Question about The Home Security
What is the combo for a 2311 safe? - The Home Security
Zip code for 2311 Aspen Road, Ames, Iowa
2311 Aspen Rd Ames, IA, 50010 - Condos for Rent ' Zillow
www.zillow.com > Iowa > Ames > 50010
ZillowView 10 units for 2311 Aspen Rd Ames, IA, 50010 - Condos for Rent, as well as ... Ames Middle (assigned). 6-8 ... Nearby ZIP codes include 50012 and 50013.
2311 Aspen Rd Unit 101, Ames IA, 50010 ' Homes.com
Dec 16, 2015 | Computers & Internet
I put my combo on my model s0310 safe for the first time and unable to open safe with the combo I inputed. is there a way to use th keys or bypass combo
The safe can be opened using the factory set 5 digit code found on the documentation that came with it. You can also call 1-800-828-1438 with the serial number and get help.
Dec 25, 2014 | Home Security
Apple tv doesn't work when hooked up to denon 2311 receiver. Apple tv is turned on but tv screen displays the word
http://usa.denon.com/documentmaster/us/avr-2311ci_lit527.pdf
This is the link to the probable box in question. The Apple TV needs to be connected to HDMI input port (pick on of the six available). Follow setup instructions.
Jun 08, 2012 | Audio Players & Recorders
I have a Sentry safe S5741. I have the electronic combo and the key. The door to the safe was locked with the door open. Now the door will not unlock to shut the door. Is there trip to reset the door? Is...
Try changing the batteries first. No the electronic combo would not be erased unless someone previously changed the combination. There is probably something causing the bolts to not retract. The lock may fail if there is any pressure on the bolts and or the door of the safe. Hopefully this information helps.
Jul 12, 2011 | Sentry Fireproof Safe
I forgot my combination i tried putting a couple different numbers in after three trys the key pad locked and now when i type any numbers in it doesnt work. how do i unlock my safe?
after 3 trys the keypad does go into lockout mode but it should only last for about 15 minutes and then let you retry 3 more codes to try and open. if you still do not know what the combo is you can usually call the maker of the safe and with the serial number you might be able to get the original combo that the safe was set to when it was purchased ( this is a factory set combo ) --- now if that does not work, your next step will be to call a safe tech ( locksmith ) to set up a auto dialer,, this takes about a full 24 hours to get the combo right. the safe tech can also drill a small hole behind the dial and manually remove the locking bolt. after the safe is opened the locksmith will fill the hole and reset the combo for you ( also replace the battery at this time too ).
c...
Jan 15, 2011 | Stack-On Stack On 16 Gun Safe with...
Lost the combo to my sentry 1610 safe, need the company master combo
Hi.
If you have lost the combination you need to follow detailed procedure needed to retrieve the key from Sentry. For security reasons there is no other way to get a master combo.
Please follow the instructions detailed in this link.
Regards.
Ginko.
Nov 16, 2010 | Sentry Safe Fire-Safe Personal Safe
I need to know how to erase the old combo and set a new combo. I only want the new combo to open the safe. Sentry Safe Model #472884*
I hope you registered you safe after you bought it. If not you still have a chance. Contact their support here.
They will be able to help
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 15, 2010 | Sentry Fireproof Safe
I Have The Key But Cant Remember How To Turn It And The Combo
The only way you can use the combo is to take the safe to a lock smith
Apr 20, 2009 | Sentry Fireproof Safe
Can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Apr 18, 2009 | Sentry Fireproof Safe
Get new combo on senry dial safe
Hi, There is only one way, and that is to send a letter with the serial number to Sentry and if the info matches who is supposed to own it, they will send you the factory default combo to open it. Good Luck!
Feb 14, 2009 | Sentry Fireproof Safe
Home Security Logo
Top The Home Security Experts
vince
 MikeWang
MikeWang
Level 1 Expert
Are you a The Home Security Expert? Answer questions, earn points and help others
