Question about Refrigerators
Freezer door was left open, now lights won't come back on, and temp controls don't light up
  • 1462 Answers
SOURCE: bosch classixx refridgerator
the evaporator is probably iced up and hence poor air flow. (i am assuming it is a frost-free type). switch off and leave for 24 hours with door open is the easy cure. otherwise, remove the back inside panel of the freezer and melt off the excess ice with a hairdryer used carefully
Posted on Jun 03, 2007
  • 66 Answers
SOURCE: whirlpool GD5RHAXNQ SIDE BY SIDE, CHIRPING NOISE WHEN LIGHT IS PLUGGED IN
short in the control panel. or the ground in the control panel is loose.
Posted on Dec 26, 2007
SOURCE: Hotpoint FFS70 fridge/freezer
water keeps appearing beneath salad bin we have checked to see that nothing has come into contact with back wall of fridge ,and we have used a straw to keep the defrost gutter drain hole clear but water still appearing beside gutter drain hole .
Posted on Mar 02, 2008
aborcass
  • 2651 Answers
SOURCE: left ge stainless steel fridge and freezer door open acciently
youll need to unplug and defrost all the ice from hte back panel, leave unplugged for a min of 24, hours, then plug back in you should be fine. way too much ice has built up behind hte inner panel ,cutting of all air flow to both compartments.you did no real harm( other then losing your food
Posted on Nov 28, 2008
SOURCE: Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Posted on Dec 12, 2008
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Sep 30, 2016 | Samsung Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Bosch frost free freezer
no just a reaction to the door being left open give it a chance to get use to the correct temp again and should stop flashing
Nov 01, 2013 | Freezers
Ge profile 2004 open door and temp controls off shut door open they come back on light was staying on sometimes to bottom half of coils in freezor froze freezer working but temp in frig 50s on off fri
It is possible the refrigerator is low on Freon. You will need to remove the back panel inside the rear of freezer to examine the evaporator coils. If only a few rows have frost it will be time to replace the refrigerator. If the control panel in the freezer dispenser are coming on and off there may be a bad connection in the plug under the top left door hinge cover. Check that the plug is tight. Let me know what you see first behind the freezer wall, Thanks Sea Breeze
Dec 12, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Kenmore Elite Model # 795.77579600: The upper inside lights began working intermittently and now will not come on when either door is opened. Both bulbs check out and illuminate when tested in a lamp...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 22, 2011 | Kenmore Side by Side Refrigerator
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
Lights come on when door opens but does not seem to cool. Lights which used to indicate temp setting for freezer and refridgerator do not come on at all. Freezer is not cooling at all. But lights do...
The thing i would check was the main control board on the back on the side about a foot and half up LEFT SIDE. It seems to be that the things that are conrtolled by low voltage are out because the board has fried. In most cases it's pretty easy to see if the board is the problem, by removing the cover there and you will see soot and burnt components on the board.
Gene
Aug 19, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Evap motor runs when in defrost but when you close freezer door motor stops running. Do you think it may be the computer board. The customer is advising one morning temps in freezer was at 30 degrees then...
Air temp in freezer could be up if unit is in defrost cycle, but temp of packages would not vary much from such a short temp increase. Fan will turn on if door is left open for several minutes to prevent damage from freezer light bulb heat. By the way, this is a Fix-Ya to a fellow servicer.
Jan 09, 2009 | GE Profile PTS22LCSWW 33" 21.7 Cu. Ft....
Whirlpool GD5RHAXNQ SIDE BY SIDE, CHIRPING NOISE WHEN LIGHT IS PLUGGED IN
Dec 26, 2007 | Whirlpool ED0GTQXMQ Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
