Question about Dishwashers
Our dishwasher has the message e4 on display - Dishwashers
  • 100 Answers
You don't say which dishwasher you have..
But e4 is normally antiflood... At the bottom of most dishwasher is a plastic tray that catches leaks and condensation, If water builds up in it the float switch trips.
Depending upon your abilities, it is possible to get the water out using a sponge or cloth... if you are successful and it happens again in a short space of time you might have a leak which will require further investigation.
Posted on Apr 16, 2017
Logik dishwasher E4 error message
I am having difficulty with my logik slimline dishwasher. E4 message about 30 minutes into cycle. Where the salt goes is always full of water. Please can someone help me
Nov 17, 2012 | Dishwashers
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Feb 27, 2011 | Kenwood KDW243A Builtin Dishwasher
Dishwasher was mid cycle and then displayed e4 error message. Manual says something about over-filling (water) but it is not clear how to rectify problem. Do you have suggestions for me please?
Check and make sure that dishwasher is draining all the way out. If not clean the sump inside under the spray arm and or the drain lines and back check valve.
Nov 30, 2010 | Dishwashers
My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
Hope this help?
Nov 02, 2010 | Kenwood KDW243A Builtin Dishwasher
Disherwash is showing e4 what does it mean
The E4 error is not usually associated with newer dishwashers. Older Kenmore dishwashers with digital displays would show an E4 error when the selector switch pads/buttons were stuck. You need someone In to look at it im afraid
Sep 25, 2010 | Kenmore 15762 Dishwasher
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
E4 message
take of the btwo black panels at the bottom of the dishwasher and put in a towel to soak up thje excess water this works for me everytime
Jul 31, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
E4 error message
take off two black covers on bottom front of machine and mop up or soak up any water you feel or see at very bottom of machine by a polystyrene float this will fix it
Dec 27, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dishwasher time E4
e4 for most products means it must be reaplaced contacted the company they should be able provide a replacment
Oct 15, 2007 | Kenmore 46123 Stainless Steel Electric...
Dishwashers Logo
Top Dishwashers Experts
