Question about Cell Phones
Test Test Test - Cell Phones
What are the codes for Samsung Android phone
Samsung secret code by Mubarak Sulaimon
*#06# - IMEI number
*#0*# - Enter the service menu on newer phones like Galaxy S III
*#*#4636#*#* - Phone information, usage statistics and battery
*#*#34971539#*#* - Detailed camera information
*#*#273282*255*663282*#*#* - Immediate backup of all media files
*#*#197328640#*#* - Enable test mode for service
*#*#232339#*#* - Wireless LAN tests
*#*#0842#*#* - Backlight/vibration test
*#*#2664#*#* - Test the touchscreen
*#*#1111#*#* - FTA software version (1234 in the same code will give PDA and firmware version)
*#12580*369# - Software and hardware info
*#9090# - Diagnostic configuration
*#872564# - USB logging control
*#9900# - System dump mode
*#301279# - HSDPA/HSUPA Control Menu
*#7465625# - View phone lock status
*#*#7780#*#* - Reset the /data partition to factory state
*2767*3855# - Format device to factory state (will delete everything on phone)
##7764726 - Hidden service menu for Motorola Droid
Update x1: More codes!
*#*#7594#*#* - Enable direct powering down of device once this code is entered
*#*#273283*255*663282*#*#* - Make a quick backup of all the media files on your Android device
*#*#232338#*#* - Shows Wi-Fi MAC address
*#*#1472365#*#* - Perform a quick GPS test
*#*#1575#*#* - For a more advanced GPS test
*#*#0283#*#* - Perform a packet loopback test
*#*#0*#*#* - Run an LCD display test
*#*#0289#*#* - Run Audio test
*#*#2663#*#* - Show device's touch-screen version
*#*#0588#*#* - Perform a proximity sensor test
*#*#3264#*#* - Show RAM version
*#*#232331#*#* - Run Bluetooth test
*#*#232337#*# - Show device's Bluetooth address
*#*#7262626#*#* - Perform a field test
*#*#8255#*#* - Monitor Google Talk service
*#*#4986*2650468#*#* - Show Phone, Hardware, PDA, RF Call Date firmware info
*#*#1234#*#* - Show PDA and Phone firmware info
*#*#2222#*#* - Show FTA Hardware version
*#*#44336#*#* - Show Build time and change list number
*#*#8351#*#* - Enable voice dialing log mode, dial *#*#8350#*#* to disable it
##778 (+call) - Show EPST menu
These codes are specific to HTC devices only:
*#*#3424#*#* - Run HTC function test program
*#*#4636#*#* - Show HTC info menu
##8626337# - Run VOCODER
##33284# - Perform field test
*#*#8255#*#* - Launch Google Talk service monitor
##3424# - Run diagnostic mode
##3282# - Show EPST menu
##786# - Reverse Logistics Support
WLAN, GPS and Bluetooth Test Codes:
*#*#232339#*#* OR *#*#526#*#* OR *#*#528#*#* - WLAN test (Use "Menu" button to start various tests)
*#*#232338#*#* - Shows WiFi MAC address
*#*#1472365#*#* - GPS test
*#*#1575#*#* - Another GPS test
*#*#232331#*#* - Bluetooth test
*#*#232337#*# - Shows Bluetooth device address
*#*#8255#*#*
This code can be used to launch GTalk Service Monitor.
Codes to get Firmware version information:
*#*#4986*2650468#*#* - PDA, Phone, H/W, RFCallDate
*#*#1234#*#* - PDA and Phone
*#*#1111#*#* - FTA SW Version
*#*#2222#*#* - FTA HW Version
*#*#44336#*#* - PDA, Phone, CSC, Build Time, Changelist number
Codes to launch various Factory Tests:
*#*#0283#*#* - Packet Loopback
*#*#0*#*#* - LCD test
*#*#0673#*#* OR *#*#0289#*#* - Melody test
*#*#0842#*#* - Device test (Vibration test and BackLight test)
*#*#2663#*#* - Touch screen version
*#*#2664#*#* - Touch screen test
*#*#0588#*#* - Proximity sensor test
*#*#3264#*#* - RAM version
May 04, 2016 | Samsung Cell Phones
Tip
Field Test
The test mode display is activated through the test mode command: <b>*3001#12345#</b>. Once you enter this command, you are given a list of options, including 'Field Test'. Select Field Test and then hit 'Enabled'. You must power down the phone and power it up again to get out of the test mode menu. The test mode screens may vary somewhat between different firmware versions and providers.<br /> Once you power up the phone you are given a new menu choice at location 10 called 'Field Test'. There are several different test mode screens. Type in a test number to get the screen listed below. Alternatively you may use the arrow buttons to move between the 199 different field test screens. Entering test number '0' will disable the test mode, but will still allow you to access the test menu.<br /> If you are using the field test mode and are unsure what the screens mean then hold down the # key for about four seconds to get a brief description of the screen. Repeat holding the # key to return to the test mode values. <b>Thanks to L. Tee for this tip</b><br /> If you would like to see what is behind the test mode screen then keyguard the phone, wait until the 'press unlock and then *' screen disappears, and then press one of the numeric keys to see the regular screen. <b>Thanks to L. Tee for this tip</b><br /> Note: If you make or receive calls while in test mode, you may not be able to change the speaker volume. To turn off the field test mode you can select field test '0' or enter a few digits and then clear these digits.
on Jun 19, 2011 | Cell Phones
Blood test abbreviations list
Common Blood Test Abbreviations
  • ALT - Alanine Transaminase (part of liver function test)
  • ANA - Antinuclear Antibody (part of liver function test)
  • AST - Alanine Aminotransferase (part of liver function test)
  • BAC - Blood Alcohol Concentration
  • BMP - Basic Metabolic Panel (a group of tests)
  • BNP - Beta Natriuretic Peptide (testing for congestive heart failure)
  • BUN - Blood Urea Nitrogen (part of kidney function test)
  • CA - Calcium (test blood calcium levels)
  • CBC - Complete Blood Count (test red and white blood cells)
  • CK - Creatine Phosphokinase (test for muscle damage)
  • CR - Creatinine (part of kidney function test)
  • ESR - Erythrocyte Sedimentation Rate (tests for inflammation)
  • HCT - Hematocrit (part of the CBC test)
  • HDL/LDL - High Density Lipoproteins/High Density Lipoproteins (testing for good and bad cholesterol)
  • INR - International Normalized Ratio (blood clotting test)
  • K - Potassium (test for potassium levels)
  • Mg - Magnesium (test for magnesium levels)
  • Na - Sodium (test for sodium levels)
  • PSA - Prostate Specific Antigen (prostate cancer test)
  • PT - Prothrombin Time (test blood clotting)
  • RBC - Red Blood Cell Count (part of the CBC test)
  • TPO - Thyroid Peroxidase Antibodies (test for antibodies to thyroid)
  • Trig - Triglygerides (part of cholesterol test)
  • TSH - Thyroid Stimulating Hormone (one of the main tests of a thyroid test)
  • WBC - White Blood Cell Count (part of the CBC test)
Jan 29, 2014 | Health & Beauty
Activation code
LG 900 v09e
Citazione:
TEST MENU: 277634#*#
LG 900 v10b
Citazione:
TEST MENU: 082065#*#
LG U970 Shine
Citazione:
TEST MENU: 26911147#*970#
LG L600V
Citazione:
TEST MENU: 63342425#*#
LG KU310
Citazione:
ENGINEER MODE: *72346#96
LG KU800
Citazione:
TEST MENU: 26911147#*#
LG KU830
Citazione:
LG KU950
Citazione:
TEST MENU: 7973845#*#
ENGINEER MODE: 21738#96
LG KU990 Viewty
Citazione:
TEST MENU: 3845#*990#
ENGINEER MODE: 364663#96
MENU NCK: 2945#*990#
LG Rhythm
Citazione:
TEST MENU: 2945#*#
Feb 27, 2012 | LG Cell Phones
The bottom half of some lines of text are missing
First of all what is your printer model and manufacturer? What is your computer's operating system? What program/application are you using when printing?
If you are using windows xp or any Microsoft windows operating system, try to print from notepad to check if this happens as well from a generic windows application.
Click Start > Run > type in the box notepad then press ok
from there type a couple of lines about 10 - 15
example:
test
test
test
test
test
test
test
test
test
test
test
test
test
and check if the issue occurs. If it occurred as well in notepad then it is just a format setting in your application.
Jun 12, 2008 | Office Equipment & Supplies
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
