Question about Garmin nuvi 205 GPS Receiver
Garmin 260 now failing to charge and shuts itself down
Unit worked fine for a year, but 3 days ago started to show "low battery" indicator and shuts itself down immediately thereafter
  • 1,606 Answers
If the unit is only a year old? then I would suspect that the charger has a problem that has damaged your battery. Do you use an external power continuously?
Try a different charger or if you have a meter make sure the charger is putting out close to the specs on it. Try using the usb cable to charge it.
The low battery and shutting off are typical of a battery that won't/can't hold a charge. That is typical after 2-3 years plus but not one year. It can also be indicitive of the charging circuit needing to be reset. The problem is it needs to be started and run long enough for it to recognize the reset command. To do this, hold your finger on the bottom right corner of the screen while powering the unit, until it asks if you want to reset it. That might get you running.
While I would be suprised at the battery going out within a year or so it is not unheard of. You may have to replace the internal battery pack. The unit is new enough your only source is probablly going to be Garmin. They might replace the battery under warrenty or out (if you talk nice).
Posted on Jul 24, 2009
Unit shuts down after about one minute.
When you leave a Nuvi on a charger for several hours and don't see full green bars, this is an indication that the battery is defective. Most Nuvi batteries last about 2 years. Most of the batteries have a date code of 2007. I would have the battery replaced as soon as possible as it can bloat and crack the case open. More info can be found here:
http://www.sharc.net/gps_battery_repair.htm
- Jim
Jun 01, 2010 | Garmin Nuvi 660 GPS Receiver
Shuts off, won't charge battery
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 26, 2009 | Garmin StreetPilot C330 GPS Receiver
I have got a nuvi 260 and it wont come on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
Battery on Nuvi 750
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 19, 2009 | Garmin nuvi 250W GPS Receiver
Garmin nuvi 260w not operating while plugged in
Based on your description, you are doing it right. You said....
"when i connect it to the car charger it shows the computer sysmbol and starts charging. there is no other usb port on the device"
That is correct. It takes about 2-3 hours to fully charge a low battery.
There is only a mini USB port on a 260.
It's used for charging and downloading updates of software or maps.
Sep 02, 2008 | Garmin nuvi 200W GPS Receiver
Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
Mar 02, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin Nuvi shuts itself off after only seconds during navigation
Is the battery charged? What does the battery indicator say? If you are using it in the car, is the power cord connected and working properly? If it is working correctly, you should see a lightning bolt symbol over the battery bar graph showing that it is connected to an external power source and that it is charging.
- Jim
Jan 23, 2008 | Garmin Nuvi 660 GPS Receiver
Mi streetpilot shut down when it's not pluged
Dead Battery. Garmin will replace battery for a charge if the unit is out of warranty.
Aug 10, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 205 GPS Receiver Logo
347 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
