Question about Marantz Audio Players & Recorders
Marantz 1170 was playing music and started turning up volume all music shut off what's the problem
  • Back2life Electronics Apr 26, 2017
    Does the unit power up? If so and you still have no sound, it is likely that an output channel has shorted which would put one of the rail voltages on the speaker outputs. There is a circuit that would detect this and shut off the audio to protect your speakers. It's time to take it to get serviced. I can certainly nurse that baby back to health but it would have to be shipped as I am in Missouri.
    www.back2lifeelectronics.com
  • Marantz Master
  • 3,828 Answers
How old is that unit ?
cant find a picture of a 1170
faulty volume dials or slides
internal fuse ?
power source over heating
just how load = enough to pop the speakers
Marantz 1170 was playing music and started turning - images-4p5wtmbbsqxcguhfujkugljq-5-0.jpg
Posted on Apr 16, 2017
3 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Avr Shuts down at high volume
It does that because there is a safety feature in all the newer devices. If your system is turned up to high you would blow your audio outputs or speakers. That's why it shuts off.
Posted on Jan 17, 2009
  • 28 Answers
SOURCE: power problem?
1. Is the head unit powering the speakers directly or through an amp?
2. What ohm load (4,8,) per channel and how many speakers?
3. Does it do it with the bass set all the way down?
If you have access to a voltmeter see what the voltage is on the yellow and black wires when it is diming. It should be stable ~ 13.5v with car on. if its < 10v when dimming either there is:
1. Shorted speaker lead.
2. Bad ground to radio.
3. loose power feed to radio.
4. Ohm load below 4 ohms, causing the eccess current draw.
Posted on Nov 12, 2009
Volume fluctuations
Does the volume fluctuate through speakers?
Feb 19, 2016 | Marantz Audio Players & Recorders
Marantz SR-66 Shut down!
Sounds like the protection circuit is tripping. With power off, check for loose speaker connections. Also, look very closely for shorts in the speaker wires. Even a single loose strand can touch another connection and create a short, which shuts down the receiver.
I would take take the frequency splitter out of the circuit and see what happens. Check for acceptable impedances in the manual. The receiver may not like the load the splitter presents.
The receiver may have settings for bi-amping. Then you use one set of terminals on the back for treble, and a different set for bass.
Feb 03, 2015 | Marantz SR-66
Marantz SR5500 B speaker setup problem
are all the speakers connected 1.5s
all the same watts helps
is that one with an inbuilt amp ?
what a mess or connectors at the back of one of these
Model SR5500 User Guide - Marantz
us.marantz.com/DocumentMaster/US/DFU_SR5500_Final_Eng.pdf
Apr 16, 2017 | Marantz SR5500 Receiver
AVR SR6004 switches off while BD player is playing. What do I do?
There are two circumstances that I know of that a properly installed unit such as your Marantz would shut down. So here is the Theory and Data I know of.
A Your receiver has a great deal of amplification power. If it is in a closed cabinet without excellent ventilation, it will shut down if used at high volumes because because over heating. Because of it's very high power, when played loudly, it generates excessive heat.
When watching certain movies the BD player may be over-driving the limits of the amplifier section of your receiver. Page 78 of your owner's manual addresses this. Here is a link to download the manual from Marantz.
http://us.marantz.com/us/Support/Pages/Manuals.aspx
B There is one other very important thing I should mention to you. When people use high powered equipment and initially turn up the sound. After a short time, the mind turns it down. What next happens is the reason professional musicians and sound engineers often have permanent hearing loss after a relatively short time.
What tends to happen is that the listener and often the engineer running the sound mixing board at a concert(after a certain period of time) believes the sound is not loud enough when it really IS loud enough. (this tricks the audience as well) and engineer turns it up. After turning it up, his mind (and the audiences') turns it down mentally and they again think and agree that it not loud enough and then again, the volume level is turned up. And up. And up. The only reason I'm not deaf is that I discovered this when I was building sound systems as a kid. I also studied about it. So please be careful when you play things loud. Permanent hearing loss starts to occur at the very high frequencies and rolls down from there over a period of time. Hearing loss can start to occur in just a few hours at 110 decibels. permenant hearing loss is exactly just that. Permenant! It just doesn't come back. If you use this information, you will enjoy hearing music for the rest of your life.
I hope this helps,
Best Regards,
Mark
Jan 22, 2011 | Marantz Audio Players & Recorders
Marantz SR9200 shuts off intermittently while watching or listining.
Check all speaker connections. unplug everything.. start with just L and R speakers. Do a mic calibration..also check all your source inputs to the amp. start from the basics. Is the amp still under factory warranty? I used to install marantz...also make sure unit is well ventilated. IF you are using audio zones in your place..with in wall volume controls..make sure they are impedance matched. VOLUME may be set to high...overdriving the outputs..eventhough audio may not be loud. Set volume to -30...?
May 06, 2010 | Marantz SR-9200 Receiver
When the level of the music gets over 40db the unit stops playing so i have to turn the volume button at a very low level to avoid kicking off. the problem started when my little sister managed to reach...
Disconnect all speaker wires at the receiver then turn it back on and the volume up. If it stays on, post a comment and I can walk you thru troubleshooting. If it still shuts down there is an internal problem and it needs to be serviced.
Aug 30, 2009 | Marantz SR4021
Alpine 9813
i have that same problem. when i turn the volume up, it shuts off but comes back on right away. the only thing i can think of is i'm not running the constant power directly from the positive terminal on the battery (which is what is recommended). not sure if thats the solution but im gonna try and wire it right anyway...
Jul 19, 2008 | Alpine CDA-9813 CD Player
42 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
