Question about Kitchen Ranges
I changed the circuit board and am getting error codes PROBE ERROR-WSH PROBE ERROR-BSTR SOME BODY CAN HELP ME TO RESOLVE THIS TROUBLE
5 Suggested Answers
SOURCE: gas heater circuit board
On the bottom door where the blower foor is located,
look on the back of it. It should have a Electrical print
and at the very bottom A Troubleshooting chart for
the control board. It is hard to find but it is on there.
Usually a solid Red means system is ready and good
to go.
Good luck, if you need anymore help let me know.
Posted on Feb 14, 2010
  • 617 Answers
SOURCE: 1988 Dodge Aries K 2.5L Engine Trouble and codes
Trouble Code 14 indicates that the Coolant Temperature Sensor (CTS) is reporting abnormally high readings. CTS is used to control fuel mixture, timing, idle speed, TCC and EGR operations among others. The thermistor used has a low resistance when hot, rising as the coolant cools. This error then, indicates a very low resistance in the CTS circuit.
Trouble Code 15 indicates that the Coolant Temperature Sensor (CTS) is reporting abnormally low readings. CTS is used to control fuel mixture, timing, idle speed, TCC and EGR operation, among others. The thermistor used has a high resistance when cold, lowering as the coolant warms. This error then, indicates a very high resistance in the CTS circuit.
Trouble Code 33 indicates that the Mass Air Flow (MAF) sensor is reporting more air is entering the engine than makes sense based on RPM and TPS. The MAF sensor produces a frequency output; around 30 Hz at idle to 150 Hz under acceleration. The frequency varies proportionally to airflow. The ECM monitors the frequency and thus determines airflow into the engine. Typical idle MAF is 5 to 7 grams per second.
Posted on Feb 18, 2010
  • 78 Answers
SOURCE: Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
Posted on Apr 23, 2010
  • 531 Answers
SOURCE: How to resolve the code error for Sharp AR C262M
I found this for a different model in the same family. Sharp AR-BC320 it may be the same as your problem.
On page 2 it says E7-21 is:
LED controller initial trouble (Cyan)
On page 4 it gives a couple of things to try to fix the problem.
Posted on Sep 21, 2016
Hi there, I have a 2005 Chevy Malibu 3.5L engine with an error code B3948. Does anyone know how to resolve this? Thanks!
See if the signal flashes, buy a new bulb. Some Chevy no longer use a flasher relay, the signal comes from the body computer.
B3935Transponder Authentication Error
B3948Left Front Turn Signal Circuit
B3949Right Front Turn Signal Circuit
B3950Left Rear Turn Signal Circuit
List of Diagnostic Trouble Codes for 2008 2010 HHR Chevy HHR Network
Dec 01, 2016 | 2005 Chevrolet Malibu
Is there a way to reset my oven?
I am not sure how technical you or anyone in your household is and you didn't give a specific oven model, so I don't think anyone can give you detailed instructions on how to do this.
I would disconnect the oven from power/gas/etc and open the cover. I would look for the wires coming from the probe jack and disconnect them from the circuit board. I would then reconnect the oven and check if that resolved the issue. If that did not resolve the issue then I would call 3 repair services to get an estimate based on the error.
Based on the issue including that the oven is stuck on warming, I would not be surprised if an entire circuit board needs to be replaced.
Nov 13, 2017 | In Microwave Ovens
Hobart LXI Dishwasher a P3 code is flashing, seems to be working alright. Thanks to any help
the p3error is an open or shorted booster thermistor.take off btm panel on the right side is the bstr, do when cold and no power to mach.,TURN OFF BREAKER, ON THE UPPER RGT CORNER OF BSTR YOU WILL SEE THE THERMISTOR.unplug from harness use7/16 wrench to unscrew from bstr. well,get new therm.and installyou can get @ any hobart office in your area, part#328994. dont forget to vote, thanks, monomoy
Mar 11, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hello, heater ignites but does not stay on can you solve problem?
May have a bad or dirty flame rod. Look at either the far right or far left burner for a probe in the flame path. Take a toothbrush and scrub the probe. Also check the wire connection at probe as well as circuit board. There should be an error code blinking on the circuit board. You will find an error chart on the wiring diagram pasted to one of the panels. If you have to remove the panel that has the door switch to view the error code, as power shuts off, it will erase the error code. Find a small viewing port and count the number of blinks.
Dec 29, 2009 | Goodman Heating & Cooling
Error code f31 flashing
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 03, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
No heat on rinse cycle HOBART AM14C Dishwasher
3 Con, is the booster heat contactor. If it is chattering, the fault will be in the booster. There are a few different boosters in the AM14. can you post the ML number from the data plate, or describe if the booster is a square Hatco HCM-10, or a round stainless booster with a 13 kw multi wired element.. All boosters use a low water cut off circuit, a high limit thermostat and a control thermostat. The old Hatcobooster uses mechanicqal components, where the new rount tank uses probes and a control board. The board has 3 leds. red is calling for heat, yellow is open thermistor, and green is shorted thermistor.
AM14's had a variety of different control circuit voltages, ranging from 240/208/120 and 24 volt AC. Check the transformer secondary for correct output to controls, trace through circuit until voltage pulses. If new style, it could be just scaled up probes not reading water. Drain the tank with the power off before removing probes.
Jul 03, 2009 | Hobart AM14C-155 Dishwasher
Error code 34... eventually error code 14
How to fix error codes 14 &34 on Carrier Infinity furnace
Mar 30, 2009 | Heating & Cooling
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
