Question about Yamaha Audio Players & Recorders
I own a Yamaha RX-V520. When the volume is set to min I can still hear the left back speaker. How to fix this problem? Thanks!
easyq
  • 144 Answers
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Posted on Apr 17, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX-V520
If you don't have any speaker wires hooked up to it and it won't turn on, the only thing left to check is the internal fuse. First, make sure it's unplugged from AC, then remove the top from the receiver, 6 or 7 small phillips head screws. At the back inside corner where the AC comes in there is either one or two fuses, check them. If you have a multimeter, dial it to resistance & sound (meaning when the two probes touch you will hear a tone) touch both ends of the fuse with the probes, if you get tone, fuse is good, if not, replace the fuse and all should be well. If you get tone, you've got either bad transistors or a bad power supply. Could be a 100-200 repair. Hope this helps
Posted on Jun 11, 2009
dunnbiker
  • 8546 Answers
SOURCE: Yamaha RX- V 663 - unable to change volume on Zone 2
Page 111:
PROBLEM: Zone 2 speaker settings are not available in "SET MENU".
CAUSE: "EXTRA SP ASSIGN" is set to a setting other than "ZONE2".
REMEDY: Set "EXTRA SP ASSIGN" to "ZONE2".
See Page 85
Posted on Mar 13, 2010
Testimonial: "Hi it certainly pointed me in the right direction. Thank you. A few more steps would have been useful and page number suggestion was not correct p33."
dunnbiker
  • 8546 Answers
SOURCE: Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Posted on Apr 30, 2010
gopakumarg43
  • 75178 Answers
SOURCE: Yamaha AV Receiver RX-V465 picture but no sound.
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Posted on Jan 17, 2017
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
No volume
You need to check the settings and also check the connection from receiver to five speakers .
Oct 28, 2008 | Yamaha AX-596 Amplifier
What is the best speaker volume settings for 5.1 system my receiver is Yamaha rx-v430 and room size is 15x20
As this receiver does not have automatic speaker calibration, you need to set the volumes manually. The best is if the left and right speakers are at the same distance from you (then their volumes can be equal). If one speaker is at more distance than the other, the volume must be higher for this speaker.
You can find instruction for volume setting at p. 21 of your receiver manual. There you can also find settings of the speaker mode - that depends on the specific speakers you have. You can define for each of 5 speakers if they are Large/Small/None (on this setting depends where will be the lowest bass tones directed).
Oct 20, 2013 | Yamaha RX-V430 Receiver
How can I connect Senheiser wireless headphone to Yamaha RX773 without using front headphone jack as this mutes speakers, I have hearing problems, my wife doesn't, I tried both av audio outs in the back...
Your receiver has Zone-2 functionality. For Zone-2, it has both speaker (powered) output and pre-out line outputs. According to Yamaha FAQ, these pre-out outputs are independent on the main volume settings. So if your wireless headphones have their own volume settings, you can change the volume independent on speakers volume.
If you want same volume for speakers and headpohones, use the PRE-OUT FRONT outputs on the back. If you want different volumes (and listen to headphones even with speakers muted), use ZONE-2 OUT outputs on the back.
Oct 02, 2013 | Yamaha RX-V773WA RXV773 7.2-Channel A/V...
Yamaha rx 530 center channel cuts out
Thanks for all the suggestions guys.
I've tried using the balance for left and right speakers, and when the receiver is acting up with the right speaker having a low volume, I tried moving the balance all the way over to the right speaker. The right speaker volume will not increase in volume but the left speaker will decrease in volume.
Just to clarify, the center and the rear speakers are balanced. The issue only happens sometimes when I first power on the receiver I will have no center channel. If I leave everything alone for a few mins, the center channel will come on.
So it seems to me that something one the receiver is going. The question is, can anyone suggest a physical repair for the receiver for these symptoms?
Thanks
Jul 20, 2012 | Yamaha RX-V530 Receiver
Trying to hook up a velodyne dd 12 sub to the unit. Please direct me to the correct way to do this
I have the same setup. Use 1 pair (Left/Right) RCA to RCA cable. Connect from Velodyne "Input" (left connectors) to Yamaha SubWoofer #1 Preamp output. Make sure you have the sub's volume (left knob from back) very low (full counter clockwise is "Min") until you are setting up the audio balance in your house/room. Set Low Pass cross over to 80Hz, Phase switch to 0, subsonic to 20Hz, X-over to "IN", Power to "auto"
On Yamaha RXV1 remote control, go into speaker setup and turn on Sub and any other speakers you have connected.
Warning!! do not turn up volume near a china cabinet while you are watching a movie. Everything will walk off the shelf.
Jan 31, 2011 | Yamaha RX-V1 Receiver
No volume in Zone 2
Get the original Yamaha remote, go to Set menu, manual setup, speaker setup, and look for "extra speaker." it needs to be set to "zone 2." This is off the top of my head, so it should be pretty accurate. Get used to doing this, though, as this amplifier assignment to zone 2 is prone to resetting itself in those Yamahas.
Sep 05, 2009 | Yamaha RX-V661 Receiver
We want to hook up eight speakers in eight differnet rooms (one speaker per room with individual volume control) and hook them up with yamaha RX-V1800 receiver so that we can play all the speakers in...
Hi...
Without a huge mess, I would suggest one of the multi-speaker selectors that partsexpress.com sells or a similar item.
Just put "speaker slector" in their search engine.
If youre going to 8 other rooms..you might try a couple of wireless speaker systems too. They work in stereo and ....no wires
Jan 03, 2009 | Yamaha RX-V1800
Yamaha RX-V520
Aug 18, 2008 | Yamaha RX-V520
42 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
