Physical fitness consists of five component what are those?
    Top Expert:
  • Televison & ... Master
  • 75,017 Answers
Health, wigour, madness, loose motion and urithrown
Posted on Apr 16, 2017
The 5 Components of Physical Fitness:
We all have an idea of what "fit" should look like. For some people, it means having a sleek Hollywood body, while others want to have massive muscles or a perfect hourglass figure.
But fitness isn't defined by appearance! There are five components of physical fitness you need to consider:
1. Muscular Strength
This is the "power" that helps you to lift and carry heavy objects. Without muscular strength, your body would be weak and unable to keep up with the demands placed upon it.
The way to increase strength is to train with heavy weights, working in the 4 - 6 or 12 - 15 rep ranges. The heavier the weight, the fewer reps you should perform!
2. Muscular Endurance
Endurance is the ability of your muscles to perform contractions for extended periods of time. Rather than just lifting or carrying something for a few seconds, the muscles are used for minutes.
The way to increase strength is to train with light weights, working in the 20 - 25 rep range. Working with lighter weight will train the muscle fibers needed for muscular endurance, and the higher rep range leads to a longer period of exercise.
3. Cardiovascular Endurance
Cardiovascular endurance is your body's ability to keep up with exercise like running, jogging, swimming, cycling, and anything that forces your cardiovascular system (lungs, heart, blood vessels) to work for extended periods of time. Together, the heart and lungs fuel your body with the oxygen needed by your muscles, ensuring that they have the oxygen needed for the work they are doing.
The Cooper Run (running as far as possible in 12 minutes) is a test commonly used to assess cardiovascular endurance, but many trainers use the Step Test (stepping onto a platform for 5 minutes). Both are accurate measures of a subject's cardiovascular endurance.
4. Flexibility
Flexibility is one of the most important, yet often overlooked, components of physical fitness. Without flexibility, the muscles and joints would grow stiff and movement would be limited. Flexibility training ensures that your body can move through its entire range of motion without pain or stiffness.
To test your flexibility, lean forward and try to touch your toes. Those with good flexibility will usually be able to touch their toes, while those with limited flexibility will not. The sit and reach test (sitting on the floor and reaching toward your toes) is another good way to assess your flexibility. The more flexible you are, the closer you will come to touching your toes and beyond.
5. Body Fat Composition
Body fat composition refers to the amount of fat on your body. For example, a 100-pound person with a 25% body fat composition will have a lean body mass of 75 pounds.
Apr 16, 2017 | Televison & Video
Where is the neutral safety switch at on 2005 buick rendevous
Inside the transmission . An it's called internal mode switch .
The lever assembly-manual shaft detent with internal mode switch (IMS) is a sliding contact electrical switch assembly that corresponds to the PRNDL position selected. Each of the PRNDL positions has a unique ground pattern on four wires from the control module.
The assembly consists of two major components:
• The internal mode switch that consists of:
- The housing (1), which makes up the stationary contacts.
- The insulator (2), which makes up the moving contacts and is secured on the detent lever (4).
• The lever assembly which consists of:
- The manual shaft (3)
- The detent lever (4)
The range detection is accomplished by securing the moving contacts to the detent lever. When the driver selects a PRNDL position, the detent lever inside the transmission rotates. This rotates the insulator which in turn grounds the four wires in a unique pattern for each gear selection, corresponding to the PRNDL position selected. The IMS is electrically connected by five wires (four of which the control module supplies voltage to and one wire that is a common ground) to the transmission pass through connector.
Nov 09, 2016 | Buick Cars & Trucks
What cars does the nania d9 fit
We recommend a physical fitting of any carseat / carseat base prior to purchase to confirm suitability.
With a carseat that is fitted with 3 point seatbelt there is no way of being able to confirm 100% suitability without a physical fitting as there is no standard length for seatbelts / seatbelt webbing so it can vary widely even between two vehicles of the same make, model and year of manufacture. Contact your local retailer and request a carseat fitter trained member of staff provides physical fitting in your vehicle.
Sep 26, 2014 | Baby Gear
Instructions to reset a nordictrack cardio track watch
You may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
    • Press any button to activate the Polar F11 Fitness heart monitor unit.
    • 2 Press all buttons on the Polar F11 Fitness heart monitor simultaneously, except the "Light" button. There are five buttons and the "Light" button is at the top left side of the unit. Continue to hold the buttons until the display fills with digits.
    • 3 Press the "OK" button, which is located on the right side of the unit in the middle of the up and down buttons. The Polar F11 Fitness heart monitor will reset.
  • Oct 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
    What is physical health
    Physical health is that state when our body is involved in various physical activities and various activities without feeling restless. When our body is free from various diseases it can be termed as physical health of our body.
    Jul 05, 2011 | Cycling
    I have a Sampo 42 inch plasma multimedia display monitor model PME-42S6 (s). I got a blu-ray player and connected it via the AV1 inout. The screen is now green and red. What can I do to fix this?
    If you have a Blu-Ray player you should be connecting it via HDMI, which is the only way to receive a full HDMI picture on your television. But you may connect it via the component inputs if you do not have an HDMI cord. The component cable consists of five color coded cords of (1) red and (1) white cable for the audio, and (1) blue, (1) green, and (1) red cable for the picture. Connect the Blu-Ray using this cable and you will be fine.
    Feb 15, 2011 | Televison & Video
    Have a series of 5 chimes 5 times believe its
    The secondary air bag warning is an audible fault format that consists of five sets of five tone bursts, with each set of five tone bursts separated by a five second quiet period. One tone burst cycle will consist of one second ON and one second OFF. This series of five activations is repeated every 30 minutes.
    This will tone if the air bag indicator is inoperative.
    Suggest to have the dealer or someone with a scan tool that will communicate with the restraint system retrieve codes.
    Mar 16, 2009 | 2002 Ford Escape
    A motherboard is the central or primary printed circuit board (PCB) making up a complex electronic system, such as a modern computer or laptop. It is also known as a main board, baseboard, system board, planar board.
    he motherboard of a typical desktop consists of a large printed circuit board. It holds electronic components and interconnects, as well as physical connectors (sockets, slots, and headers) into which other computer components may be inserted or attached.
    Sep 26, 2008 | Computers & Internet
    My hd tv
    to view anything in High definition you have to connect to your tv using either the DVI, Component or HDMI inputs. Your cam or anything you want to view HD videos from will need to have a lead to suit these inputs, the component lead will consist of an input from camera to five seperate coloured leads or an oblong DVI connector or HDMI which looks similair to a usb connector. You will need then on your tv to select the resolution of 720P or 1080I to view the HD picture.
    Jul 14, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
    Televison & Video Logo
    29 people viewed this question
    Top Televison & Video Experts
