Question about Car Audio & Video
The speakers need rewireing - Car Audio & Video
Hi. I own a Kustom 12-Guage Amp that I need to rewire a speaker to. Could you tell me which speaker wire goes onto which terminal? White to? Black to?
If multi speaker operation take care to make sure that you wire the speaker in phase with the other units.
Aug 27, 2017 | AMP Car Audio & Video
I HAVE TWO YELLOW WIRED POWER AN WHAT..95 CAMARO REWIRING RADIO
Below is a listing of the radio wires and what they control.
1995 Chevrolet Camaro car radio wiring schematic
Car Radio Battery Constant 12 volt Wire: Orange
Car Radio Accessory Switched 12 volt Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6.5" speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire: Tan
Left Front Speaker Negative Wire: Gray
Right Front Speaker Positive Wire: Light Green
Right Front Speaker Negative Wire: Dark Green
Car Audio Rear Speakers Size: 6.5" speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire: Yellow
Left Rear Speaker Negative Wire: Brown
Right Rear Speaker Positive Wire: Dark Blue
Right Rear Speaker Negative Wire: Light Blue
Jul 08, 2014 | 1995 Chevrolet Camaro
Schematics for logitech x230 speakers
Hey Jaime,
Unfortunately, Dell does not have any available schematics for wiring the x230 speakers available. You would have to maybe contact Logitech.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 06, 2014 | Dell Dimension 2350 PC Desktop
My left speaker of my logitech s120 speakers has stopped working. It's probably the wires but how do i get it working again?
I would start by plugging the speaker in an mp3. if they still dont work
you need somebody who can rewire the speaker. Its not dangerous nor difficult but you need to pry open the speaker.
If your speakers are working fine on the mp3 then you volume is set to balance to the right. Put the balance in the middle in windows
cheers
rene
May 27, 2011 | Logitech S120 2 Speakers
How to rewire voice coil of a speaker
You cannot rewire a voice coil of a speaker unless the speaker itselfis rebuildable. If it is rebuidable, a complete reconing kit is necessary
Dec 23, 2010 | Car Audio & Video
Need to rwire audio speakers in a 1999 f250 super
Try here:
http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Ford.html
Apr 25, 2010 | Car Audio & Video
1 of my speakers are broken
You can buy a new one for that if you say that it is broken or you can repair that by rewiring the speaker coil attached to the speaker magnet inside but of course you need some skills to do that. If your unsure, you can bring your speaker system to any service center that offers speaker repairs.
Dec 23, 2009 | Audio Players & Recorders
REWIRE
Series wiring of a 4 ohm DVC subwoofer will result in an 8 ohm load.
See the following diagram.
The diagram listed has a dual 2 ohm voicecoil, netting 4 ohm, however in your case, the dual 4 ohm sub will net an 8 ohm load.
Dec 26, 2008 | Jl Audio 12W6v2 Car Subwoofer
I was pulling my car radio & think i might have disconnected it. how can i fix it?
Check your fuses. Wiring is like plumbing.  Follow the feed.  Need a lot more information but just plug it back in if it's a harness.  It's it's just spliced together then you have to check each wire by disconnecting and rewiring properly.  Rewire while car is off turning to Acc after each wire.  Start with power, ground, pow ant, to verify connectivity.  Once power is on start with speaker wires.
Sep 09, 2008 | Car Audio & Video
Car stereo installation speakers
Your old unit was a common ground unit meaning all speaker grounds as well a radio ground were the same. The new unit should NOT be connected to this wire configuration. Newer units change the potential difference of the speaker power meaning that the - wire of the unit may have negative 24v on it so IT CANNOT BE REFERENCED TO EARTH OR CHASSIS GROUND.
I would recommend rewiring the speakers to the radio for best reliability and sound quality.
Dec 31, 2007 | Jl Audio 12W3 Car Subwoofer
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
