Question about Casio Televison & Video
Casio FV600 projection lcd tv. My this tv one bad man hand by lost this lc tv power supply board from c7.c8.and voltage reguletar ic q1.q2 q3 q4 and lamps blast many pins
3 Suggested Answers
  • 3614 Answers
SOURCE: amana sxde25j high voltage board blown..
hi there,
you can try to this store to order the parts to be replaced part number & description was also indicated in HERE.
just let me know, for further assistance,
Posted on Apr 21, 2009
Tv won't turn on. replaced bad caps and after some testing it turned out that the power supply board wasn't giving the supposed voltages.
This problem is not easily to be solved.Tries to changes all the capacitors components even if u think is good around the bad capacitors surrounding area.After that,if u still have the same problems.This problem could be any high voltage components parts like transformers to ICS power regulator.Trying to fix this power supply board probably beyond your ability and u must also have the tv power supply board original schematic and electron scope too . .To measure those power transformers and ics power regulator output.Tries websites like, to buy a whole new refurbish tv power supply board for the replacement that is ur best bet.
Sep 27, 2012 | Insignia NS-LTDVD19-09 LCD TV
Red light won't turn to green
This is a common problem. There are several capacitors on the power supply and logic board that are bad. Replacement of these parts has restore all units that I have looked at.
On the power supply I would replace at a minimum:
C14 - 4.7ufd 50v UPW1H4R7MDD
C4 - 1ufd 50v UPW1H010MDD
C8 - 100ufd 25v UHE1E101MED
C10 - 470ufd 16v UHE1C471MPD
C12 - 1000ufd 10v UHE1A102MPD
There are 4 others in the supply that were not grossly bad.
C1 - 22ufd 400v EEU-EE2G220
C7 - 220ufd 25v UHE1E221MPD
C11 - Same as C10
C13 - Same as C10
Logic board:
E5 - 33uf 35v EEU-FM1A471
E6 - Same as E5
Part Numbers of replacement caps are Nichicon or Panasonic.
Note: Caps on the logic board are extremely hard to replace due to the internal ground plane.
Jan 12, 2011 | Digi Channel Master/tal to Analog...
I have a mitsubishi vs-4541/4542 tv with sound and no picture. What are my options?
I have not repaired this particular model. If this TV is a projection set,you have one of two possible problems. First....You may have convergence IC that has lost a ground contact to the signal board. We are discussing the board that has all your RCA connections and RF connectors. You may have to replace, possibly a STK-XXX series convergence IC. One or two capacitors near this IC, usually a bad cap will end the life of an IC and resistors. And replace a couple of resistors, these are standing tall next to the convergence IC. The next problem could be on the power supply. The power supply will almost always have the flyback transformer on it. If you can locate the vertical IC..This IC may need resoldering. You will see rings around the pins of the vertical IC. Replace the three or four capacitors next to the IC. A bad capacitor will overheat an IC and cause solder grounds to separate. Thanks for asking and show a few hands of support!
Dec 09, 2010 | Mitsubishi Televison & Video
Sharp AQUOS LC-32D44U 32 in. LCD TV turns off after a few seconds
Its the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this help in solving the problem, take care
Sep 14, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
LC-46D43U Lcd display broke on inside. The screen is fine. Have sound no picture, just a bad spot and some lines. How can I fix this?
If the LCD Display is broke, only replacing the LCD Panel will fix it. The Main problem is that the cost of doing this would exceed the cost to replace the whole unit. I am sorry about the bad news.
Nov 15, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Casio fv600 projector
Use the video input, with the stereo audio and you will be fine. good luck
Jul 07, 2009 | Televison & Video
The rca tv will not power up 55 inch
Is it a rear projection set? or LCD? If it is a projection set it could be a bad High voltage splitter. Part is about $30 If it is LCD it could be a bad power supply or inverter board. A good tech can replace capacitors in power supply without replacing the board
Mar 13, 2009 | Televison & Video
Directv DVR R15-500 problem
I had a similar problem the orange record light was on and the unit could not be turned on. I didn't want to replace the unit since all recording would be gone. After some googling I found that the problem was related to the power supply. I found three capacitors with swollen tops 2 1000uf@10V and 1 1200uf@10v. I replaced them and everything works again.
Dec 05, 2008 | Televison & Video
Ricoh Aficio CL3500N error code SC581
Q1 - Possibly, I have not seen an SC581 error before. Usually using too much power would give you something like an SC240 error "Power Supply Excessive". So it depends on the extent of the damage. You could also have to replace the main board, motors, etc.
Q2 - You will have to pull back the feeder tray, remove the back panel, there is a cover over the main board and the power supply is below it and fairly easy to get to. But if other components were damaged it could be a much more involved repair.
Jul 24, 2008 | Ricoh Aficio CL3500N Laser Printer
Televison & Video Logo
Top Casio Televison & Video Experts
Lawrence Oravetz
Level 1 Expert
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
