Question about DeLonghi Coffee Makers & Espresso Machines
Hi Wondering if you can help? My Delonghi Magnifica is jammed and not responding to any buttons pressed. The warning sign is illuminated and lights come on when turned on but nothing happens??
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
mailtoravi
  • 186 Answers
SOURCE: hp dv4000 won't power up
Try this solution :
1. Disconnect the AC Adapter.
2. Remove the Battery.
Note : Please see that there are no external devices or cables connected to the Notebook.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook.
Additionally, try removing and reinserting the RAM sticks by following the instructions listed in page number 119 of 266 :
http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
If the issue repeats, try connecting the Notebook to any Desktop Monitor and press the FN and F4 key so that the display will transfer to the desktop monitor connected.
If there is no display on the LCD of the Notebook or on the Desktop monitor connected, issue can either be with the Graphic Card of the Notebook or Motherboard itself.
I am sure these instructions are helpful.
Posted on Aug 13, 2008
SOURCE: Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Posted on Feb 20, 2009
SOURCE: delonghi magnifica coffee machine...infuser jammed
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Posted on May 03, 2010
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
My Delonghi Magnifica has a problem after turning on it doesn't get hot and after a while of the cup lights flashing the red warning light comes on and the machine won't do anything!!
most coffee makers have a temperature sensitive diode in the circuit, and that will "blow". if you are comfortable working on your own unit you could troubleshoot it, otherwise, bring to a repair shop.
Jun 10, 2016 | DeLonghi Esclusivo Magnifica ESAM3300...
This is difficult to describe but my delonghi magnifica has developed a small problem, after turning the machine on via the front panel On button, the pump activates (slightly) even though no other buttons...
It might be a normal cleaning cycle or flushing itself out. You don't mention whether it's not working anymore, so is it just that the sounds and lights seem concerning, or has it actually stopped working?
Oct 28, 2013 | DeLonghi Magnifica 3300 Espresso Machine
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi Magnifica Rapid Capucinno Power button not working. Hi all, We have a delonghi coffee maker that stops working few weeks ago. The machine doesn't power up. When you plugin into the outlet...
It's quite likely your unit had a blown thermal fuse caused by a bad thermostat. Test them by disconnecting one end and a meter should show continuity if the part is good. The pro's test them in circuit while the unit is plugged in, power showing across the part means it is bad. REPLACE BOTH PARTS TOGETHER.
Jul 02, 2017 | DeLonghi Esclusivo Magnifica ESAM3300...
I cleaned my delonghi magnifica and now nothing works. neither water or coffee comes out.it is just out of warranty unfortunately. help!
have u switch it on on back cover ??? ummm make sure u have the bucket sat in correctly .....and tray is in properly... have you snapped off the peg on the rear of the bucket for wast ?? its located rear of bucket. bsc appliances bristol 07779933829 postal service too.
Feb 08, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Our Delonghi Magnifica Automatic Capuccino machines needs de-scaling, I would like some instructions, and also is there any way of increasing the temperature of the coffee.
Press the 'menu' button and then the 'change' button repeatedly until it shows 'descale'. Then press 'ok' to choose yes. You have to add descaler to the water container.
Dec 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Descaling a delonghi magnifica ESAm04
Apr 22, 2010 | DeLonghi Coffee Makers & Espresso Machines
Delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
Mar 21, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
