Question about SanDisk Sansa e250 MP3 Player
Unableto connect to PC
I am unable to conect my Sansa e250 to my PC, But it shows connected in my mp3 player, but there is no instance in my PC.
  • 626 Answers
You have to have Windows Media Player version 10 or higher, if you do not then the device will not install correctly.
If this does not apply, then check the Device Manager for errors while the device is connected. If you see any RED or YELLOW errors listed, right click on them and select un-install.
Disconnect the device and re-connect it to install the drivers.
If that doesnt work, add to the message and we can go from there.
Best of Luck.
Please RATE my solution BELOW.
Posted on Nov 21, 2007
Multiple copies of songs on sansa e250. Unable to delete them.
this will be bery hard for you you need a pc and erase all the files one-one My suggestion format the sansa and clic your pc ONLY ONCE DUD {RATE ME}
May 13, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 mp3 player is unable to connect to computer nor recognized to use .It won`t turn on change the modes
turning on to change modes is your problem. If it's completely dead you may need to replace it or refurbish it. Or if the battery is completely dead plug it in all day until you can get it to turn on. ONCE ON then you can worry about getting it to connect. Try this:
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Jan 18, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 won't show up in devices!
I had the same issue. Brand new Sansa e250 player. My XP SP2 computer would not recognize it. I updated my Windows Media player to version 10. Bingo, all is working now. I previously had version 9. Good luck!
Dec 24, 2007 | SanDisk Sansa e250 MP3 Player
Problem in charging
try performing recovery mode on the player then after performing recovery mode update the firmware of your player. Recovery mode is > Enable Hold Switch + Press Record Button + Menu Button
Oct 06, 2007 | SanDisk Sansa e250 MP3 Player
I have some china made mp3
Make sure that you have installed the software the the mp3 player came with and that you have powered on the mp3 player once it is connected. If you want the Sansa e250 to show up in "My Computer" under removable devices, go to the main menu of the player software and go to Settings/USB Modes/ and change the mode to MSC (Mass Storage Class). Hope that helps.
Aug 17, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
You mp3 player might need to be formated. Open up my computer, right click your mp3 player and click "format"
Aug 02, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
Try Formating the Sansa. 1.My Computer 2.Right click the sansa icon 3. clock Format. Let me know if this solved your problem. D.
Jul 28, 2007 | SanDisk Sansa e250 MP3 Player
First switch your USB control to MSC. Then turn off your mp3 player and activate the hold icon. Then turn it on while holding the record button with hold icon still being activated. then it will go to recovery mode. Now plug your sandisk into the computer and wait until it says RECOVERY COMPLETE...PLEASE DISCONNECT or when it just says for you to disconnect. This worked on my sandisk, and it hopefully work for you.
Jan 13, 2007 | SanDisk Sansa e250 MP3 Player
ok, mine had the same problem, first go to settings, then USB mode and switch it to MSC, plug it into your computer and it should show up, then format it, this will erase everything but then u can put it back on, after you format it you can switch it back to MTP mode, its alot better, hope i helped
SanDisk Sansa e250 MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
