Question about Cell Phones
Contact coolpad tech support
Removing or resetting the error code 67
Need to change my Coolpad phone number to my area code please help
This is something you would need to contact your cellphone plan provider for.
They cannot guarantee that number with a different are code and your plan might change depending on region. Contact them and they can make the change for you.
Jan 19, 2017 | Cell Phones
How to disable data error 67 on my android coolpad
https://www.youtube.com/watch?v=2XFRE5EQdmw
Dec 31, 2016 | Android Cell Phones
Is there a way to make calls on my coolpad phone without showing my phone number?
Dial *67: This method allows you to make you block id for any type of phone. It is not depend on mobile platform. You can block your caller ID by simply adding '*67' prefix before the number. You must dial country country ('1' for US) following to *67. The call format will be like this.
*671-123-123-1234
May 03, 2016 | Cell Phones
How do I do a factory restore on a Coolpad 3300A
http://www.hard-reset.com/coolpad-quattro-4g-hard-reset.html
Coolpad Quattro Hard Reset (Factory Reset)
    1.Turn off your Coolpad Quattro phone and pull out battery and reinsert it after a few seconds
    2.Press and hold both Volume DOWN + UP and hit POWER button until "Recovery mode..." showing on the screen. When the triangle with an exclamation mark appears touch the HOME touch key to enter Recovery menu.
    3.Select Factory reset/ wipe data. (scroll down with VOL down.)
    4.Select with power.
    5.Scroll down to Yes - delete all user data. Press power to confirm. If your phone is responding to screen input, then open Settings from the Applications menu. Tap Backup & reset > Factory data reset; click Reset phone and Erase everything to format your phone.
Jan 04, 2016 | Computers & Internet
How do i hard reset a coolpad 8810
http://androidxda.com/download-coolpad-stock-rom-models
use your pc and flash software from the page... and the right rom!!!
then update it again
Sep 20, 2014 | Universal Coolpad 8810 3.5"" Capactive...
Error code 67 won't connect to internet
You have to reset your phone by pressing specific numbers on your dial pad you`ll receive those numbers from your mobile provider so you must call them and also ask them for your access code doing this will delete all the information on your phone but it is the only way to get rid of error code 67.
Jan 15, 2014 | Net10 LG Optimus Logic Cell Phone
Coolpad quattro 5860E error messages...cant email or upload photos
you need to reload the sd card or get a new one.the error mess. will go away,the card has the problem in it.you should be able to remove it and use the phones storage to upload some pics..replacing it will provide more operating functions
Dec 24, 2012 | ALPcellphonescom Coolpad Quattro 4G...
Fix error code 67
Error Message
"Data Call Failure
Error Code : 67
Error Code 67 Registration Failure. Your PCS Vision username and/or password may be incorrect. Please try again."
This error message is an example of the error message you might have received. You may find that your computer is running slower than you first got it. After frequent use, you may also have system crashes or even blue screen of death.
We strongly suggest that you run a quick scan for error code 67 for your PC to check and fix the errors.
Buy Now (Only $34.95)
30-Day Money-Back Guaranteed
What Is Error Code 67? One thing you should know is that when you access the Internet, your system will have some access to the recourses of a remote computer. If the name of the particular network cannot be found, error code 67 will show up to your computer screen. And you will not be able to use the resources provide in the network.
Fix Error Code 67 Error Now! How to Fix Error Code 67? Sometimes, Windows error codes also indicate a faulty hard ware in your computer. It could be a hard ware that has not been installed properly. Or it could also be insufficient free space in your hard drive. When you receive error messages like that, you should go and check the condition of your hard drive immediately in case of further damages.
Now that you know what the causes of error code 67 are, you have to learn to fix the relating problems. To do this, you can take a look at the tips below:
  • Remove files you do not need from your hard drive. You might have stored files in your computer like movies, music or images that you have accessed for a long time. If you do not need these files, you should better delete them from yourcomputer. This will ensures the sufficient free space in your hard drive.
  • Uninstall unnecessary software and disable startup programs. If you have some software that you no longer need, uninstall them from your computer. Besides, too much startup programs will hinder the process of starting up of your system. You could check and disable the programs you do not need in startup.
  • Scan your system in a regular basis. If your computer keeps on giving you error messages and your system performs slower and slower, you should pay attention to the safety of your computer. Chances are that your computer has been infected by virus or Trojan that hinder the efficiency.
  • Clean your registry. If the registry of your computer is corrupt, you would also receive irritating error messages. So you should scan your registry, identify and fix all the errors in your registry.
Jan 29, 2012 | Refrigerators
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
