Question about Garden
In inches, how long is engin to transmission 539124518 belt
My 2007 ford Freestar squeals every time I accelerate
sounds like it may be nothing more than a lose belt. have a mechanic check the belt tension. You can check the tension yourself by pressing down on each belt with the engine off. If the belt moves more than an inch or so it should be tightened. Only other explanation would be a transmission slip.
Oct 04, 2013 | 2005 Ford Freestar
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Where is the transmission dipstick on a 96 mazda mpv 4wd
My 2WD 1996 Mazda MPV transmission dipstick is a black stick, from out side, it look about a foot long from bottom to top with a black handle that is about 2 inches long and 3/4 inch wide. It is locate between the battery and the engine, actually, the top of it is a little bit lower than the bottom of the battery and closer to the front of the engine where the belts are.
Feb 26, 2012 | 1996 Mazda MPV
I cant find the transmission dipstick on my 96 mazda mpv 4wd
My husqvarna mower has quit moving. The engine runs smoothly but when I shift out of neutral, nothing happens. It stopped working suddenly. I have moved the small lever in the back that allows you to...
either the drive belt from the engine to the top of the transmission has broken or gone slack due to a tensioner issue, or the transmission has failed. with the engine NOT running you can put your hand up under the deck and feel the topmost belt, if it is there and snug, then you have a transmission problem and that requires a replacement.
May 25, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I recently changed the alternador belt on a 2001 chevy metro lsi, afterwards whenever i start the car , there is this rattling noise and when i opened the hood to check , to the left of the alternador...
Water Pump REMOVAL & INSTALLATION Metro
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the cooling system.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Air cleaner
    • A/C compressor suction pipe bracket, if equipped
    • Loosen the water pump pulley bolts. Do not remove them at this time
    • Right side lower splash shield
    • A/C compressor drive belt
    • Lower alternator cover plate
    • Water pump/alternator drive belt
    • Crankshaft pulley
    • Water pump pulley
    • Timing belt
    • Dipstick tube
    • Upper alternator bracket from the water pump
    • Water pump and discard the gasket
    To install: Fig. 1: To ensure a tight seal, be sure gasket surfaces are properly prepared - Metro 7922z704.gif
  4. Clean the gasket mating surfaces thoroughly.
  5. Install or connect the following:
    • Water pump with new gasket. Torque the bolts to 115 inch lbs. (13 Nm).
    • New rubber seals
    • Upper alternator adjusting bracket
    • Oil dipstick tube
    • Timing belt
    • Water pump and crankshaft pulleys. Leave the water pump pulley bolts hand-tight
    • Alternator drive belt
    • Lower alternator cover plate. Torque the bolts to 89 inch lbs. (10 Nm).
    • A/C compressor drive belt, if equipped
    • Right side lower splash shield.
    • Torque the water pump pulley bolts to 18 ft. lbs. (24 Nm).
  6. Adjust the water pump drive belt tension and torque the alternator adjustment bolt to 17 ft. lbs. (23 Nm).
  7. Install or connect the following:
    • Air cleaner
  8. Refill the cooling system.
  9. Start the engine and check for leaks, repair if necessary.
Prizm 1.6L ENGINE
  2. Drain the engine coolant.
    • Negative battery cable and properly support the engine
    • Right side engine mount and support
    • Upper and middle timing belt covers
  4. If equipped with power steering remove the following components:
    • Front transmission mount
    • Radiator fan motor
    • Coolant reservoir
    • Upper radiator hose
  5. Remove or disconnect the following:
    • Crankshaft Position (CKP) sensor electrical connector from the dipstick tube
    • Dipstick tube
    • Engine Coolant Temperature (ECT) sending unit
    • Coolant inlet pipe
    • Water pump and discard the O-ring Fig. 2: Remove the coolant inlet pipe from the block, then the pump - Prizm 7922z705.gif
    To install:
  6. Install or connect the following:
    • New O-ring and Water pump. Torque the bolts to 10 ft. lbs. (14 Nm).
    • Coolant hose to the pump
    • Coolant inlet pipe. Torque the fastener to 11 ft. lbs. (15 Nm).
    • Dipstick tube. Torque the bolt to 89 inch lbs. (10 Nm).
    • ECT sending unit to the dipstick tube
    • Engine wire harness. Torque the bolt to 89 inch lbs. (10 Nm).
    • Radiator fan. Torque the bolts to 52 inch lbs. (6 Nm).
    • Coolant reservoir
    • Front transmission mount. Torque the bolt to 47 ft. lbs. (64 Nm).
    • Upper and middle timing belt covers. Torque the bolts to 62 inch lbs. (7 Nm).
    • Right side transmission mount and insulator. Torque the bolt to 47 ft. lbs. (64 Nm).
  7. Fill the cooling system.
  8. Start the vehicle and check for leaks, repair if necessary.
1.8L ENGINE
    • Drive belt
    To install:
  4. Install or connect the following:
    • New O-ring and water pump. Torque the bolts to 8 ft. lbs. (11 Nm).
    • Drive belt
  5. Fill the cooling system.
  6. Start the vehicle and check for leaks, repair if necessary.
Jan 02, 2011 | Chevrolet Metro Cars & Trucks
Need to change the alternator on a 2001 sunfire,2.4 engine,how do i do that?
Things You'll Need:
  • Battery terminal wrench
  • Serpentine belt removal tool
  • 3/8-inch ratchet
  • 3/8-inch metric socket set
  1. Turn off the engine and place the transmission in park (automatic) or first gear (manual). Engage the parking brake and open the hood. Disconnect the negative cable from the battery terminal using the battery terminal wrench.
  2. Remove the serpentine belt by inserting the end of the serpentine belt tool into the square hole on the belt tensioner and rotating the removal tool clockwise. Unplug the alternator's electrical connector. Remove the bolt holding the positive voltage cable to the alternator using a 3/8-inch ratchet and a metric socket. Remove the positive voltage cable from the alternator.
  3. Remove the alternator bracket bolts using a metric socket connected to a 3/8-inch ratchet. Remove the alternator from the car. Place the new alternator in the mounting brackets and reinstall the mounting bolts using a 3/8-inch ratchet connected to a metric socket.
  4. Reinstall the positive voltage cable on the alternator and tighten the retaining nut using a 3/8-inch ratchet and a metric socket. Plug in the alternator's electrical connector. Compress the serpentine belt tensioner using the serpentine belt tool. Reinstall the serpentine belt according to the belt-routing diagram located under the hood.
  5. Reconnect the negative cable to the battery using the battery terminal wrench. Start the engine and verify that the alternator works.
Oct 29, 2010 | 2001 Pontiac Sunfire
Need to replace drive belt, but can't get the front pulley (under engine) off of a Huskee 42" 13AQ698G131
I have the same model and am in the process of replacing the drive belt. To get it on the front (engine) pulley, I had to take out the 4 engine bolts and jack up the engine about 3 inches. Go slow because exhaust manifold is still attached. Once the pulley was about 1/2 inch above the frame plate I was able to slide the belt up through the frame and onto the pulley. Tractor Supply Co said it was a 77 inch belt, but I'm not sure since now I can't get the belt over the fan and around the transmission pully. I'm afraid I'll have to take it off the engine again and put it on the transmission first.
Apr 19, 2010 | Mtd Garden
17 hp rider mower 42 inch cut. willnot move in any gear or reverse. how does this transmission work?
it uses the belt as a clutch so that would be the first thing to check
Oct 18, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
