Question about The Computers & Internet
My ZENWARE LCD monitor displays OUT OF RANGE H: 31 - 60Khz V: 56 - 75Khz Max. Res 1360X768 CURRENT MODE H: 64Khz V: 60Hz
In safe mode, it displays correctly. How to change the current range to within working range? Thanks. Lindsay
2 Suggested Answers
  • 91 Answers
SOURCE: my computer is not responding
dude just check the bios first !
it the bios works then check the cpu adn the ram
it has to be one of these normally !
Posted on Jan 29, 2010
Samsung SyncMaster S24B300 is not in optimum mode of 1920x1080 60Hz as it should, but in 1360x768 ocasionally is starting up in 1920x1080 but most of the time in lower resolution mode, could FixYa he
Using our onchip Intel graphics we experienced the same problem, where the aspect ratio was displayed wrong using the native resolution of 1920x1080 at 60Hz while black bars show on the left and right side.
The problem was partly solved by using custom timing settings as you can find below:
Front Porch: 90 and 19
Back Porch: 148 and 22
Sync Width: 42 and 4
Active: 1920 and 1080
Scan rate: (auto 67.5) and 60
Then you just have to move the image down a couple of pixels using the buttons on the display.
Aug 27, 2012 | Computers & Internet
Dell LCD Monitor will only work in safe mode - otherwise I get the error message Can't Display this Video Mode. I have reset to factory settings and also tried manually setting it to 1280x1024. When...
This Dell E153FPf 15" TFT can olny handle max 1024 x 768 @60Hz that is why you are getting the message ont the screen.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 03, 2011 | Dell E153FPf 15" TFT LCD Flat Panel...
My benq fp547 says its out of range...the image still shows up but there is a bar in the middle of the screen that says out of range...any ideas?
In windows change your display refresh rate to 60Hz. If you cant get into windows, boot into safe mode by holding f8 after a computer restart and change the settings from there.
Sep 09, 2010 | BenQ FP547 15" LCD Monitor
When I try to use my 17'' Soyo monitor with Windows 7 program the screen turns black and then ''out of range'' wording is all I get on the monitor. I have tried booting in safe mode, set the resolution to...
When you power up the compute press F8 key then enter in :"Enable vga mode" then go to display property and set screen resolution to 1024*768.
Then check .
If still same then enter in safe mode and uninstall graphic driver then start computer normal mode then install graphic driver.
Also in safe mode go to start->run type in run "chkdsk /r" then press ok then press "y" then restart computer then it fix and recovers error on harddrive.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 23, 2010 | Soyo Dymond DYLM017A 17" LCD Monitor
I keep on pulling in the monitor to my labtop. An
Sounds like your video settings are out of range. Start up your laptop in 'safe' mode, set the video to 1200x1024 and 60Hz then reboot normally.
Post back on the results.
Dec 01, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Blue box appears saying change resolution to 1024x768 60Hz
Try booting in safe mode. The res will be about 800 x 600 ( i think).
If that works great.
If the monitor is still unresponsive then you should try to RMA it.
Please don't diss my rating if you don't like the possible reality of the situation. It still may be the most helpful answer you'll get.
Sep 05, 2009 | Samsung SyncMaster 193V 19" Flat Panel LCD...
Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
May 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Compatible with Mac?
I have the same problem.  Did you find a solution or just return it?
Jul 21, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Out Of Range
Do the same procedure you do to enter "safe mode" but this time choose the "start in VGA mode" option, then change windows resolution.
May 08, 2008 | iiyama ProLite E380S-S 15" LCD Monitor
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
