Question about Vacuums
Need to fid replacement recovery tank front panel model # F5915-900 hoover steam vac
  • 3,828 Answers
Ebay
or online parts supplier
PartsWarehouse com
need to fid replacement recovery tank front panel  - f5915-1-4l3mo04yvnp2xdvhjfffy5rf-3-0.gif
Posted on Apr 16, 2017
I own a hoover steam vac model # F5915900 inside the recovery tank the seal broke. Where can I buy a new rubber seal?
Here is the webpage for vac parts warehouse. This shows a diagram of your steam vac. You pick the part and buy it.
Hope this helps.
Handie Andie
Mar 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac has no suction, blowing air from middle of bottom
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Make sure the tank lid is aligned to the recovery tank to seal, and assure the square panel is in place on the front of the recovery tank that connects the vacuum of the tank to the clear nozzle plate.
Mar 22, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My steam vac doesn't seem to have suction. Help?
(1) Make sure tank lid is sealed to the tank.
(2) Is the filler panel in place on the front of the recovery tank? (Square shaped plastic panel)
(3) Is the tank gasket in place under the hood? There must be a rubber gasket on the round pipe that the recovery tank seals to when it sets down in to the cleaner foot. This connects the vacuum path to the tank.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steam vac is not releasing the cleaner
http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
Godbless
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Possible cause
Possible solution
• Solution tank not firmly in place
• Make sure tank is securely locked in
position
• Solution tank empty
• Refill tank according to instructions for
surface being cleaned
correctly
• Make sure lid is firmly in place
• Pump needs to be “primed” (when
using tool)
• See “Before using tool” section, p. 13
Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
Mar 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Automatic "shut off" not turning off
Check the filter in the tank, if a dual V model you will have a screen, if not a dual V move the foam filter down about 1/4" to help.The lid on either model needs to be securely in place, as well as locking the left and right latches. On the Dual V model, check the hose door on the front.
Feb 23, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Setting up for apolstery cleaning
Hoover Steam Vac F5853-900 Series 17.9
Remove the tank front panel by sliding it straight up. Replace panel with converter (located on end of hose, end is shaped like front panel that you slide out.Before connecting tube to cleaner, make sure black tabs are extended by pulling tan collar roward tube.Open door on hood labeled "Stair/Upholstery Cleaning Connection" Press round solution tube connector onto round projection inside door. Press connecator collar down firmly to ensure that it is fully connected.
When the solution tube is connected to the deep cleaner, the nozzle brushes will automatically be turned off and will not rotate when the deep cleaner is turned on even if the speed selector is in the HI oar LO position. For full suction, it is important that the recovery tank lid is properly secured before cleaning.The tank lid is replaced in a hinge-like manner. Position front of lid under tabs on front of tank. Rotate lid down onto tank. Make sure lid is secure on all sides before cleaning.Hope this helps.
Good Luck
Nov 15, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Just bought a Hoover steam vac. Did the dining room. everything okay.. emptied recovery tank and replaced. started on living room. dirty water not going into recovery tank. carpets very wet. What did I...
you may have put the lid on your recovery tank on wrong. on some models you have to lock the front in first then snap it down in the back. if you can pull the lid away from the tank then its on wrong and isnt making a seal.
Sep 27, 2008 | Vacuums
Hoover steam vac
  1. Remove your cleaning solution tank and set aside.
  2. Remove the lid to your recovery tank.
  3. Remove the front panel of the recovery tank by sliding it straight up.
  4. Slide the convertor half way down into the same slot. (Curved side down). The opening should be facing upward.
  5. Replace the recovery tank lid.
  6. Open the door marked stair/upholstery cleaning connection.
  7. Press the tube connector with the black tabs onto the projection inside the door.
  8. Replace you cleaning solution tank and you are ready to go.
Note: It's a good idea to turn your brushes off. Also, you may need to prime your hose by turning on your cleaner and holding the hand tool onto a flat surface for a few moments before use.
Aug 08, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
