Question about Canon Office Equipment & Supplies
SOURCE: C4480 cannot scan to pc
I can not scan from my printer to my pc. I have a hp c4480. everything works on it. bill
Posted on Aug 06, 2009
SOURCE: trying to scan, but keep getting error code
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Posted on Sep 05, 2009
  • 155 Answers
SOURCE: Canon - Pixma MP150 printer/scanner won't scan in color.
u've to install all third party drivers related ur printer that u've got on time of purches.
Posted on Sep 18, 2009
SOURCE: trying to scan, but keep getting error code 2,162,0 My scanner pr
This works!:
noavatar_s.gif the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
Posted on Oct 21, 2009
SOURCE: My Canon MP510 scanner won't
Try using your scanner from your computer, I'm using windows XP and when i go to My Computer and the printer is connected i see a section that says Scanner and Cameras, your printer should be there, click on it and follow the easy step to scan a document.
Posted on Nov 25, 2009
Problem with Canon Lide20/30. I want to multi scan photos. The multi scan in the simple mode is not working. The multi crop and size signs in advanced mode are not enabled. Tried uninstalling and...
Check the manual for that on this link
Hope it helps.
Mar 11, 2011 | Canon LIDE20 Flatbed Scanner
How to scan photo to save on computer ?
Instructions Things You'll Need:
  • Pictures to scan
  • Computer
  • Scanner
  1. Step 1 ** Prep your photos **
    What we're going to do here is take all your photos and put them onto one 8 1/2 x 11 sheet of paper.
    So take some tape and put it on the BACK of a photo. Then put that photo on the 8 1/2 x 11. You want to do it on the back so it won't ruin your original.
    Then repeat this for the other photos you've got. And make sure you leave some space between the photos. This is so they don't get stuck together or overlap.
    If you have lots and lots of photos that won't fit on one page, then use multiple pages to hold them. In other word, put as many as you can on a page.
  2. Step 2 ** Preparing to scan**
    Now that you've got your photos on an 8 1/2 x 11 piece of paper, it's time to put it onto the scanner. And be careful when holding the paper so your photos don't all fall off.
    Now carefully lay the paper with the photos facing DOWN on the glass of your scanner. And it doesn't matter if you're using a flatbed scanner or one of those combo printer/scanner/fax machines.
    TIP #1: I suggest making sure your glass is clean and free of streaks beforehand. Otherwise, you may see lines or distortions when the photos are scanned.
    TIP #2: Do NOT feed the paper through the sheet feeder if you have one. This may jam the feeder or damange your photos. So make sure you only lay the paper on the glass!
  3. Step 3 ** Ready to scan **
    The only thing left to do now is actually scan your photos. Now depending on your scanner software, you may be able to scan a specific area.
    In other words, many scanning software programs allow you to select the region or area of the paper you want to scan. If so, then I suggest you use this to crop your image around a specific picture. This will make the process easier.
    When you've done this, scan it! Once it's on your computer, you can edit it to make it ligher, sharper, etc. Or save it as is. Then you'd repeat this process for the next picture.
    If your software won't allow you to scan a specific area, then you'll need to scan the entire page. Do it! Once the image is on your computer, then you can use editing software to copy a specific portion to a new file. This is what you'll need to do to get individual photos.
    As an alternative, you could crop the one you just scanned and then save it. Then rescan the whole page again and crop it to the next picture. Both ways work the same, so is your choice which way to go.
Hope it will help you :)
Jul 23, 2010 | HP PSC 1350 All-In-One Thermal Printer
Canon Pixma MX850 won't scan - says 'set the pc to start scan'
Do you have more than one PC connected to the scanner? I have both a PC and a Mac connected to it, and I think my scanner is trying to connect to the Mac, which requires image capture software to be installed, rather than the PC. Don't know how to tell it to go to the PC, though...
Feb 01, 2010 | Canon PIXMA MX850 Multifunction Printer
How to scan slides to photos to hard drive using canon canoscan 8400f
Your scanner came with some software inside the box. If this is a second hand scanner with no additional software download the drivers from and run the software accordingly.
Mac os X does not require this process. connect the scanner to your machine and simply load the slides in the tray scanner and use the application "IMAGE CAPTURE" located in local_disk/applications/
The pictures automatically load and you select to crop or scan as is.
Later the image will appear on the desktop upon completion of scan.
For windows: I made you a link for your convenience:
Nov 07, 2009 | Electronics - Others
Scanned photos on my Canon Pixma MP190 come out about the size of a postage stamp. Then it gives option to edit or crop. Why don't they come out the size they are when scanned
all you have to do when you scan an image for example , you will set it to enlarge image.. do that it will appear big.. or the same as your pictured scan..
Sep 07, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Scan photos to computer
You need a scanner to scan the photos. I have a canon scanner and it works pretty well. That printer does not scan photos. it just prints them.
Apr 22, 2009 | HP Photosmart D7160 InkJet Printer
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Lost the manual
You can download the scanning guide here:
Run the installer, then double click the index.html file to load the table of contents.
Good Luck (you may need to search for 'LiDE2030' if you can't find where you downloaded and extracted the files)
Nov 17, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
How to get my scanner to scan only the photograph
When you scan the picture, make sure you do a preview of the scanning surface in the scanner software first, then select the region corresponding to the picture only, after that, select "scan" in the scanner software.
May 20, 2008 | HP PSC 750 All-In-One InkJet Printer
Open Questions:
29 people viewed this question
old marine
old marine
