Question about Microsoft Computers & Internet
My Drive C has 0 MB free disk space and have been advised to remove programs.Can I remove any Microsoft Visual C++ Redistributable?There are 6 in all.Do I need them all?
    Habit-Forming:
    New Friend:
  • Microsoft Expert
  • 93 Answers
A Microsoft Visual C++ 2005 redistributable cannot be replaced by a Microsoft Visual C++ 2008 one. The binding would fail and any program that depends on the Microsoft Visual C++ 2005 redistributable will report "This application has failed to start because the application configuration is incorrect. So I think it would be best to leave them.
Posted on Apr 16, 2017
Testimonial: "Thanks for your reply. Much appreciated."
drez
  • 30 Answers
SOURCE: Error message at startup says..."Not enough space for music DB...must free up 6 MB of space.
your going to have to format your mp3 player.
Posted on Sep 11, 2007
mnmus
  • 26 Answers
SOURCE: Microsoft Visual C++ 2005 SP1 Redistributable Package (x86)
Download the update directly from Microsoft, and if you have any error messages, report their content here.
Posted on Jul 17, 2008
  • 18 Answers
SOURCE: My D: drive is 99% full how do I free up disk space ?
Music, video and pictures use the most hard drive space. Store them on a disc or on line storage site. After the delete or removing as advised, defrag you hard drive. This should free up space. Get rid of any programs you don't use. As long as you don't delete hidden files you should be fine. Hope this helps. If you are using windows XP go to start, control panel add and remove programs and delete only the programs that you installed and remove only them.
Posted on Jun 21, 2009
Crankstart
  • 696 Answers
SOURCE: "insert a disk into drive" even when pen drive is attached!
Sounds like a failed circuit either in the USB adapter or in the drive itself. You will most likely require the help of a pro with this one if you need to get your files back.
If there's nothing crucial on it, recycle it and grab a new one, if there is important data on it, reply back with your Country, Sate, City and I will refer you to a nearby Pro.
Chris
Posted on Jul 18, 2009
  • 17 Answers
SOURCE: pen drive display free space 0 byte and used space also 0 byte
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
Posted on Aug 17, 2009
Gfxui stopped working
Solution:
1. Open Control Panel'Click 'Uninstall a Program' (Programs and Features)
2. Look for Microsoft .Net Framework in the list and Uninstall them all (restarting the computer each time it tells you to)
3. Once they are all gone, open the Uninstall a Program (Programs and Features) again and click Turn Windows features on or off on the bar on the left
4. You'd get another window on and you need to uncheck Microsoft .Net Framework 3.5.1 from the list and click OK
5. Proceed with it complete uninstall and restart the computer (when it tells you to)
6. Open the 'Uninstall a Program' (Programs and Features) again and now look for Microsoft Visual C++ Redistributable and uninstall all these as well.
7. Restart the computer and open the Uninstall a Program (Programs and Features) again and click Turn Windows features on or off on the bar on the left and place a check on Microsoft .Net Framework 3.5.1 (it would be a blue square and not a check) and install it again
8. Finally, download & install the Microsoft Visual C++ 2008 SP1 Redistributable Package from Microsoft's website
http://www.microsoft.com/downloads/en/details.aspx?familyid=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=en
Nov 09, 2013 | Computers & Internet
Tip
Freeing up extra hard drive space
Are you out of hard drive space but can't find anything you'd like to remove from your computer?
Maybe you should try doing a Disk Cleanup.
Disk Cleanup will remove unnecessary files from your hard drive and if it hasn't been done on your system previously, free up a lot of space in the process.
To do a Disk Cleanup:
1) Go to My Computer.
2) Right click on your C drive.
3) Click Properties.
4) Click the "Disk Cleanup" button next to the visual representation of your hard drive space.
Disk Cleanup will calculate how much space you can free up and
what should be removed.
5) Under "Files to delete" select any files you don't want or need.
Generally all of the tabs can be selected and none of the files are
needed by your system. Below on "Description" you can view what
the files listed under each tab are for.
6) Once you have selected all of the files you want to remove click OK.
7) Disk Cleanup will remove the files from your system.
Disk Cleanup is complete.
on Dec 21, 2009 | Computers & Internet
Streets and trips 2011 will not install ?
I had a similar problem installing it on Windows 7 SP1. It may not be the same problem you are having on XP, but it is worth trying.
It seems that Streets and Trips 2011 will not install if the Visual Studio 2010 SP1 Redistributable Package is on the system.
  1. Through the control panel, uninstall the Microsoft Visual Studio 2010 SP1 Redistributable Package.
  2. Install Streets and Trips 2011.
  3. Download and install the Microsoft Visual Studio 2010 SP1 Redistributable Package. Don't skip this step, since SP1 gives you important security updates.
Feb 09, 2012 | Microsoft Computers & Internet
My system config is : Intel C2D E7500 with 2.93 GHz CPU MOBO is Intel DG41RQ and 2gb DDR2 RAM OS is Windows XP - 32-bit (Service pack 3) Problem is overall system performance is not good. System is...
A slow computer could becaused by a number of things - 1. InsufficientRAM memory - if your computer has less than 512Mb of RAM then increase it to atleast 1Gb of RAM. 2. Registryproblems - clean and repair the registry, it will contain unused registry keys.Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/removeunused programs, this will also free up hard disk space. 4. Notenough hard disk space - swap file space may need to be increased if Windowshasn't been configured to manage it. 5. Installlatest Windows updates. 6. Updatevirus definition files and scan computer for viruses, Trojans, malware etc. 7. Clearthe Internet cache for faster browsing. 8. Harddisk maintenance is required at least once a month to keep it functioningefficiently. Runthe following programs - Disk Cleanup -removes temporary files that are no longer used and to recovers hard disk space. DiskDefragmenter to make fragmented files into contiguous files and thereforethe hard disk access is faster.
Jul 28, 2011 | Intel DG41RQ Motherboard & Core 2 Duo...
Describe the requirements of foxpro in terms of hardware and memory
System RequirementsTo install Microsoft Visual FoxPro 9.0, you need:
Minimum Requirements Processor
  • PC with a Pentium-class processor
Operating System
  • Microsoft Windows 2000 with Service Pack 3 or later operating system
  • Microsoft Windows XP or later
  • Microsoft Windows Server 2003 or later
Memory
  • 64 MB of RAM minimum; 128 MB or higher recommended
Hard Disk
  • 165 MB of available hard-disk space for typical installation; 20 MB of additional hard-disk space for Microsoft Visual FoxPro 9.0 Prerequisites
Drive
  • CD-ROM or DVD-ROM drive
Display
  • Super VGA 800 X 600 or higher-resolution monitor with 256 colors
Mouse
  • Microsoft Mouse or compatible pointing device
May 17, 2011 | Microsoft Visual FoxPro 9.0 Professional...
What are the hardware requirements for foxpro?
  • Processor: Pentium-class processor
  • OS: Windows 2000 with SP3 or later, Windows XP or later, Microsoft Windows Server 2003 or later
  • Memory: 64MB of RAM min., 128MB recommended
  • Hard Disk: 165 MB of available hard-disk space for typical installation; 20 MB of additional hard-disk space for Microsoft Visual FoxPro 9.0 Prerequisites
  • Drive: CD ROM or DVD-ROM drive
  • Display: 165 MB of available hard-disk space for typical installation; 20 MB of additional hard-disk space for Microsoft Visual FoxPro 9.0 Prerequisites
  • Mouse: Microsoft Mouse or compatible pointing device
from: http://msdn.microsoft.com/en-us/vfoxpro/bb190292
Mar 02, 2011 | Microsoft Visual FoxPro 9.0 Professional...
:Error: the vc8 runtime Redistributable package was not installed successfully. Setup cannot continue
The Microsoft Visual C++ 2005 Redistributable Package (x86) installs runtime components of Visual C++ Libraries required to run applications developed with Visual C++ on a computer that does not have Visual C++ 2005 installed.
This package installs runtime components of C Runtime (CRT), Standard C++, ATL, MFC, OpenMP and MSDIA libraries. For libraries that support side-by-side deployment model (CRT, SCL, ATL, MFC, OpenMP) they are installed into the native assembly cache, also called WinSxS folder, on versions of Windows operating system that support side-by-side assemblies.
System Requirements
  • Supported Operating Systems:Windows 2000 Service Pack 3;Windows 98;Windows 98 Second Edition;Windows ME;Windows Server 2003;Windows XP Service Pack 2
  • Required Software:
  • oWindows Installer 3.0 Windows Installer 3.1 or later is recommended.
  • Disk Space Requirements: 6 MB (x86)
File Name: Size: vcredist_x86.exe 2.6MB Download
Jan 05, 2011 | Sony Computers & Internet
Message says that there is insuffient memory when trying to install or run Windoes 98Se on machine with 2MB Ram
FYI,
Minimum hardware requirements for Windows 98:
1. 486DX 66 megahertz (MHz) or faster processor (Pentium central processing unit recommended).
2. 16 megabytes (MB) of memory (24 MB recommended).
3. Hard disk space may range from between 120 MB and 295 MB, depending on your computer configuration and the options that you choose to install.
4. A full install of Windows 98 on a FAT16 drive requires 225 MB of free hard disk space, but may range from between 165 MB and 355 MB, depending on your computer configuration and that options that you choose to install.
5. A full install of Windows 98 on a FAT32 drive requires 175 MB of free hard disk space, but may range from between 140 MB and 255 MB, depending on your computer configuration and the options that you choose to install.
6. One 3.5-inch high-density floppy disk drive.
7. VGA or higher resolution (16-bit or 24-bit color SVGA recommended).
If your PC does not meet the above minimium requirements, you are bound to get errors popup installing or running software.
Hope it helps.
Oct 30, 2010 | Microsoft Windows 98 for PC
Cannot open Quik Books 2007
Windows XP:
  1. Uninstall QuickBooks, Microsoft .NET Framework, and Microsoft Visual C++ 2005 Redistributable:
    1. Close QuickBooks.
    2. Click the Windows Start button and select Run.
    3. Enter control in the Open field and click OK.
    4. Double-click Add or Remove Programs.
    5. Right-click your QuickBooks program version and click Change/Remove.
    6. Follow the instructions to Uninstall QuickBooks.
    7. Repeat steps d through f to uninstall Microsoft Visual C++ 2005 Redistributable.
    8. Repeat steps d through f to uninstall Microsoft .NET Framework for your version of QuickBooks:
      • QuickBooks 2008 and 8.0 and later:Microsoft .NET Framework 2.0
      • QuickBooks 2007 and 7.0 and earlier:Microsoft .NET Framework 1.1
  2. Rename the QuickBooks program folder:
    1. Right-click the Windows Start button and select Explore.
    2. Browse to C:\Program Files\Intuit.
    3. Right-click the QuickBooks folder for the version you just uninstalled (for example, QuickBooks 2008) and select Rename.
    4. Enter OLD_ at the beginning of the folder name and press Enter (for example, OLD_QuickBooks2008).
  3. Insert the QuickBooks CD in your CD drive, and follow the instructions to install the program.
  4. Open QuickBooks.
Jul 09, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Problem installing AVG free: error 0x800736b1
Change the name of the destination directory ( ex: C:\Program Files\Yahoo2 ) ...it works for me.
First reinstall Microsoft Visual C++ 2005 Redistributable from here:
http://www.microsoft.com/downloads/details.aspx?familyid=32bc1bee-a3f9-4c13-9c99-220b62a191ee&displaylang=en
Apr 27, 2008 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
