Question about Vacuums
How do I open Windtunnel 2 to check the belt?
How to stop the main belt from comming off the motor shaft on a hoover modle u6634-900/windtunnel
Hello there! If you have replaced the belt and it is still slipping off, you may be not have the right belt for your vacuum. This unit takes a flat belt and a v-belt. Make sure you are replacing the belts with Genuine Hoover Parts. I have included the links below where you may go to order the belts specific to your cleaner.
WindTunnel PowerDrive Belt 2 Pack
WindTunnel Self Propelled Belt
Hope this helps!
Jun 21, 2014 | Hoover Self-Propelled WindTunnel Bagless...
Hoover self-propelled windtunnel U6430-900 flat belt gets hot & becomes hard to push. It has a filter bag. Purchased 8/2/01. Took one plate off bottom. Used a compressor to blow out dirt & dust. ...
Belts get hot when fibers from carpet get wound arounf the belts mounting shaft. Best to take a razor and cut off any fibers so the belt doesn't get hot again
Aug 10, 2010 | Hoover Self-Propelled WindTunnel Bagless...
The Rotary brushes do not rotate/spin when the unit is turned on.
check the belt it may be stretched or broken...also carpet and hair or other debris around the bruches may have it in a bind,,..remove the 2 screws holding the bottom on to check this
Jan 03, 2010 | Hoover V2 U8140-900 WindTunnel Upright...
The windtunnel vacuum has suction but does not pick up the dirt. I'm puzzled as to what might be the problem. Help!
The problem is that the belts are stretched and worn and slip instead of turn the brush when it is put against the resistance of the carpet. You simply need to replace the belts. Here are the (2) belts you need and the manual with instructions:
Hoover self-propelled windtunnel belts
Manual
Jan 02, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
While the windtunnel is upright the suction is awesome. When you lower it and engage the brushes is looses suction. It will not pickup anthing on the floor
check the brushroll if it spins freely, replace the belts 38528-034 and 38528-035. and make sure the tensioner for the V belt engages when you release the handle and pull the head back
Dec 30, 2009 | Hoover U8361-900 WindTunnel 2 Bagless...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5399-900 WindTunnel Vacuum
38528033 is the belt number or just 033.
40201160 is the part number for a 2 pk
sometimes they are referred to style 160 as well
All these are the same belt. Hoover makes things so simple don't they? LOL
Dec 02, 2008 | Hoover U5399-900 WindTunnel Lite Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
