU-2113 replacement switch for Toro Blower Model 51599. I live in Omaha, Nebraska.
I can offer it. drop me a memo send the Defond drawing and the quanitity to: roman dot xiao at gmail dot com
Jan 07, 2011 | Garden
Timer knob is broken, I need a replacement
Hi Contact Baratza at 877-701-2021 They should be able to help.
Feb 06, 2010 | Solis Maestro Electric Burr Grinder
Cleaned the Solis Maestro grinder and re set it to a fine espresso setting but the grind is coming out very course. What should i do?
Hi Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Jan 12, 2010 | Solis Maestro G385 Electric Burr Grinder
My Solis coffee grinder does not go a fine grind any more. We
Hi
Your grinder adjustment ring inside has its tabs broken. Contact Baratza at 877-701-2021 and they should be able to help get a new one.
Nov 15, 2009 | Solis Maestro Electric Burr Grinder
Service solis master pro
Hi
Contact Quality Coffee Systems in Burnaby, BC qcs@telus.net
Dec 18, 2008 | Solis Master Top 517
Burrs
you can see at
http://www.youtube.com/watch?v=qu4t1uzOrF8
just you need to continue opening 2 part more than in 5 min and 40 sec, there you go further than the video shows.
Dec 22, 2007 | Solis Maestro Electric Burr Grinder
Solis Master 5000 Espresso Machine - Need Repair
If you can remove the grind hopper(two screws) you can re-index the grinder for a finer grind.
Apr 21, 2007 | Solis Master 5000 Espresso Machine
Coffee Makers & Espresso Machines Logo
60 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
