Question about Dishwashers
Our delongi dishwasher has an E4 error message displayed. How can I fix the problem?
SOURCE: E4 error on new conia dishwasher
I have a Maytag MJD3000AAW dishwasher and it was showing E4 during a cycle. On checking the pressure tube from the outlet of the dishwasher to the nozzle on the u tube under the sink, I fould that the dishwasher was not draining properly as a kink have developed in the tube where it curved back to the nozzle. I slid the pressure tube into a long elbow which stopped the tube from pinching. Problem solved.
Posted on Nov 02, 2008
SOURCE: Delonghi dishwasher won't drain.
I have the same machine with the same error message but my machine has drained it self but will not continue the cycle?
Posted on Nov 15, 2008
whytfang
  • 170 Answers
SOURCE: E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Posted on May 19, 2009
SOURCE: e4 error message
I have the same problem. Want to buy a new one, but would like to know if this can be fixed.
Posted on Jun 09, 2009
  • 109 Answers
SOURCE: Hobart dishwasher model LX30H; displays wrench and E4.
Water is not to top sensor in alotted time.
Top sensor is in right rear corner, and is the upper of the two. Check the connector to the probe on the outside at the back. (sometimes gets wet fro vacuum breaker leaking when dirty or low flow pressure. Machine needs 20 psi flow rate
Posted on Aug 14, 2009
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
E4 always appears on the display of my electrolux ewt604s, what is the quickest solution to fix the problem?
http://www.electrolux.co.nz/Support/Manuals/?modeld=ewt604s
No easy answer.Electrolux does not recognise your model number or list error e4. I can only wish you good luck. and a few links that may help. Phone numbers and address at web address above.
If it won't open, copy and paste to your browser bar.
Electrolux Dishwasher Parts Accessories
electrolux dishwasher troubleshooting YouTube
Sep 13, 2014 | Dishwashers
Logik dishwasher E4 error message
I am having difficulty with my logik slimline dishwasher. E4 message about 30 minutes into cycle. Where the salt goes is always full of water. Please can someone help me
Nov 17, 2012 | Dishwashers
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Shane
Feb 27, 2011 | Kenwood KDW243A Builtin Dishwasher
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
Hope this help?
Thanks.
Nov 02, 2010 | Kenwood KDW243A Builtin Dishwasher
Disherwash is showing e4 what does it mean
The E4 error is not usually associated with newer dishwashers. Older Kenmore dishwashers with digital displays would show an E4 error when the selector switch pads/buttons were stuck. You need someone In to look at it im afraid
Sep 25, 2010 | Kenmore 15762 Dishwasher
My husband put dish soap into our edgestar dwp40s dishwasher instead of dishwasher liquid. now it says e4 on the display. what to do to fix it?
check your manual for the " e4" . Remove the dish soap by a sponge & squeeze it into cup.
U can re use this.Repeat til the chamber is empty. Now put water into the same chamber and try running. when becomes normal do the regular wash. If the pH value detecting sensor you might have got the error e 4. After adding water this error should have changed!
Apr 17, 2010 | EdgeStar DWP40S Free-Standing Dishwasher
I have a Delonghi Dishwasher that has an Error 4 message.
I ran Delonghi because I was getting the error 4 and it couldnt get past that first draining hoping that they could help but they just referred me to a repair man and told me I couldn't fix it.
The repair suggested that i try checking that the outlet pipe at the S bend wasn't clogged and the I try turning it off and on. I had done that by the on/off button but it didnt change.
So then I actually turned it off at the wall left it a few minutes and then turned it back on and voila..it is back to normal. No more error 4 message and it is working now as we speak
Janne
Nov 15, 2008 | Dishwashers
E4 error message
take off two black covers on bottom front of machine and mop up or soak up any water you feel or see at very bottom of machine by a polystyrene float this will fix it
Dec 27, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
