Question about LG Refrigerators
Guys can you help on how to open the fan on the freezer, cause its not functioning i should replace it but idont know how to open. my refregerator is lg gr-t382sv. thanks
  • 210 Answers
SOURCE: i have a lg top freezer, model GR-s462GC
the problem is most likely a thermal fuse, located in the freezer on the evaporator, has blown. The lights on are indicating an error code. If you unplug the unit and then replug it, it will run until it hits the defrost cycle. This will at least keep your food cold until you can get service.
Sgt 48
Posted on Jun 01, 2008
IFIXALL
  • 868 Answers
SOURCE: Refregerator
if your sure its not working ,you have to remove the cover in the freezer on the back wall and it requires a volt meter to make sure its not working.
Posted on Jun 13, 2008
breddi2
  • 126 Answers
SOURCE: I have a LG refregerator.Two
the water is from defrosting coil in rear of freezer and there is a drain pan under coil to make water drain to pan under unit where it evaporates from compressor heat.possible cause for water not going where it is supposed to is drain is clogged with foreign matter or frozen shut.I would suggest checking door gasket seals if you are getting this often moisture is getting in and causing lots of frost for unit to deal with and could lead to a repetitive problem.
Posted on Apr 19, 2009
woodchuck789
  • 4070 Answers
SOURCE: fridge LG GR-2985QF with bottom
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Posted on Mar 08, 2011
regan580
SOURCE: I have an LG ref
Furthermore, I have left it open/unplugged and thoroughly defrosted it, and it worked fine except when it defrosted water would run from the rear of the fridge (past the lights) and run out from the fridge to the kitchen floor. It is not accumulating in the rear compartment.
Posted on Oct 14, 2011
REFREGERATOR NOT COOLING
You have a ice obstruction,or fan in freezer may not be moving air to fresh food part of fridge, or the defrost heater may not be working.try YouTube
Dec 22, 2017 | Refrigerators
Fridge warm, freezer cold. repair guy said its fine if milk is not spoiling. but set at 6 coldest temp is around 40
Can you feel air movement from the freezer to the refrigerator side through the cooling tubes when the evaporator fan is operating?
If not you might have some ice build up in the cooling tube that is not allowing the refregerator to get cold enough. Try a hair dryer to clean it.
Aug 19, 2011 | Frigidaire FRS26R4A Side by Side...
My refregerator are not properly coolin my food properly. and ice appear\r\nto be sticking to the back wall of the freezing part
You have a blocked drain causing the ice and also the fan is picking is up and pushing it.
This will also impair cooling.
Feb 13, 2011 | Continental Freezer Wide...
GE Profile GSS25LGMB
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 05, 2009 | GE GSS25LGM Side by Side Refrigerator
Freezer gets cold but refregerator is warm and in the back there is two wires that dont go to any thing they are just taped to the side wall, please help
The two wires may be unrelated to the fridge problem. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 04, 2009 | Refrigerators
Freezer works but refregerator is warm
If this is the model I am thinking about, you have the same compressor for each side. There should be a vent or opening that you can adjust to let cool air inside the refrigerator. Find it and adjust. You may have this opening blocked by something. Let me know if this fixes the problem.
Jan 24, 2009 | GE GBS18HBM Bottom Freezer Refrigerator
Refregerator
Jun 13, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
27 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
